    Sketchup Pro 2014 hangs every time I quit (Mac)
    36 Posts 13 Posters 12.7k Views 13 Watching
    • E
      ecomike1
      I really appreciate the back and forth between all involved.
      I want to reiterate what Jeff is saying regarding the issue not being posted on the Podium forum. The reason, I believe, is that people in general didn't know it was the fault of one particular plugin until we dug further and went through the plugins one by one. Very time consuming, even for the personalities which are more detailed oriented.
      Bigstick, thanks for taking care of this, and I'm looking forward to your report on the issue.
      Thanks again everybody!
        mwm5053
        I can report that I've had the same issues as econmike1 but using Twilight often had to force quit from Activity Monitor or it SU 2014 would crash and want to report to Apple instead of a Bug Splat. Also can tell you I have a Mac HD/Library SU 2013 and SU 2014 folder with SU plugins 😕
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          driven
          Rant Warning:
          with all these 'renderer' plugins the first question whether it is a single user, single computer license?
          If the answer to both is 'yes' , then the developers should be installing it into your licensed 'User' folder, I can see absolutely no reason not to...
          As of v2014, for them to place it elsewhere, requires them making all the needed folders, as SU no longer does.
          If it is a "network" license, then the new folders could be in the "Shared" folder, and symlinked to each 'User' folder,
          If it is a "any computer, one User" license, they each should be in the "User" folder of each computer,
          The only conceivable reason to have an installer is to bury bits all over the system...
          Regardless of how clever or complex they may be, it's a Plugin not a Primary app, if I un-instal the Primary app, I want all the plugins to vanish as well.
          but maybe that's just me...
          • bigstickB
            bigstick
            This is a classic case of principles vs pragmatism. In absolute terms, of course you're right, and on Windows it's not a problem. What I found in the office was that security restrictions prevented any access to the 'Program Files' folders.
            This meant that plugins couldn't be installed by anyone other than the IT department, because security permissions prohibit users being given Local Admin rights.
            The move in SU 2014 to move this to areas where UAC doesn't get excited is a really big thing for my office.
            On the Mac, it's the standard OS X installer that has problems. We tried doing things the other ('correct') way, but found that unfortunately it created significant issues for end users. The solution (for the moment at least) is to end up with our current installation path, which isn't ideal, but it does work.
            • bigstickB
              bigstick
              I've just tested a new build that fixes the hanging on exit issue. It has taken a while, but we think we finally have it resolved. I'll post an update when we release it.
              Sorry about the delay - apparently it's been tricky to pin down...
              • H
                helvetica
                Is there any update on this fix for podium? I bought it, and I love it, but the crashing of SU is an issue for me. I also believed it was a problem with SU so I'm watching this post with interest.
                • bigstickB
                  bigstick
                  Yes, we recently released a new build which fixes this behaviour.
                  • jeff hammondJ
                    nice. great news
                    • EdsonE
                      Edson
                      I had been affected by this glitch for a long time. the new build has really fixed it. now I can just quit Sketchup.
                      dave and jim, thanks for fixing this irrelevant but annoying problem.
                      best regards.
                      http://www.mahfuz.arq.br
                      • W
                        whitelock
                        Hi All, I am not very computer savvy in terms of how to download and install things on a mac, how do you get this new build for the bug fixes, do you uninstall old version first. please help.
                        • EdsonE
                          Edson
                          the podium site has all the instructions on how to uninstall and install the new build.
                            SgtSlick
                            So bigstick, where we can download this new build you mentioned that fixes the issue? I'm using MAc OSX 10.8.5 not Mavericks and I have to force quit everytime.
                            • SkalpS
                              Skalp
                              You can do a very fast force quit by typing exit! on the ruby console.
                              It's even a lot faster than a normal quit.
                              Skalp
                              http://www.skalp4sketchup.com
                                steveyeong
                                i just DL the latest version of v2 plus for sketch up 2014 mac.
                                now the problem had been resolved. no more hanging when quitting!
                                finally ! good job.
                                  rcavenecia
                                  the difference in my case is that I use render[in] rather than podium...
                                  it is annoying having to force quit every time... and having to load back the plugin's icons.
                                  solutions anyone?
                                  • 2 / 2
