    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • TIGT Online
      Yes, make sure you have the correct Plugins folder - as revealed by my code snippet.
      Then change its permissions to FULL Read/Write... AND choose to apply the changes to the contents of that folder too...
      It should work both Dave and I have MACs that do this without issues...
      • john2J Offline
        john2
        @bobpineo said:
        Hello Fredo,
        Love your Plugins, thank you!
        I keep getting this message..."libfredo6 will be updated at next startup of sketchup.
        I have tried reloading, deleting obsolete files etc etc.
        Can you help me figure out what is going on?
        Best BP
        plus the following:(after I get the initial libfredo update warning.
        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DBUR_UcsManager.rb:12:in <top (required)>' Error: c:/program files (x86)/sketchup/sketchup 2014/tools/dm_artisan/artisan.rbs:273: invalid multibyte char (UTF-8) c:/program files (x86)/sketchup/sketchup 2014/tools/dm_artisan/artisan.rbs:273: invalid multibyte char (UTF-8) c:/program files (x86)/sketchup/sketchup 2014/tools/dm_artisan/artisan.rbs:273: syntax error, unexpected end-of-input, expecting keyword_end data="90¡M5lªÙ[:}¶šä^Ÿ-Ú¢ßÓjt@+¡©t›p}x±" #just garbage ^ C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:10:in eval'
        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:10:in load' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:10:in module:Artisan'
        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:3:in <module:DM>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan/artisan_load.rb:1:in <top (required)>'
        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:18:in register_extension' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:18:in module:Artisan'
        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:5:in <module:DM>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/DM_artisan.rb:4:in <top (required)>'
        I faced a similar issue while copying my plugins. Download the latest rbz from artisan’s official website. Install this extension, and these errors will be fixed. 👍
        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        • TIGT Online
          @Bob Pineo
          Somewhat belatedly I read your post...
          Your error messages relate to .rb files loading from the Tools folder.
          Some of these, like Didier Bur's current UCSmanager, and the older version of Artisan are not compatible with v2014.
          BUT you should have NO plugins files loading from the Tools folder in v2014 except the three which ship with SketchUp itself:
          sketchup.rb extensions.rb langhandler.rb
          and a subfolder named ' RubyStdLib', which contains dozens of Ruby2 files...
          [and there might also be a lone file named something like !_fix_ruby_startup2-1-2.rb - but that is only IF you have manually downloaded and installed it yourself - it allows you to open SKPs on remote drives and thereby launch SketchUp without breaking SketchUp.exe - a known bug in v2014M0 that will be fixed within the imminent v2014M1]
          If you have incorrectly manually copied these additional plugins files into the Tools folder you must remove them [and their subfolders].
          They all belong in your user's Plugins folder !
          To find where that is, use Sketchup.find_support_file('Plugins') in the Ruby Console, BUT remember that the Preferences > Extensions > Install... button and/or the SketchUcation AutoInstall tool will extract RBZ's files and add them into the correct Plugins folder for you = without any need to manually tinker with things and break SketchUp...
          Please do NOT copy plugins from earlier SketchUps unless there is no possible alternative.
          Newer v2014-compatible versions for most common Plugins are available in the SCF PluginStore, Trimble's EWarehouse, Smustard.com, other Plugin's-Website etc.
          Get those.
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v6.0a - 18 Jun 14
            LibFredo6 6.0a is a release for:
            • DrawAlong 1.1a,
            • MoveAlong 1.2a,
              which are published as part of FredTools 2.0a.
            This updates provides fixes and evolutions for
            • DrawAlong: inferences when drawing on a plane
            • MoveAlong: Move with alignment
            See main post of this thread for Download of LibFredo6.
              Jooles13
              Disregard! All sorted
                ckarch87
                thax a lot
                • OxerO Offline
                  Oxer
                  New Spanish Language File.
                  Spanish Language
                    Stonecold
                    Still not working on Sketchup 2014. Here is the error, what am I doing wrong?
                    Error Loading File Fredo6_!LibFredo6.rb
                    Error: #<LoadError: cannot load such file -- LibTraductor.rb>
                    C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                    C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:29:in `<top (required)>'
                    Hm... Renamed Lib6Traductor to LibTraductor and it worked somehow o.O
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v6.0b - 16 Jul 14
                      LibFredo6 6.0b is a release for the support of Section Planes in:
                      • DrawAlong,
                      • MoveAlong,
                        which are published as part of FredTools 2.0.
                      Section Planes can now be moved and be used as a reference for inferencing
                        Papapa
                        Hey Fredo,
                        Thanks for the great work you do with these plugins.
                        But why do you make these pages so complicated to read? Everything looks like a link that you can click or something, and all kind of bullet lists don't help. I'm trying to look for the download link, which should be recognizable in the page, and I stumble all the time with words and titles and headers which are misleading. Couldn't you simplify it so it's easier to find things? It's missing a sort of hierarchy in the page in my opinion.
                        Cheers
                        • TIGT Online
                          @papapa said:
                          Hey Fredo,
                          Cheers
                          Use the PluginStore !
                          • fredo6F Offline
                            Precisely, as TIG highlighted, you should use Sketchucation PluginStore, which is an addon script running within Sketchup. This is where you'll see the single "Install' button.
                            The web page in the forum is primarily informative about the Plugin. It is organized in sections hoping users would read some of them prior to use the plugin and thus avoid common problems.
                            • architexA Offline
                              architex
                              How do I install LibFredo 6 (new release.
                              I have try to install with the skechucation toolbar.. Autoinstall don't do anything. I have to install all by .RBZ (for me is the only way to install any plugins)
                              Any suggestions?
                              • fredo6F Offline
                                Any suggestions?
                                Strange. SCF Plugin Store tools works on SU2013.
                                Did you install some of my plugins along with LibFredo6?
                                  matiu
                                  i have libfredo 6 57 says i need 58 or higher where do i get higher version??
                                  • TIGT Online
                                    It is at v6.0b, and it is currently available in the PluginStore - learn to use it. it'll make you life a lot easier...
                                      behnam123
                                      thanks!!!!! From Iran
                                      • Z Offline
                                        zemane
                                        sketchup 2014 says it can't find Fredo Library folder after I install it.
                                          It must not be installed correctly. How and where did you install it?
                                          • Z Offline
                                            zemane
                                            I used SU2014 extension warehouse. It allocates the folder under the correct path.. but SU doesn't see it. Why??
                                            the folder is there, under appdata......plugins, with the default extensions, under the name of Fredo6_!LibFredo6 and Fredo6_!LibFredo6.rb
                                            What should be wrong?
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 109
                                            • 110
                                            • 62 / 110
