    [Plugin] CADup
    64 Posts 28 Posters 97.0k Views 28 Watching
      khancyrus
      Brilliant Tig!
      • yorik1984Y Offline
        yorik1984
        Thank you for work!
        Can the script do this tipe of projection of detail?
        http://storage1.static.itmages.ru/i/13/0609/s_1370722566_8997578_4ada51f771.png
        And, optionaly, if it posible, user can choose what projection they need.
          Here's a slight update http://sketchucation.com/forums/viewtopic.php?p=309485#p309485
          It now comes with ArcCurveTests.rb for backwards compatibility with v7 etc when handling curves/arcs etc...
          • V Offline
            vfz
            Hey TIG,
            seems like a great plugin that would help a lot to me, but it seems I cannot get it to work (on SU 2014/Win).
            When I run the command, after some processing it makes all the new layers, a copy of the component/group on SKAD layer, but all the other layers are empty. I do not see any of the 2D views.
            the ruby console says
            "skad
            Error: #<TypeError: reference to deleted ComponentInstance>
            <main>:in <main>' -e:1:in eval'
            nil"
            what do i do wrong?
              Unsure.
              It's an old plugin, but should still work in v2014...
              Do you always get the error?
              Can you post of PM a SKP containing the problem component...
              ๐Ÿ˜•
              • V Offline
                vfz
                Thanks for the fast answer.
                I tried some different models, in different versions of su (7,8,2013,2014) and I always get the same results.
                I really feel like an idiot now, but I don't see where can I send pm.
                  I now have your PM and SKP.
                  Unfortunately I'm away very shortly but I can look at it in the middle of next week...
                  • V Offline
                    vfz
                    Thanks TIG for the help. I've found my mistake. There were components inside the component.
                    I exploded everything and made one group/component and your plugin worked like a charm!
                      Thanks, saves me having to fix it ๐Ÿ˜‰
                        tombyrne
                        Ive Recently installed the CADup extension, I tried both ways, through the software and dropping it in the plugins folder, but I cant find it anywhere within the software, it tells me that its installed and ready for use but no sign of it, I looked under plugins and also toolbars,
                        Any tips?
                          So, select your Component-Instance OR Group [and nothing else].
                          Pick 'CADup' off the 'Tools' menu [or type 'cadup' or 'skad' in the
                          Ruby Console]
                          Nothing of this works for you?
                            Ruby Console]
                            As Pilou says - it appears under the 'Tools' menu as 'CADup'.
                            It works in all versions of SketchUp from v2015 downwards - at least down to v8, but I suspect Pilou uses it in an even earlier versions. ๐Ÿ˜‰
                            It is not without its foibles... some text on 'right-hand elevations/sections can get offset somewhat to the right - edit the container and relocate it manually; also the Axo views can sometimes over lap the last Ortho view nearest to them, but they can also be relocated easily...
                            Sometimes a few edges are missed off...
                            Its function is really to create a set of 2d Ortho/Axo views from a 3d component.
                            For DXF/DWG export for use to CAD - the CADup layering allows you to differentiate between hidden lines etc in the CAD display...
                              Here's v1.3.
                              A quick botch to trap some errors and signed for v2016...
                              Still very slow and flaky but it's just an idea...
                              http://sketchucation.com/pluginstore?pln=CADup
                                pibuz
                                ..am I the only one thinking this plugins is REALLY AWESOME and would need an update? This really has a great potential: reducing models to 2d lines inside SU could ease the load of layout in recalculating vector viewports!
                                TIG, is this a project you had some ideas on or not?
                                WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                  abuabu1982
                                  Dear My Friend/
                                  You created great Plugin. could you update it for Sketchup2022?
                                    Please install the latest version from the PluginStore [v2.0].
                                    It should be compatible with newer versions of SketchUp...
                                      mclaramoura
                                      Hello, TIG. Tnks for this, its amazing!
                                      Sorry my english, but i have a question.
                                      Working with Layout for Sketchup, will be insteresting if the plugin make cenes of this planes. Its possible?
                                      Remember me this Revit tool > https://help.autodesk.com/view/RVT/2024/PTB/?guid=GUID-3DD5B596-D353-489D-96EF-E3F46D287E5D
                                      With this, 2D orthogonal views will be referred to the model, updating when make changes in the model. I can do this manually, but can be a fast way to detail one architecture project with lot of carpentry. Basicly, one plugin that make cenes (section, top view, front view, axo...) of a component with one click.
                                      What do you think about that?
                                        What version of SketchUp are you actually using? You put 2018 Free/Make in your profile but that version has never existed.
                                          mclaramoura
                                          i work with skechup 2020 and recently 2023.
                                          • 3 / 4
