    [Plugin] Lines to tubes
    131 Posts 61 Posters 307.7k Views 61 Watching
      Rename .rbz to .zip and extract files/folders. Place into Plugins folders
        @ckho1985 said:
        @tig said:
        Didier needs to rework his rb file for v2014 compatibility and republish it...
        BUT you can do it temporarily for your own use, even though his script is 'packed'.
        Open the file lines2tubes.rb in Notepad, and go to the end:
        Change
        ...}.unpack("m")**.to_s**
        to read
        ...}.unpack("m")**[0]**
        Save the changes.
        Restart SketchUp.
        The script will then load and work in v2014 !
        This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014.
        These edited scripts will also load and work in earlier SketchUp versions too... πŸ€“
        Working in Mac… not sure what to do 😞
        'Notepad.exe' is the PC's default plain-text editor.
        You will also have a similar simple one on your MAC [TextEdit?].
        For an even better text-editing tool look at MAC's free TextWrangler, which is like the PC's free Notepad++,exe...
        There are several other free ones too...
        Never edit a plugin with a word-processor !
        • keea1111K Offline
          keea1111
          HI,
          I am trying to install lines2tubes and/or pipe along path for Sketch up 2014, and not able to get it in my plugin's menu. Could someone help me figure this out. much thanks, Keea
          KEEA
            How are you trying to install it ?
            My PipeAlongPath is v2014 compatible and will install OK from the PluginsStore dialog's AutoInstall or when downloaded and installed from the equivalent rbz from the PluginStore pages...
            The v2014 compatibility of Lines2Tubes has been discussed in this and other threads.
            There might be a 'compatible version' if you do a little searching...
            A simple tweak might even fix it... pending the author getting his proverbial out of his proverbial πŸ˜’
            See earlier posts in this thread πŸ˜’
            • F Offline
              finhario
              Change
              to read
              Save the changes.
              Restart SketchUp.
              i do all the steps but still it's not working 😞 please help
                @Mario
                What have you done exactly ?
                The attached version should work on MAC or PC...
                I have tested it on both platforms, and it works fine for me !
                Compare it to your own effort ??
                Remember that the menu item is under Tools NOT Plugins !
                πŸ˜•
                lines2tubes.rb
                • RefkaR Offline
                  Refka
                  πŸ˜•
                  Thanks a lot TIG very useful.. 😍
                  • soloS Offline
                    Where is this tool hiding?, it's not in plugins, not on right click and not in tools.
                    • sdmitchS Offline
                      sdmitch
                      It should be on the Tools menu as "Convert arcs,circles,curves,lines to cylinders".
                      http://sdmitch.blogspot.com/
                      • soloS Offline
                        That's how it is in SU 2013, but not 2014, strange it's in plugin folder and all but not showing up.
                          Pete, which file did you download? I downloaded Didier's and it didn't work for me but when I downloaded and installed TIG's version and restarted SketchUp, it did. I converted TIG's version to .rbz (which I am attaching) to make it quick to install. I still had to close and restart SU to get it to show in the Tools menu.
                          lines2tubes2.rbz
                          • soloS Offline
                            That worked, thanks Dave.
                            I have a few plugins just like this that did not install in SU 2014, I now have a trick.
                              shawnyeh
                              hello,
                              I got the same situation that can't find lines2tube in tool menu bar in MAC sketchup2014 .
                              Is there anyone can help me out ?
                              Thanks.
                                shawnyeh
                                Thanks Dave, it works!!
                                • H Offline
                                  helik
                                  Thank you very much Dave!
                                    chris87
                                    Great plugin !
                                    Thank you !
                                      Please get the latest v2014/2015 compatible version from the PluginStore http://sketchucation.com/pluginstore?pln=lines2tubes
                                        chauhuyphan
                                        Great plugin! Thanks you !
                                        • josephkim626J Offline
                                          josephkim626
                                          As I am often giving precision 4 to give a rectangular look, im just wondering if there would be a way to rotate the profile 45 degrees. Effectively, having a rectangular tubes.
                                          • sdmitchS Offline
                                            sdmitch
                                            Yes, but this particular plugin is scrambled so only the creator can make that change.
                                            In the mean time, maybe this will help. You can copy and paste into the Ruby Console to try it out.
                                            mod = Sketchup.active_model
                                            ent = mod.active_entities
                                            sel = mod.selection
                                            unless sel.empty?
                                              vars=UI.inputbox(["Number of Sides;"," Length of a Side;","Angle of Rotation;"],[4,1,45],"Tube Specifications")
                                              if vars
                                                n,l,d=vars
                                                a=180/n
                                                r=l/Math.sin(a.degrees)/2
                                                edgs=sel.grep(Sketchup;;Edge)
                                                edgs.each{|e|
                                                  p,v=e.line
                                                  grp=ent.add_group;ge=grp.entities
                                                  tube=ge.add_ngon(p,v,r,n)
                                                  face=ge.add_face(tube)
                                                  ent.transform_entities(Geom;;Transformation.rotation(p,v,d.degrees),face)
                                                  face.followme e
                                                  grp.explode
                                            else
                                              UI.messagebox "Select Edges"
                                            • 5 / 7
