    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 286.5k Views 110 Watching
    • Y Offline
      yiannis76
      Update it for Keyshot 5 please.
      Thank you very much.
        smuncky
        @jiminy-billy-bob said:
        @smuncky said:
        This is the error that comes up when I open up the ruby console:
        Error: #<NoMethodError: undefined method `get_attribute' for nil:NilClass>
        Is this the whole error?
        Sorry, must've deleted it while editing.
        This is followed right after:
        c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3159:in get_cascading_attribute' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3279:in get_attribute_formula'
        c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3260:in get_attribute_value' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1052:in has_behaviors'
        c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1080:in block in has_behaviors' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in each'
        c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in has_behaviors' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1080:in block in has_behaviors'
        c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in each' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in has_behaviors'
        c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs:819:in `onComponentAdded'
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          This error is related to Dynamic components, not Layers Panel.
            smuncky
            Do you have any idea as to why this error only happens when Layers Panel is on?
              jiminy-billy-bob
              Hmmm, I'll look into it.
                jiminy-billy-bob
                For those who want Layers Panel to support Thea Render (or the other way around), please say so in this thread : http://sketchucation.com/forums/viewtopic.php?f=384%26amp;t=58168
                • Bob JamesB Offline
                  Bob James
                  Still get the occasional "Undo Layers Panel ID" when trying to undo an action.
                  • danchoD Offline
                    dancho
                    Can you put inside plugin to arange layers in alphabetica order?
                      smuncky
                      Any luck on replicating the problem or finding the cause in the code?
                        jiminy-billy-bob
                        I couldn't replecate the issue. Could you send me your model?
                          smuncky
                          PM sent.
                            jiminy-billy-bob
                            New version 1.2.0 !
                            Changelog :
                            • Added an History dialog, to easily revert back if groups/order disappear
                            • Added a right-click menu
                            • Fixed an issue causing an infinite undo loop
                            • Fixed encoding issue with non-english characters and alphabets
                            • The dialog now remembers its position in OSX
                            • Fixed minimizing
                            • Added support for KeyShot5
                            http://i.imgur.com/bzlLnCc.png
                            Download in the plugin store !
                              jiminy-billy-bob
                              If you already updated to 1.2.0, please redownload it. I fixed a minor glitch.
                              • cmeedC Offline
                                cmeed
                                Amazing job. Thank you.
                                • BoxB Offline
                                  I just noticed your toolbar is persistent, meaning even if you choose to close it it will reopen on next startup. Is it possible to remove this behavior.
                                  I've notice quite a few tools do this and it makes for a minor nuisance when you want to use a minimal number of toolbars.
                                    jiminy-billy-bob
                                    Box > On windows 7 64bits, with SU2014?
                                    It works fine for me.
                                    • BoxB Offline
                                      Hmmm, interesting, I'm on the same setup. I just updated the plugin and it still does it. I'll have to have a look around and see if it's something up my end although both Sdmitch and Eneroth3 were able to give me the line edit to stop it opening.
                                        jiminy-billy-bob
                                        Could you send me what they told you to modify for their plugin?
                                        • BoxB Offline
                                          Here you go.
                                          Deck builder
                                          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58084%26amp;p=533860#p533827
                                          Railway
                                          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57831%26amp;start=240#p533089
                                            jiminy-billy-bob
                                            Ok, try to redownload, I added Eneroth's fix.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 29 / 34
