    [Plugin] FredoTools - v4.6a - 21 Oct 26
    464 Posts 123 Posters 882.8k Views 121 Watching
    • OxerO
      Oxer
      Thanks for the new version and new tool Move Along πŸ‘
      I have made a new Spanish Language (Spain) file to include the new tool.
      • fredo6F
        Oxer,
        Thanks. I will integrate in the next release.
        Also, for info, all the tooltips for inferences in MoveAlong are actually defined in LibFredo6, not in FredoTools. This is why they won't appear in Spanish.
        • OxerO
          Oxer
          Thanks for the info Fredo. I have made the new Spanish Language (Spain) file to LibFredo6, do you want that i upload it here or in LibFredo6 topic?
          • fredo6F
            Oxer,
            Better in the LibFredo6 thread.
            • OxerO
              Oxer
              Ok.
              • fredo6F
                NEW RELEASE: FredoTools v1.9a - 15 May 14
                FredoTools 1.9a is a release for
                • DrawAlong 1.0,
                • MoveAlong 1.1,
                See main post of this thread for Download of FredoTools.
                • cottyC
                  cotty
                  Great update!!
                  Thank you.
                  my SketchUp gallery
                  • OxerO
                    Oxer
                    New Spanish Language File for FredoTools - v1.9a - 15 May 14
                    P.S: If you have like preference Spanish Language (Spain) simply change the ES in filename to --> SP
                    • fredo6F
                      Oxer,
                      Thanks very much. This will go in the next update.
                      • fredo6F
                        NEW RELEASE: FredoTools v1.9b - 17 May 14
                        FredoTools 1.9b is a release for
                        • DrawAlong 1.0b,
                        • MoveAlong 1.1b,
                        It includes:
                        • a fix for VCB inputs in architectural units in DrawAlong and MoveAlong
                        • an updated translation in Spanish-Spain (ES) by Oxer
                        • fredo6F
                          NEW RELEASE: FredoTools v2.0a - 18 Jun 14
                          FredoTools 2.0a is a release for
                          MoveAlong v1.2,
                          DrawAlong v1.1.
                          • fredo6F
                            NEW RELEASE: FredoTools v2.0b - 07 Jul 14
                            FredoTools 2.0b is a release fixing a bug in MoveAlong (signaled by dedmin)
                            • guanjinG
                              guanjin
                              Since the beginning of language files 2.0A, there has been a lot of abandoned character, can not be cleared, it can not be translated
                              • fredo6F
                                What do you mean exactly?
                                • leolouieL
                                  leolouie
                                  I have been updating all my plugins to 2014, but have been stuck on some error messages. Is there an old file in conflict or is there something in the coding:
                                  Error Loading File Fredo6_!LibFredo6.rb
                                  Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
                                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
                                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
                                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in block in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in each'
                                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
                                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:186:in startup' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:307:in module:LibFredo6'
                                  C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'
                                    Have you updated the actual LibFredo version?
                                    Looks like something in the 'set' is NOT updated to me πŸ˜•
                                    • leolouieL
                                      leolouie
                                      I removed all Fred06 plugins and restarted SU14. I did not get any errors. The I installed LibFredo6 and the errors came back.
                                      • fredo6F
                                        The best is to show the file list in your Plugins directory. There is definitely an old file, non converted to UTF8.
                                        • leolouieL
                                          leolouie
                                          I added back all your plugins and now there are no errors. Does FredoTools return an error message when it finds no plugins to manage?
                                          • P
                                            pipinek
                                            Greetings,
                                            I am not able to mange to get the illustrated Fredo6 Tools icon toolbar appeared as shown on this page.
                                            When I call a Fredo6 Tools toolbar I have got only the first icon in the toolbar, ie lancher one.
                                            Any helpful suggestion will be deeply appreciated.
                                            • 11
                                            • 23
                                            • 24
                                            • 9 / 24
