    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
      smuncky
      @jiminy-billy-bob said:
      @smuncky said:
      This is the error that comes up when I open up the ruby console:
      Error: #<NoMethodError: undefined method `get_attribute' for nil:NilClass>
      Is this the whole error?
      Sorry, must've deleted it while editing.
      This is followed right after:
      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3159:in get_cascading_attribute' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3279:in get_attribute_formula'
      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:3260:in get_attribute_value' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1052:in has_behaviors'
      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1080:in block in has_behaviors' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in each'
      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in has_behaviors' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1080:in block in has_behaviors'
      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in each' c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcclass_v1.rbs:1077:in has_behaviors'
      c:/users/asoloviev/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/su_dynamiccomponents/ruby/dcobservers.rbs:819:in `onComponentAdded'
      • jiminy-billy-bobJ
        jiminy-billy-bob
        This error is related to Dynamic components, not Layers Panel.
          smuncky
          Do you have any idea as to why this error only happens when Layers Panel is on?
          • jiminy-billy-bobJ
            jiminy-billy-bob
            Hmmm, I'll look into it.
            • jiminy-billy-bobJ
              jiminy-billy-bob
              For those who want Layers Panel to support Thea Render (or the other way around), please say so in this thread : http://sketchucation.com/forums/viewtopic.php?f=384%26amp;t=58168
              • Bob JamesB
                Bob James
                Still get the occasional "Undo Layers Panel ID" when trying to undo an action.
                • danchoD
                  dancho
                  Can you put inside plugin to arange layers in alphabetica order?
                    smuncky
                    Any luck on replicating the problem or finding the cause in the code?
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      I couldn't replecate the issue. Could you send me your model?
                        smuncky
                        PM sent.
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          New version 1.2.0 !
                          Changelog :
                          • Added an History dialog, to easily revert back if groups/order disappear
                          • Added a right-click menu
                          • Fixed an issue causing an infinite undo loop
                          • Fixed encoding issue with non-english characters and alphabets
                          • The dialog now remembers its position in OSX
                          • Fixed minimizing
                          • Added support for KeyShot5
                          http://i.imgur.com/bzlLnCc.png
                          Download in the plugin store !
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            If you already updated to 1.2.0, please redownload it. I fixed a minor glitch.
                            • cmeedC
                              cmeed
                              Amazing job. Thank you.
                              • BoxB
                                I just noticed your toolbar is persistent, meaning even if you choose to close it it will reopen on next startup. Is it possible to remove this behavior.
                                I've notice quite a few tools do this and it makes for a minor nuisance when you want to use a minimal number of toolbars.
                                • jiminy-billy-bobJ
                                  jiminy-billy-bob
                                  Box > On windows 7 64bits, with SU2014?
                                  It works fine for me.
                                  • BoxB
                                    Hmmm, interesting, I'm on the same setup. I just updated the plugin and it still does it. I'll have to have a look around and see if it's something up my end although both Sdmitch and Eneroth3 were able to give me the line edit to stop it opening.
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      Could you send me what they told you to modify for their plugin?
                                      • BoxB
                                        Here you go.
                                        Deck builder
                                        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58084%26amp;p=533860#p533827
                                        Railway
                                        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57831%26amp;start=240#p533089
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          Ok, try to redownload, I added Eneroth's fix.
                                          • BoxB
                                            Yep, that's done the trick. Thanks.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 29 / 34
