    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.5k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Hmmm, I'll look into it.
        jiminy-billy-bob
        For those who want Layers Panel to support Thea Render (or the other way around), please say so in this thread : http://sketchucation.com/forums/viewtopic.php?f=384%26amp;t=58168
        • Bob JamesB Offline
          Bob James
          Still get the occasional "Undo Layers Panel ID" when trying to undo an action.
          • danchoD Offline
            dancho
            Can you put inside plugin to arange layers in alphabetica order?
              smuncky
              Any luck on replicating the problem or finding the cause in the code?
                jiminy-billy-bob
                I couldn't replecate the issue. Could you send me your model?
                  smuncky
                  PM sent.
                    jiminy-billy-bob
                    New version 1.2.0 !
                    Changelog :
                    • Added an History dialog, to easily revert back if groups/order disappear
                    • Added a right-click menu
                    • Fixed an issue causing an infinite undo loop
                    • Fixed encoding issue with non-english characters and alphabets
                    • The dialog now remembers its position in OSX
                    • Fixed minimizing
                    • Added support for KeyShot5
                    http://i.imgur.com/bzlLnCc.png
                    Download in the plugin store !
                      jiminy-billy-bob
                      If you already updated to 1.2.0, please redownload it. I fixed a minor glitch.
                      • cmeedC Offline
                        cmeed
                        Amazing job. Thank you.
                        • BoxB Offline
                          I just noticed your toolbar is persistent, meaning even if you choose to close it it will reopen on next startup. Is it possible to remove this behavior.
                          I've notice quite a few tools do this and it makes for a minor nuisance when you want to use a minimal number of toolbars.
                            jiminy-billy-bob
                            Box > On windows 7 64bits, with SU2014?
                            It works fine for me.
                            • BoxB Offline
                              Hmmm, interesting, I'm on the same setup. I just updated the plugin and it still does it. I'll have to have a look around and see if it's something up my end although both Sdmitch and Eneroth3 were able to give me the line edit to stop it opening.
                                jiminy-billy-bob
                                Could you send me what they told you to modify for their plugin?
                                • BoxB Offline
                                  Here you go.
                                  Deck builder
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58084%26amp;p=533860#p533827
                                  Railway
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57831%26amp;start=240#p533089
                                    jiminy-billy-bob
                                    Ok, try to redownload, I added Eneroth's fix.
                                    • BoxB Offline
                                      Yep, that's done the trick. Thanks.
                                        glro
                                        I tried
                                        I got an error message while i was trying to move some layers to a group
                                        too bad
                                        the appearance is well finished, and it fits a need
                                        error message
                                          @giro
                                          What version of Internet Explorer do you have ?
                                            glro
                                            internet explorer 11.0.9600.17239
                                            @tig said:
                                            @giro
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 29 / 34
