    [Plugin] CADup
    64 Posts 28 Posters 96.1k Views 28 Watching
    • gullfoG Offline
      gullfo
      no worries. thanks!
      Glenn
      http://www.runnel.com
        jim w
        Great Plugin !!!
        Thank you so much !!!
        The AXO's are great but I do a lot of "Isometeric Drawings" in CAD that have the base angles (x,y) at 30 degrees instead of the AXO's 45. Would it be possible somehow to get such an Iso at 30 degrees?
        Thanks again for you great work!!!
        Regards
        • TIGT Online
          @jim w said:
          Great Plugin !!!
          Regards
          Iso's are MUCH harder to make than Axo's... that's why you don't get them πŸ˜‰
          I have a made a separate IsoAxo toolset to set a view to Iso or Axo [with model Z-scaling as needed] - search for that on the forums here...
          I have an upgrade in the pipeline [currently 'blocked'] but that's not on the list πŸ˜’
            lapx
            Hello Tig,
            Will this be similar to the old ADO autimatic drawings export of pages in dwg or image format. Do you recall this ruby script. It was very easy to use. I think Didier B was the original author. It as also very useful.
            Thanks,
            • TIGT Online
              Not quite like ADO as it assembles actual 2d hidden line 'component's' as flat 2d objects based on the standard views...
              • O Offline
                oscartung
                omg!!! this is so great!
                thank you very much TIG
                  MartinK
                  Thanks TIG. I will be trying this out to create 2D furniture and fixtures from 3D files. This should make that a pretty simple task.
                    Scaifewang
                    Hi Tig
                    Im way off center here but did you do any further owrk on this superb plugin?
                    Works great getting 2d into DoubleCAD...
                    Regards Scooby
                    • TIGT Online
                      It's stalled at this stage - but it still has some useful features πŸ˜„
                        khancyrus
                        Brilliant Tig!
                        • yorik1984Y Offline
                          yorik1984
                          Thank you for work!
                          Can the script do this tipe of projection of detail?
                          http://storage1.static.itmages.ru/i/13/0609/s_1370722566_8997578_4ada51f771.png
                          And, optionaly, if it posible, user can choose what projection they need.
                          • TIGT Online
                            Here's a slight update http://sketchucation.com/forums/viewtopic.php?p=309485#p309485
                            It now comes with ArcCurveTests.rb for backwards compatibility with v7 etc when handling curves/arcs etc...
                            • V Offline
                              vfz
                              Hey TIG,
                              seems like a great plugin that would help a lot to me, but it seems I cannot get it to work (on SU 2014/Win).
                              When I run the command, after some processing it makes all the new layers, a copy of the component/group on SKAD layer, but all the other layers are empty. I do not see any of the 2D views.
                              the ruby console says
                              "skad
                              Error: #<TypeError: reference to deleted ComponentInstance>
                              <main>:in <main>' -e:1:in eval'
                              nil"
                              what do i do wrong?
                              • TIGT Online
                                Unsure.
                                It's an old plugin, but should still work in v2014...
                                Do you always get the error?
                                Can you post of PM a SKP containing the problem component...
                                πŸ˜•
                                • V Offline
                                  vfz
                                  Thanks for the fast answer.
                                  I tried some different models, in different versions of su (7,8,2013,2014) and I always get the same results.
                                  I really feel like an idiot now, but I don't see where can I send pm.
                                  • TIGT Online
                                    I now have your PM and SKP.
                                    Unfortunately I'm away very shortly but I can look at it in the middle of next week...
                                    • V Offline
                                      vfz
                                      Thanks TIG for the help. I've found my mistake. There were components inside the component.
                                      I exploded everything and made one group/component and your plugin worked like a charm!
                                      • TIGT Online
                                        Thanks, saves me having to fix it πŸ˜‰
                                          tombyrne
                                          Ive Recently installed the CADup extension, I tried both ways, through the software and dropping it in the plugins folder, but I cant find it anywhere within the software, it tells me that its installed and ready for use but no sign of it, I looked under plugins and also toolbars,
                                          Any tips?
                                            So, select your Component-Instance OR Group [and nothing else].
                                            Pick 'CADup' off the 'Tools' menu [or type 'cadup' or 'skad' in the
                                            Ruby Console]
                                            Nothing of this works for you?
                                            • 3 / 4
