    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 696.7k Views 121 Watching
    • fredo6F Offline
      Oxer,
      Thanks very much. This will go in the next update.
      • fredo6F Offline
        NEW RELEASE: FredoTools v1.9b - 17 May 14
        FredoTools 1.9b is a release for
        • DrawAlong 1.0b,
        • MoveAlong 1.1b,
        It includes:
        • a fix for VCB inputs in architectural units in DrawAlong and MoveAlong
        • an updated translation in Spanish-Spain (ES) by Oxer
        See main post of this thread for Download of FredoTools.
        • fredo6F Offline
          NEW RELEASE: FredoTools v2.0a - 18 Jun 14
          FredoTools 2.0a is a release for
          MoveAlong v1.2,
          DrawAlong v1.1.
          • fredo6F Offline
            NEW RELEASE: FredoTools v2.0b - 07 Jul 14
            FredoTools 2.0b is a release fixing a bug in MoveAlong (signaled by dedmin)
            • guanjinG Offline
              guanjin
              Since the beginning of language files 2.0A, there has been a lot of abandoned character, can not be cleared, it can not be translated
              • fredo6F Offline
                What do you mean exactly?
                • leolouieL Offline
                  leolouie
                  I have been updating all my plugins to 2014, but have been stuck on some error messages. Is there an old file in conflict or is there something in the coding:
                  Error Loading File Fredo6_!LibFredo6.rb
                  Error: #<ArgumentError: invalid byte sequence in UTF-8>
                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in block in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in each'
                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:186:in startup' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:307:in module:LibFredo6'
                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'
                    Have you updated the actual LibFredo version?
                    Looks like something in the 'set' is NOT updated to me 😕
                    • leolouieL Offline
                      leolouie
                      I removed all Fred06 plugins and restarted SU14. I did not get any errors. The I installed LibFredo6 and the errors came back.
                      • fredo6F Offline
                        The best is to show the file list in your Plugins directory. There is definitely an old file, non converted to UTF8.
                        • leolouieL Offline
                          leolouie
                          I added back all your plugins and now there are no errors. Does FredoTools return an error message when it finds no plugins to manage?
                            pipinek
                            Greetings,
                            I am not able to mange to get the illustrated Fredo6 Tools icon toolbar appeared as shown on this page.
                            When I call a Fredo6 Tools toolbar I have got only the first icon in the toolbar, ie lancher one.
                            Any helpful suggestion will be deeply appreciated.
                            • fredo6F Offline
                              @pipinek said:
                              Greetings,
                              Go to the Default Parameters dialog (or click on yellow wrench) and enable the icons you wish. You can also read the main post.
                              • fredo6F Offline
                                NEW RELEASE: FredoTools v2.1a - 12 Oct 14
                                FredoTools 2.1a is a release for:
                                EdgeInspector v1.2: more accurate and relevant detection of fixing for Tiny Edges, Lost Junctions and Tiny Gaps
                                DrawAlong 1.2 v1.2: fixes for inferences on construction points and drawing construction points (avoid doubling)
                                • guanjinG Offline
                                  guanjin
                                  Show incomplete, occasionally show
                                  • fredo6F Offline
                                    NEW RELEASE: FredoTools v2.2a - 19 Oct 14
                                    FredoTools 2.2a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                    • guanjinG Offline
                                      guanjin
                                      When I first opened sketchup, click Edge Inspector icon, a pop-up dialog box blank and click on the other icon again, and then click will display correctly。
                                      • fredo6F Offline
                                        guanjin,
                                        Can you open the Ruby console and see if there are errors displayed.
                                        Do you get this problem with the English version or the Chinese version
                                        • guanjinG Offline
                                          guanjin
                                          @fredo6 said:
                                          guanjin,
                                          Without prompting any errors.
                                          There are Chinese characters display dislocation, English normal
                                          This problem has continued for several versions of this
                                          Earlier versions without problems
                                          Thank you fredo6
                                          guanjin
                                          • fredo6F Offline
                                            @guanjin
                                            I can have a look.
                                            But could you send me the FredoTools_ZH.lang file that you use. Currently, I don't have one updated for EdgeInspector.
                                            • 23
                                            • 24
                                            • 7 / 24
