    [Plugin] Lines to tubes
    131 Posts 61 Posters 307.7k Views 61 Watching
      sarkarshomit
      @ssokol said:
      Hi , I have problem, Line2Tubes doesn't show up under tools in Sketchup 2014?
      In Sketchup 8 works perfect.
      Any help?
      +1 to that...have similar problem...wont show up in SU2014...installed it using Sketchucation Plugin store app...installs through that in plugins folder of SU2014...but wont show up anywhere....please help...very useful...kinda missing it...dont want to go back to SU8...
      PS: I Read the whole thread and checked that I dont have any older versions installed.
      Till then using TIG's pipe along path
        Didier needs to rework his rb file for v2014 compatibility and republish it...
        BUT you can do it temporarily for your own use, even though his script is 'packed'.
        Open the file lines2tubes.rb in Notepad, and go to the end:
        Change
        ...}.unpack("m")**.to_s**
        to read
        ...}.unpack("m")**[0]**
        Save the changes.
        Restart SketchUp.
        The script will then load and work in v2014 !
        This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014.
        These edited scripts will also load and work in earlier SketchUp versions too... πŸ€“
        • demD Offline
          dem
          Unfortunately, while plugin starts in v2014, it still does not work. Hope Didier wil fix it
          upd. oops, im sorry. its was a conflict with old CompoSpray version
            Did you do the temporary edit fix I suggested two posts ago ?
            • unclebimU Offline
              unclebim
              Change
              to read
              Save the changes.
              Restart SketchUp.
              Thank you! Fixed!
                ckho1985
                Change
                to read
                Save the changes.
                Restart SketchUp.
                Working in Mac… not sure what to do 😞
                  Working? Or not working?
                    ckho1985
                    as in I know I could drag n drop the .rb file in windows.
                    but now I am using a mac in office computer. can't do the drag-n-drop anymore. (or is there a way?)
                    anyway i can alter the .rbZ file to work?
                    another suggestion. would be superb if there is a option of having square / rectangular tube rather than circular cylinder only. πŸ‘ πŸ‘ πŸ‘
                      what is stopping you doing the drag and drop?
                      @ckho1985 said:
                      anyway i can fix the .rbx file?
                      .rbx? It should be an .rbx file. Are you using our PluginStore?
                      Isn't a 4 sided circle a square?
                        ckho1985
                        %(#0040FF)[the Mac I am using is not a personal machine and my user account do not allow to me to gain access to the system and make alterations of softwares.
                        I can update and install plugins, while I am in the software. but I cannot get to the actual software folder. Maybe there is a way to bypass it that I do not know.]
                        I can install .rbz file by install extension, but not drag-drop .rb file.
                        %(#0040FF)[what i meant was a tube allow to choose its facing direction. i.e.; a flat surface facing up like a hand rail.
                        a rectangular tube with dimension input would help. i.e.; a 100mm x 50mm tube…]
                        sorry that haven't been thorough
                          Rename .rbz to .zip and extract files/folders. Place into Plugins folders
                            Change
                            to read
                            Save the changes.
                            Restart SketchUp.
                            'Notepad.exe' is the PC's default plain-text editor.
                            You will also have a similar simple one on your MAC [TextEdit?].
                            For an even better text-editing tool look at MAC's free TextWrangler, which is like the PC's free Notepad++,exe...
                            There are several other free ones too...
                            Never edit a plugin with a word-processor !
                            • keea1111K Offline
                              keea1111
                              HI,
                              I am trying to install lines2tubes and/or pipe along path for Sketch up 2014, and not able to get it in my plugin's menu. Could someone help me figure this out. much thanks, Keea
                              KEEA
                                How are you trying to install it ?
                                My PipeAlongPath is v2014 compatible and will install OK from the PluginsStore dialog's AutoInstall or when downloaded and installed from the equivalent rbz from the PluginStore pages...
                                The v2014 compatibility of Lines2Tubes has been discussed in this and other threads.
                                There might be a 'compatible version' if you do a little searching...
                                A simple tweak might even fix it... pending the author getting his proverbial out of his proverbial πŸ˜’
                                See earlier posts in this thread πŸ˜’
                                • F Offline
                                  finhario
                                  Change
                                  to read
                                  Save the changes.
                                  Restart SketchUp.
                                  i do all the steps but still it's not working 😞 please help
                                    @Mario
                                    What have you done exactly ?
                                    The attached version should work on MAC or PC...
                                    I have tested it on both platforms, and it works fine for me !
                                    Compare it to your own effort ??
                                    Remember that the menu item is under Tools NOT Plugins !
                                    πŸ˜•
                                    lines2tubes.rb
                                    • RefkaR Offline
                                      Refka
                                      πŸ˜•
                                      Thanks a lot TIG very useful.. 😍
                                      • soloS Offline
                                        Where is this tool hiding?, it's not in plugins, not on right click and not in tools.
                                        • sdmitchS Offline
                                          sdmitch
                                          It should be on the Tools menu as "Convert arcs,circles,curves,lines to cylinders".
                                          http://sdmitch.blogspot.com/
                                          • soloS Offline
                                            That's how it is in SU 2013, but not 2014, strange it's in plugin folder and all but not showing up.
                                            • 5 / 7
