    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 201.7k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      For those who want Layers Panel to support Thea Render (or the other way around), please say so in this thread : http://sketchucation.com/forums/viewtopic.php?f=384%26amp;t=58168
      • Bob JamesB Offline
        Bob James
        Still get the occasional "Undo Layers Panel ID" when trying to undo an action.
        • danchoD Offline
          dancho
          Can you put inside plugin to arange layers in alphabetica order?
            smuncky
            @jiminy-billy-bob said:
            Hmmm, I'll look into it.
            Any luck on replicating the problem or finding the cause in the code?
              jiminy-billy-bob
              I couldn't replecate the issue. Could you send me your model?
                smuncky
                PM sent.
                  jiminy-billy-bob
                  New version 1.2.0 !
                  Changelog :
                  • Added an History dialog, to easily revert back if groups/order disappear
                  • Added a right-click menu
                  • Fixed an issue causing an infinite undo loop
                  • Fixed encoding issue with non-english characters and alphabets
                  • The dialog now remembers its position in OSX
                  • Fixed minimizing
                  • Added support for KeyShot5
                  http://i.imgur.com/bzlLnCc.png
                  Download in the plugin store !
                    jiminy-billy-bob
                    If you already updated to 1.2.0, please redownload it. I fixed a minor glitch.
                    • cmeedC Offline
                      cmeed
                      Amazing job. Thank you.
                      • BoxB Offline
                        I just noticed your toolbar is persistent, meaning even if you choose to close it it will reopen on next startup. Is it possible to remove this behavior.
                        I've notice quite a few tools do this and it makes for a minor nuisance when you want to use a minimal number of toolbars.
                          jiminy-billy-bob
                          Box > On windows 7 64bits, with SU2014?
                          It works fine for me.
                          • BoxB Offline
                            Hmmm, interesting, I'm on the same setup. I just updated the plugin and it still does it. I'll have to have a look around and see if it's something up my end although both Sdmitch and Eneroth3 were able to give me the line edit to stop it opening.
                              jiminy-billy-bob
                              Could you send me what they told you to modify for their plugin?
                              • BoxB Offline
                                Here you go.
                                Deck builder
                                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58084%26amp;p=533860#p533827
                                Railway
                                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57831%26amp;start=240#p533089
                                  jiminy-billy-bob
                                  Ok, try to redownload, I added Eneroth's fix.
                                  • BoxB Offline
                                    Yep, that's done the trick. Thanks.
                                      glro
                                      I tried
                                      I got an error message while i was trying to move some layers to a group
                                      too bad
                                      the appearance is well finished, and it fits a need
                                      error message
                                        @giro
                                        What version of Internet Explorer do you have ?
                                          glro
                                          internet explorer 11.0.9600.17239
                                          @tig said:
                                          @giro
                                            jiminy-billy-bob
                                            Sorry, I was away and didn't see your post.
                                            Could you translate the error message?
                                            I can't reproduce it, could you explain in detail how you got the error?
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 33
                                            • 34
                                            • 25 / 34
