    [Plugin] CADup
    64 Posts 28 Posters 97.0k Views 28 Watching
      mizar
      wonderful
        Update:
        Nothing new yet - I was somewhat bogged down by other issues this week... Designing door ironmongery and Revit stuff 🀒 et al... I'll try and get this restarted next week πŸ˜„
        • gullfoG Offline
          gullfo
          a complete awesome plugin TIG! i did find one peculiar behavior with groups created with housebuilder - the xplode function seems to think the entities are deleted. here's the ruby console message:
          Error: #<TypeError: reference to deleted Group>
          C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in explode' C:/Program Files/Google/Google SketchUp 8/Plugins/cadup.rb:222:in xplode'
          ...snip...numerous other lines...
          attached is the SU file which has the housebuilder group.
          test cadup with housebuilder script generated group
          Glenn
          http://www.runnel.com
            It's still 'work in progress' as I finish other paid stuff... I'll look and get back to you...
            • gullfoG Offline
              gullfo
              no worries. thanks!
              Glenn
                jim w
                Great Plugin !!!
                Thank you so much !!!
                The AXO's are great but I do a lot of "Isometeric Drawings" in CAD that have the base angles (x,y) at 30 degrees instead of the AXO's 45. Would it be possible somehow to get such an Iso at 30 degrees?
                Thanks again for you great work!!!
                Regards
                  @jim w said:
                  Great Plugin !!!
                  Regards
                  Iso's are MUCH harder to make than Axo's... that's why you don't get them πŸ˜‰
                  I have a made a separate IsoAxo toolset to set a view to Iso or Axo [with model Z-scaling as needed] - search for that on the forums here...
                  I have an upgrade in the pipeline [currently 'blocked'] but that's not on the list πŸ˜’
                    lapx
                    Hello Tig,
                    Will this be similar to the old ADO autimatic drawings export of pages in dwg or image format. Do you recall this ruby script. It was very easy to use. I think Didier B was the original author. It as also very useful.
                    Thanks,
                      Not quite like ADO as it assembles actual 2d hidden line 'component's' as flat 2d objects based on the standard views...
                      • O Offline
                        oscartung
                        omg!!! this is so great!
                        thank you very much TIG
                          MartinK
                          Thanks TIG. I will be trying this out to create 2D furniture and fixtures from 3D files. This should make that a pretty simple task.
                            Scaifewang
                            Hi Tig
                            Im way off center here but did you do any further owrk on this superb plugin?
                            Works great getting 2d into DoubleCAD...
                            Regards Scooby
                              It's stalled at this stage - but it still has some useful features πŸ˜„
                                khancyrus
                                Brilliant Tig!
                                • yorik1984Y Offline
                                  yorik1984
                                  Thank you for work!
                                  Can the script do this tipe of projection of detail?
                                  http://storage1.static.itmages.ru/i/13/0609/s_1370722566_8997578_4ada51f771.png
                                  And, optionaly, if it posible, user can choose what projection they need.
                                    Here's a slight update http://sketchucation.com/forums/viewtopic.php?p=309485#p309485
                                    It now comes with ArcCurveTests.rb for backwards compatibility with v7 etc when handling curves/arcs etc...
                                    • V Offline
                                      vfz
                                      Hey TIG,
                                      seems like a great plugin that would help a lot to me, but it seems I cannot get it to work (on SU 2014/Win).
                                      When I run the command, after some processing it makes all the new layers, a copy of the component/group on SKAD layer, but all the other layers are empty. I do not see any of the 2D views.
                                      the ruby console says
                                      "skad
                                      Error: #<TypeError: reference to deleted ComponentInstance>
                                      <main>:in <main>' -e:1:in eval'
                                      nil"
                                      what do i do wrong?
                                        Unsure.
                                        It's an old plugin, but should still work in v2014...
                                        Do you always get the error?
                                        Can you post of PM a SKP containing the problem component...
                                        πŸ˜•
                                        • V Offline
                                          vfz
                                          Thanks for the fast answer.
                                          I tried some different models, in different versions of su (7,8,2013,2014) and I always get the same results.
                                          I really feel like an idiot now, but I don't see where can I send pm.
                                            I now have your PM and SKP.
                                            Unfortunately I'm away very shortly but I can look at it in the middle of next week...
                                            • 3 / 4
