    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    [Plugin] CADup
    64 Posts 28 Posters 88.1k Views 28 Watching
    • O Offline
      oscartung
      omg!!! this is so great!
      thank you very much TIG
        MartinK
        Thanks TIG. I will be trying this out to create 2D furniture and fixtures from 3D files. This should make that a pretty simple task.
          Scaifewang
          Hi Tig
          Im way off center here but did you do any further owrk on this superb plugin?
          Works great getting 2d into DoubleCAD...
          Regards Scooby
            It's stalled at this stage - but it still has some useful features ๐Ÿ˜„
              khancyrus
              Brilliant Tig!
              • yorik1984Y Offline
                yorik1984
                Thank you for work!
                Can the script do this tipe of projection of detail?
                http://storage1.static.itmages.ru/i/13/0609/s_1370722566_8997578_4ada51f771.png
                And, optionaly, if it posible, user can choose what projection they need.
                  Here's a slight update http://sketchucation.com/forums/viewtopic.php?p=309485#p309485
                  It now comes with ArcCurveTests.rb for backwards compatibility with v7 etc when handling curves/arcs etc...
                  • V Offline
                    vfz
                    Hey TIG,
                    seems like a great plugin that would help a lot to me, but it seems I cannot get it to work (on SU 2014/Win).
                    When I run the command, after some processing it makes all the new layers, a copy of the component/group on SKAD layer, but all the other layers are empty. I do not see any of the 2D views.
                    the ruby console says
                    "skad
                    Error: #<TypeError: reference to deleted ComponentInstance>
                    <main>:in <main>' -e:1:in eval'
                    nil"
                    what do i do wrong?
                      Unsure.
                      It's an old plugin, but should still work in v2014...
                      Do you always get the error?
                      Can you post of PM a SKP containing the problem component...
                      ๐Ÿ˜•
                      • V Offline
                        vfz
                        Thanks for the fast answer.
                        I tried some different models, in different versions of su (7,8,2013,2014) and I always get the same results.
                        I really feel like an idiot now, but I don't see where can I send pm.
                          I now have your PM and SKP.
                          Unfortunately I'm away very shortly but I can look at it in the middle of next week...
                          • V Offline
                            vfz
                            Thanks TIG for the help. I've found my mistake. There were components inside the component.
                            I exploded everything and made one group/component and your plugin worked like a charm!
                              Thanks, saves me having to fix it ๐Ÿ˜‰
                                tombyrne
                                Ive Recently installed the CADup extension, I tried both ways, through the software and dropping it in the plugins folder, but I cant find it anywhere within the software, it tells me that its installed and ready for use but no sign of it, I looked under plugins and also toolbars,
                                Any tips?
                                  So, select your Component-Instance OR Group [and nothing else].
                                  Pick 'CADup' off the 'Tools' menu [or type 'cadup' or 'skad' in the
                                  Ruby Console]
                                  Nothing of this works for you?
                                    Ruby Console]
                                    As Pilou says - it appears under the 'Tools' menu as 'CADup'.
                                    It works in all versions of SketchUp from v2015 downwards - at least down to v8, but I suspect Pilou uses it in an even earlier versions. ๐Ÿ˜‰
                                    It is not without its foibles... some text on 'right-hand elevations/sections can get offset somewhat to the right - edit the container and relocate it manually; also the Axo views can sometimes over lap the last Ortho view nearest to them, but they can also be relocated easily...
                                    Sometimes a few edges are missed off...
                                    Its function is really to create a set of 2d Ortho/Axo views from a 3d component.
                                    For DXF/DWG export for use to CAD - the CADup layering allows you to differentiate between hidden lines etc in the CAD display...
                                      Here's v1.3.
                                      A quick botch to trap some errors and signed for v2016...
                                      Still very slow and flaky but it's just an idea...
                                      http://sketchucation.com/pluginstore?pln=CADup
                                        pibuz
                                        ..am I the only one thinking this plugins is REALLY AWESOME and would need an update? This really has a great potential: reducing models to 2d lines inside SU could ease the load of layout in recalculating vector viewports!
                                        TIG, is this a project you had some ideas on or not?
                                        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                          abuabu1982
                                          Dear My Friend/
                                          You created great Plugin. could you update it for Sketchup2022?
                                            Please install the latest version from the PluginStore [v2.0].
                                            It should be compatible with newer versions of SketchUp...
                                            • 2 / 4
