    MSPhysics 1.0.3 (16 October 2017)
    928 Posts 171 Posters 1.3m Views 172 Watching
    • tt_suT Offline
      tt_su
      @anton_s said:
      As far as uploading it to GitHub, it will be in a matter of days.
      πŸŽ‰ 😍
        josuapa
        @cotty said:
        Fist test VERY promising! πŸ‘ πŸŽ‰
        [screenr:zkq34ycx]yhhN[/screenr:zkq34ycx]
        It's awesome. I'm testing, but my blocks fall into infinity (the boundary surface drops as well) πŸ˜• . I do not know how to make a surface to retain them. How I can fix it? Could you stop the simulation and save the drawing? Thank you! πŸ˜„
        • cottyC Offline
          cotty
          You need a static mesh (context menu).
          my SketchUp gallery
            Anton_S
            It states in the status text to use SHIFT key to lift objects.
            You can use ESC to quit and Break/Pause button to toggle play.
              josuapa
              Thanks a lot ! It's perfect !!!! 😍
              • PixeroP Offline
                Pixero
                Can it do soft bodies too?
                • soloS Offline
                  Can you explain this a little more detail?
                  Say I want to fill a bowl with marbles, how can that be done?
                  • jiminy-billy-bobJ Offline
                    jiminy-billy-bob
                    Select your bowl, in the context menu choose "static" in "state", and "coumpound from mesh" in "shape".
                      Anton_S
                      Newton 3.12 has that feature, but its unfinished. I might integrate it into MSPhysics when its finished.
                        Anton_S
                        Compound from mesh bodies are not recommended, as complex bodies could generate improper collisions. You might set a bowl static mesh, but make sure that the front faces are always facing out because the front faces are the only faces that generate the collisions, not the back faces.
                        • tt_suT Offline
                          tt_su
                          Like tribles? πŸ˜„
                          • PixeroP Offline
                            Pixero
                            @tt_su said:
                            Like tribles? πŸ˜„
                            You mean, like Trimbles? πŸ˜›
                            No, I mean like flags, cloth and such.
                              kaas
                              Tried a bowl like Solo suggested. Marbles are falling though the bowl. So tried some boxes. Had to scale everything x10 or the boxes would stick through the bowl. I guess I need to tweak some settings.
                              msPhysics_bowl.skp
                                Anton_S
                                Yeah, tiny objects are no good for newton. Another thing is I'll add the continuous collision mode feature, where objects won't fly through at fast speeds.
                                • O Offline
                                  otb designworks
                                  What are the chances of a mac version?
                                  Cheers, Chuck
                                  OTB Designworks is on Youtube
                                    Anton_S
                                    The chances of a Mac version is like the chances of snow here in Salem Oregon - 3% πŸ˜†
                                    As you noticed this plugin requires AMS Library which is fully dependent on the Windows API. The mac version will be created, but it will lack a lot of features from the Windows version.
                                    • O Offline
                                      otb designworks
                                      Too bad, but thanks for the explanation of why.
                                      Cheers, Chuck
                                      • tt_suT Offline
                                        tt_su
                                        What things do you need to do?
                                          Anton_S
                                          I got a whole list πŸ’š
                                          • tt_suT Offline
                                            tt_su
                                            Got a summary?
                                            • 46
                                            • 47
                                            • 2 / 47
