    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.8k Views 122 Watching
    • fredo6F
      NEW RELEASE: FredoTools v1.8e - 20 Apr 14
      FredoTools 1.8d is a release fixing a problem in MoveAlong v1.0.
      The issue was about moving a selection containing a huge number of entities, as signaled by rv1974.
      • OxerO
        Oxer
        Thanks for the new version and new tool Move Along πŸ‘
        I have made a new Spanish Language (Spain) file to include the new tool.
        • fredo6F
          Oxer,
          Thanks. I will integrate in the next release.
          Also, for info, all the tooltips for inferences in MoveAlong are actually defined in LibFredo6, not in FredoTools. This is why they won't appear in Spanish.
          • OxerO
            Oxer
            Thanks for the info Fredo. I have made the new Spanish Language (Spain) file to LibFredo6, do you want that i upload it here or in LibFredo6 topic?
            • fredo6F
              Oxer,
              Better in the LibFredo6 thread.
              • OxerO
                Oxer
                Ok.
                • fredo6F
                  NEW RELEASE: FredoTools v1.9a - 15 May 14
                  FredoTools 1.9a is a release for
                  • DrawAlong 1.0,
                  • MoveAlong 1.1,
                  See main post of this thread for Download of FredoTools.
                  • cottyC
                    cotty
                    Great update!!
                    Thank you.
                    my SketchUp gallery
                    • OxerO
                      Oxer
                      New Spanish Language File for FredoTools - v1.9a - 15 May 14
                      P.S: If you have like preference Spanish Language (Spain) simply change the ES in filename to --> SP
                      • fredo6F
                        Oxer,
                        Thanks very much. This will go in the next update.
                        • fredo6F
                          NEW RELEASE: FredoTools v1.9b - 17 May 14
                          FredoTools 1.9b is a release for
                          • DrawAlong 1.0b,
                          • MoveAlong 1.1b,
                          It includes:
                          • a fix for VCB inputs in architectural units in DrawAlong and MoveAlong
                          • an updated translation in Spanish-Spain (ES) by Oxer
                          • fredo6F
                            NEW RELEASE: FredoTools v2.0a - 18 Jun 14
                            FredoTools 2.0a is a release for
                            MoveAlong v1.2,
                            DrawAlong v1.1.
                            • fredo6F
                              NEW RELEASE: FredoTools v2.0b - 07 Jul 14
                              FredoTools 2.0b is a release fixing a bug in MoveAlong (signaled by dedmin)
                              • guanjinG
                                guanjin
                                Since the beginning of language files 2.0A, there has been a lot of abandoned character, can not be cleared, it can not be translated
                                • fredo6F
                                  What do you mean exactly?
                                  • leolouieL
                                    leolouie
                                    I have been updating all my plugins to 2014, but have been stuck on some error messages. Is there an old file in conflict or is there something in the coding:
                                    Error Loading File Fredo6_!LibFredo6.rb
                                    Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
                                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
                                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
                                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in block in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in each'
                                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
                                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:186:in startup' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:307:in module:LibFredo6'
                                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'
                                      Have you updated the actual LibFredo version?
                                      Looks like something in the 'set' is NOT updated to me πŸ˜•
                                      • leolouieL
                                        leolouie
                                        I removed all Fred06 plugins and restarted SU14. I did not get any errors. The I installed LibFredo6 and the errors came back.
                                        • fredo6F
                                          The best is to show the file list in your Plugins directory. There is definitely an old file, non converted to UTF8.
                                          • leolouieL
                                            leolouie
                                            I added back all your plugins and now there are no errors. Does FredoTools return an error message when it finds no plugins to manage?
                                            • 11
                                            • 23
                                            • 24
                                            • 9 / 24
