MSPhysics 1.0.3 (16 October 2017)
@pixero said:
Can it do soft bodies too?
Newton 3.12 has that feature, but its unfinished. I might integrate it into MSPhysics when its finished.
@jiminy-billy-bob said:
@solo said:
Say I want to fill a bowl with marbles, how can that be done?
Select your bowl, in the context menu choose "static" in "state", and "coumpound from mesh" in "shape".
Compound from mesh bodies are not recommended, as complex bodies could generate improper collisions. You might set a bowl static mesh, but make sure that the front faces are always facing out because the front faces are the only faces that generate the collisions, not the back faces.
Tried a bowl like Solo suggested. Marbles are falling though the bowl. So tried some boxes. Had to scale everything x10 or the boxes would stick through the bowl. I guess I need to tweak some settings.
Yeah, tiny objects are no good for newton. Another thing is I'll add the continuous collision mode feature, where objects won't fly through at fast speeds.
What are the chances of a mac version?
The chances of a Mac version is like the chances of snow here in Salem Oregon - 3%
As you noticed this plugin requires AMS Library which is fully dependent on the Windows API. The mac version will be created, but it will lack a lot of features from the Windows version. -
Too bad, but thanks for the explanation of why.
As you noticed this plugin requires AMS Library which is fully dependent on the Windows API. The mac version will be created, but it will lack a lot of features from the Windows version.What things do you need to do?
Very Nice ruby.
But I wanted reference guide.(Ex: pdf file)Thank you so much!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thank you so much.
The reference will be available on version 1.0.0 - after all things are done on the list
Take your time. You are building something wonderful.
If you need help let us know.
That is a pretty darn excellent work, all the starting features are right up my alley and I did at least attempt to add them to my custom SketchyPhysics build.
Can you talk a little more about the new physics engine, how extensive are it's features?
- can you do custom friction, bounce and stiffness per entity
- perhaps even collision accuracy per entity
- can collision groups be defined (so some entities will never interact with others)
- is there any chance to add entities during the simulation (so a distanced area would not be included at the start but then add as you move closer)
- and by that extent can a partial simulation be done, say only the selected items are considered and nothing else (that way you could quickly go in and out of testing a small item without everything in the model interfering)
Hello Mister K,
Thank you, I tried my best.
MSPhysics uses same physics engine that SketchyPhysics used - NewtonDynamics. SketchyPhysics uses a custom build of Newton version 1 or 2, I'm not sure which one, meanwhile MSPhysics uses Newton 3.12 which is the latest build available. Newton 3.x.x is far more advanced than its prior versions. Newton 3 allows you to add friction, restitution (bounce coefficients), contact points, contact forces, mass, center of mass, inertia forces, and more. The soft bodies feature of Newton is not yet complete though, but I'm positive it will get finished while I integrate the current features of Newton.
To make sure we don't miss any features of Newton I decided to import all of its functions and write all wrap-up functionality in Ruby, such as custom jonts. I used Ruby FFI to import all Newton functions.
@mister k said:
-can you do custom friction, bounce and stiffness per entity
Yes, you can! In fact I already integrated it into the Body class. You might want to see documentation: MSPhysics::BodyContext, its huge!
You mean contact body, point, normal, and speed? Yes, each body has an onTouch event which yields these parameters.
This is absolutely plausible. I will add that feature.
Of course, I had that in mind when scripting. You not only able to add bodies while simulation, but your also capable to destroy them. The script handles this stuff properly, so no more crashes.
I was thinking about that. +1 to the TODO list.
The current version has a good body API. All I need is to create webdialogs to record body scripts. BTW, the error handlers will be much better now. Errors will cause simulation to terminate properly.
Another thing is that MSPhysics bodies have true center of mass. Oh yeah, it doesn't modify body's origin like SP did. All operations are fully undo-able. Clossing SketchUp after play and reset will not ask you whether to save anything (unless you didn't save before playing) because all movements are undone properly.
And yeah, its nice to meet you here
Anton -
Yabba-Dabba Do! It looks great so far. But if you're coding this all yourself it seems like it would take ages to get it all done...which is why Sketchyphysics was incomplete.
