    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 276.9k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Box > On windows 7 64bits, with SU2014?
      It works fine for me.
      • BoxB Offline
        Hmmm, interesting, I'm on the same setup. I just updated the plugin and it still does it. I'll have to have a look around and see if it's something up my end although both Sdmitch and Eneroth3 were able to give me the line edit to stop it opening.
          jiminy-billy-bob
          Could you send me what they told you to modify for their plugin?
          • BoxB Offline
            Here you go.
            Deck builder
            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58084%26amp;p=533860#p533827
            Railway
            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57831%26amp;start=240#p533089
              jiminy-billy-bob
              Ok, try to redownload, I added Eneroth's fix.
              • BoxB Offline
                Yep, that's done the trick. Thanks.
                  glro
                  I tried
                  I got an error message while i was trying to move some layers to a group
                  too bad
                  the appearance is well finished, and it fits a need
                  error message
                  • TIGT Online
                    @giro
                    What version of Internet Explorer do you have ?
                      glro
                      internet explorer 11.0.9600.17239
                      @tig said:
                      @giro
                        jiminy-billy-bob
                        Sorry, I was away and didn't see your post.
                        Could you translate the error message?
                        I can't reproduce it, could you explain in detail how you got the error?
                          glro
                          "not possible to get the property "inserbefore', reference null or not defined...
                          do you want to continue script of the page?"
                          more or less...
                            jiminy-billy-bob
                            Thanks,
                            Could you explain in detail how you got the error?
                              glro
                              Thanks,
                              i was trying to make a group of different layers
                              i selected them as shown in the video, and i couldn't drop them
                              but...
                              i tried again and this time it worked
                              false alarm, sorry
                              seems to be working on my computer too
                                jiminy-billy-bob
                                Great, I'm glad it works.
                                Maybe you tried just after installing the plugin, before restarting SU?
                                  jiminy-billy-bob
                                  Thanks for the donation, glro, I appreciate it! 😉
                                  • F Offline
                                    fountainhead
                                    I've had some strange behaviour creep in with layers panel recently. At least once a day, possibly more, the layers dialogue ends up blank, with no layers showing at all. When I chose the recent history dialogue, only one of multiple layers is restored. The only solution for me is to close Sketchup, remove both the jbb_layers_panel folder, and the jbb_layers_panel.rb, then reload Sketchup, and reinstall the .rbz file. Once that is done, all of the layers show up again...until the next sudden disappearance. I need to point out that the layers don't disappear from an .skp file that is currently open, only when opening an existing .skp file initially. The behaviour also repeats itself with the same .skp file over and over. In the last 3 days, I have had to unload/reload layers panel on the same .skp file on 4 separate file opening occasions. Any ideas?
                                    • F Offline
                                      fountainhead
                                      A little more information. Opened an skp file this morning, no layers. Unloaded and re-loaded layers panel, all good. Opened a second, different skp file, no layers in that one, then I decided to open the previous skp file, directly from the open skp file. Since the previous file was open on the desktop, Sketchup warned me "file is open, open read only blah blah", as soon is a picked no, to cancel the load of the previous file, boom, all of the layers in 'layers panel' loaded up in the currently open file, where they, just seconds ago, were unavailable.
                                      Not sure if that helps figure out what could be going on.
                                        jiminy-billy-bob
                                        • Are you running on windows or MAC?
                                        • If windows, what's your Internet Explorer version?
                                        • What's your Sketchup version?
                                        • When the dialog is blank, are you able to use its buttons? For exemple, does the "Add layer" button adds a new layer in Sketchup's layers window?
                                        • Could you try with all other plugins disabled? (Rename the plugins folder to "Plugins2", and create a new "Plugins" folder with only Layers Panel files in it)
                                        (Please answer all questions, thanks)
                                          glro
                                          i have too
                                          sketchup just freezed when i clicked on "select highlighted layer"
                                          the plugin would be very useful, but it doesn't seem stable
                                            jiminy-billy-bob
                                            Any more detail which could help me identify the issue?
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 30 / 34
