    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.8k Views 122 Watching
    • OxerO
      Oxer
      New Spanish Language File for FredoTools - v1.9a - 15 May 14
      P.S: If you have like preference Spanish Language (Spain) simply change the ES in filename to --> SP
      • fredo6F
        Oxer,
        Thanks very much. This will go in the next update.
        • fredo6F
          NEW RELEASE: FredoTools v1.9b - 17 May 14
          FredoTools 1.9b is a release for
          • DrawAlong 1.0b,
          • MoveAlong 1.1b,
          It includes:
          • a fix for VCB inputs in architectural units in DrawAlong and MoveAlong
          • an updated translation in Spanish-Spain (ES) by Oxer
          See main post of this thread for Download of FredoTools.
          • fredo6F
            NEW RELEASE: FredoTools v2.0a - 18 Jun 14
            FredoTools 2.0a is a release for
            MoveAlong v1.2,
            DrawAlong v1.1.
            • fredo6F
              NEW RELEASE: FredoTools v2.0b - 07 Jul 14
              FredoTools 2.0b is a release fixing a bug in MoveAlong (signaled by dedmin)
              • guanjinG
                guanjin
                Since the beginning of language files 2.0A, there has been a lot of abandoned character, can not be cleared, it can not be translated
                • fredo6F
                  What do you mean exactly?
                  • leolouieL
                    leolouie
                    I have been updating all my plugins to 2014, but have been stuck on some error messages. Is there an old file in conflict or is there something in the coding:
                    Error Loading File Fredo6_!LibFredo6.rb
                    Error: #<ArgumentError: invalid byte sequence in UTF-8>
                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in block in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in each'
                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:186:in startup' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:307:in module:LibFredo6'
                    C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'
                      Have you updated the actual LibFredo version?
                      Looks like something in the 'set' is NOT updated to me 😕
                      • leolouieL
                        leolouie
                        I removed all Fred06 plugins and restarted SU14. I did not get any errors. The I installed LibFredo6 and the errors came back.
                        • fredo6F
                          The best is to show the file list in your Plugins directory. There is definitely an old file, non converted to UTF8.
                          • leolouieL
                            leolouie
                            I added back all your plugins and now there are no errors. Does FredoTools return an error message when it finds no plugins to manage?
                            • P
                              pipinek
                              Greetings,
                              I am not able to mange to get the illustrated Fredo6 Tools icon toolbar appeared as shown on this page.
                              When I call a Fredo6 Tools toolbar I have got only the first icon in the toolbar, ie lancher one.
                              Any helpful suggestion will be deeply appreciated.
                              • fredo6F
                                @pipinek said:
                                Greetings,
                                Go to the Default Parameters dialog (or click on yellow wrench) and enable the icons you wish. You can also read the main post.
                                • fredo6F
                                  NEW RELEASE: FredoTools v2.1a - 12 Oct 14
                                  FredoTools 2.1a is a release for:
                                  EdgeInspector v1.2: more accurate and relevant detection of fixing for Tiny Edges, Lost Junctions and Tiny Gaps
                                  DrawAlong 1.2 v1.2: fixes for inferences on construction points and drawing construction points (avoid doubling)
                                  • guanjinG
                                    guanjin
                                    Show incomplete, occasionally show
                                    • fredo6F
                                      NEW RELEASE: FredoTools v2.2a - 19 Oct 14
                                      FredoTools 2.2a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                      • guanjinG
                                        guanjin
                                        When I first opened sketchup, click Edge Inspector icon, a pop-up dialog box blank and click on the other icon again, and then click will display correctly。
                                        • fredo6F
                                          guanjin,
                                          Can you open the Ruby console and see if there are errors displayed.
                                          Do you get this problem with the English version or the Chinese version
                                          • guanjinG
                                            guanjin
                                            @fredo6 said:
                                            guanjin,
                                            Without prompting any errors.
                                            There are Chinese characters display dislocation, English normal
                                            This problem has continued for several versions of this
                                            Earlier versions without problems
                                            Thank you fredo6
                                            guanjin
