    [Plugin] Extended Views v1.2 UPDATE May 23, 2013
    80 Posts 40 Posters 133.8k Views 40 Watching
    • ntxdaveN Offline
      ntxdave
      I like the plugin because I find that I need to view from the bottom fairly often which the standard views does not do. However, I am wondering if it could be made to use my zoom setting instead of always Zoom to Extent. Since I started using it, I always wind up having to zoom back in to where I was instead or it just "rotating" he camera to view from the bottom.
      If this is not realistic, just let me know.........
      Press F1...thank me later
      • leedeeteeL Offline
        leedeetee
        Hi Chris,
        Just wondering if there are any plans to make this 2016 friendly? Love the plug in, would be a great help.
        Cheers.
          driven
          I think the version in 'Extension Warehouse' is working, even if it gives a warning when installing...
            leedeetee
            Thank you John.
              ronhiatt
              What a great plugin! Once installed, I mapped my arrow keys to it, and now I can see the basic mechanical views of my cabinets. Obviously this should have been the default in SU originally. THANKS!!
              How do I send a donation? Really.
              Ron
                AirWindSolar
                Any word on an update for SU2017? This was probably the extension that I most often forgot wasn't just an integral part of SketchUp, and I'm missing the functionality a lot.
                  drw12333
                  any chance for update to 2017?
                    tuoni
                    One of the best plugins and simplest, I use nowadays in SketchUp. In particularly with Vray. Keep up the good work Chris Fullmer! But any words about the upcoming update for 2017 version?
                    • W Offline
                      wrc86
                      Are you OK Chris Fullmer? Is there anyone that can fix extender views for SU2018 or a code to copy and paste to make ir work?
                        tomaszdrgas
                        Hy .. Dzieńdobry
                        I'm just starting with sketchup API and I have choosen CLF Extended Views as a sample lo see how extention should be made..
                        Soon enough I realised that it doesn't work in sketchup 2017..
                        I found out it was due to change made in sketchup 2017 when exploding groups..
                        I started to learn ruby last month but with lots of digging in sketchup's API documentation I managed to fix it.. (So proud 😄)
                        Here is the .rbz file (just zipped it and changed the extention to .rbz)
                        This should work
                        I wanted to send that file directly to Chris so he could maintain it in extention warehouse but couldn't find his email.. Hope You don't mind.. It was a greate excercise to me..
                        Tomasz
                        D 1 Reply Last reply Reply Quote 0
                        • JClementsJ Offline
                          JClements
                          . . . But it works with user defined axes. Currently if you change the axis of your model, and then change to one of the standard views, it will not align to your set axis. This plugin fixes that and it aligns the camera to the user defined axis.
                          Although it includes a Bottom View icon and performs a "Zoom Extents", it doesn't pivot the view according to the CURRENT axis, however.
                          I tested this new version using SU2018.
                            tomaszdrgas
                            I use 2016 and 2017.. I don't have possibility to check how it works in 2018..
                            • jujuJ Offline
                              juju
                              Kindly update your profile, which reads that you're still on v8.
                              • SJS66S Offline
                                SJS66
                                Hi guys, I just installed this plugin for SU 2020 but when I click any of the Extended Views toolbars, all it seems to do is insert 4 guide points in a box shape. I tried changing my axis but no difference. How do you get it to work?
                                  pipinek
                                  Greetings,
                                  Indeed it would be awesome if this splendid tool could be compatible with SU 2020.
                                  Any chance to get the uodate?
                                  Many thanks in advance.
                                    Unfortunately this tool has failed since mid-v2018 !
                                    It is pretty old !
                                    SketchUp changed the way that references to exploded items are handled.
                                    So the cpoints in the temporary group are now deleted and recreated, rather than retained.
                                    Thus the error, when they are no longer found...
                                    Because the © in the header is 'All rights reserved' it can't be changed by others and distributed...
                                    I suggest you contact Chris Fullmer direct to see if he's prepared to correct it.
                                    The method would be to attach a specific custom-attribute to each of the cpoints, then when the temporary group is exploded the recreated cpoints get the same attributes, so then in the exploded results the new cpoints can be recollected 'by attribute' in the same order, so they can be reused [before finally erasing them...]
                                      pipinek
                                      It is pretty old !
                                      Hello,
                                      I do thank you for your piece of advice.
                                      I will follow it.
                                      Best regards
                                      • F Offline
                                        freeagent
                                        Hey hey, was this ruby ever updated? or is there a version that works with new versions on sketchup?
                                        • F Offline
                                          freeagent
                                          @tomaszdrgas said:
                                          Hy .. Dzieńdobry
                                          [attachment=0:y2hlc1k7]<!-- ia0 -->CLF Extended Views.rbz<!-- ia0 -->[/attachment:y2hlc1k7]
                                          Tomasz
                                          hey Tomaz, i tested it, doesnt work 😞
                                          • Didier BurD Offline
                                            Didier Bur
                                            @pipinek and freeagent:
                                            Take a look at this: https://sketchucation.com/plugin/1284-dbur_ucsmanager_v1_0_0
                                            Basically it's an 'axes manager' but besides that the 6 views can be changed absolute to the main axes or relatively to your custom set of axes.
                                            Regards,
                                            DB
                                            • 4 / 4
