    [Plugin] Extended Views v1.2 UPDATE May 23, 2013
    80 Posts 40 Posters 138.3k Views 40 Watching
    • JClementsJ
      JClements
      Thanks, Chris.
      • simon le bonS
        simon le bon
        Hi Chris, Hi everybody,
        @chris fullmer said:
        EDIT: Confirmed, it doesn't work with version 4,5,6 or earlier. Just version 7. Sorry Pilou and any other SU6/5 devotees!
        (Am I SU6 devotee ? Not sure. I just still use it mainly. Why? May be because I'm not found of the actual way of SketchUp development.)
        Thank you ++ for this new plugin!! I don't need it for I'm still with Su6, but I Keep it in mind for future.
        ... Also, how to you embed Jing videos in the forum????? I've been trying to forever!
        Cool to mention my How can i attach a Flash (Swf) video to my posts
        but You can better follow this simpler way by Ecuadorian.
        Easy way to embed Youtube video in SketchUcation that I mentioned at the end of the thread.. 👍 👍
        😉 simon
        • E
          ermethic
          Any way of making the standard views also force a Parallel Projection switch to the camera ? I've been looking everywhere for a plugin that would do that, but i haven't found anywhere.
          Thank you very much in advance...
            It's easiest enough to add a shortcut key combo to toggle between parallel and perspective camera settings. That way the tools suit everyone and pressing a key to change from one format or the other is no great hardship 😕
            • E
              ermethic
              I know, that's how i am working at the moment. Although the things i'm working on require constant changing from various parallel projection viewpoints to perspective and back, and it's kind of a hassle to press several keys each time i'm changing the view, and i was wondering if there is anything i can add to the script to force changing to parallel each time i switch to a standard right/front/top view, and to perspective when i switch to iso.
              Coming from 3ds max, it's very easy there to switch fast between named views with just a single shortcut, and i'm kind of missing that 😄
              • sicksickisckS
                sicksickisck
                brilliant!
                • W
                  wodur
                  works perfect it was exactly what I was looking for, thank you.
                  • W
                    wodur
                    works perfect and really improves sketchup possibilities to draw 2D while everything is represented 3D but working with several axes views I realize that it could be interesting to have a way to save the axes position.
                      Set the view as a scene-tab and then revert to it as needed...
                      • G
                        glro
                        Didier BUR made UCS manager plugin to do exactly that, but i don't find it anymore on the web
                        • ntxdaveN
                          ntxdave
                          I like the plugin because I find that I need to view from the bottom fairly often which the standard views does not do. However, I am wondering if it could be made to use my zoom setting instead of always Zoom to Extent. Since I started using it, I always wind up having to zoom back in to where I was instead or it just "rotating" he camera to view from the bottom.
                          If this is not realistic, just let me know.........
                          Press F1...thank me later
                          • leedeeteeL
                            leedeetee
                            Hi Chris,
                            Just wondering if there are any plans to make this 2016 friendly? Love the plug in, would be a great help.
                            Cheers.
                              driven
                              I think the version in 'Extension Warehouse' is working, even if it gives a warning when installing...
                              • leedeeteeL
                                leedeetee
                                Thank you John.
                                  ronhiatt
                                  What a great plugin! Once installed, I mapped my arrow keys to it, and now I can see the basic mechanical views of my cabinets. Obviously this should have been the default in SU originally. THANKS!!
                                  How do I send a donation? Really.
                                  Ron
                                    AirWindSolar
                                    Any word on an update for SU2017? This was probably the extension that I most often forgot wasn't just an integral part of SketchUp, and I'm missing the functionality a lot.
                                      drw12333
                                      any chance for update to 2017?
                                      • T
                                        tuoni
                                        One of the best plugins and simplest, I use nowadays in SketchUp. In particularly with Vray. Keep up the good work Chris Fullmer! But any words about the upcoming update for 2017 version?
                                        • W
                                          wrc86
                                          Are you OK Chris Fullmer? Is there anyone that can fix extender views for SU2018 or a code to copy and paste to make ir work?
                                          • T
                                            tomaszdrgas
                                            Hy .. Dzieńdobry
                                            I'm just starting with sketchup API and I have choosen CLF Extended Views as a sample lo see how extention should be made..
                                            Soon enough I realised that it doesn't work in sketchup 2017..
                                            I found out it was due to change made in sketchup 2017 when exploding groups..
                                            I started to learn ruby last month but with lots of digging in sketchup's API documentation I managed to fix it.. (So proud 😄)
                                            Here is the .rbz file (just zipped it and changed the extention to .rbz)
                                            This should work
                                            I wanted to send that file directly to Chris so he could maintain it in extention warehouse but couldn't find his email.. Hope You don't mind.. It was a greate excercise to me..
                                            Tomasz
                                            D 1 Reply Last reply
                                            • 3 / 4
