    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      josuapa
      @cotty said:
      Fist test VERY promising! πŸ‘ πŸŽ‰
      [screenr:zkq34ycx]yhhN[/screenr:zkq34ycx]
      It's awesome. I'm testing, but my blocks fall into infinity (the boundary surface drops as well) πŸ˜• . I do not know how to make a surface to retain them. How I can fix it? Could you stop the simulation and save the drawing? Thank you! πŸ˜„
      • cottyC
        cotty
        You need a static mesh (context menu).
        my SketchUp gallery
          Anton_S
          It states in the status text to use SHIFT key to lift objects.
          You can use ESC to quit and Break/Pause button to toggle play.
            josuapa
            Thanks a lot ! It's perfect !!!! 😍
            • PixeroP
              Pixero
              Can it do soft bodies too?
              • soloS
                Can you explain this a little more detail?
                Say I want to fill a bowl with marbles, how can that be done?
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  Select your bowl, in the context menu choose "static" in "state", and "coumpound from mesh" in "shape".
                    Anton_S
                    Newton 3.12 has that feature, but its unfinished. I might integrate it into MSPhysics when its finished.
                      Anton_S
                      Compound from mesh bodies are not recommended, as complex bodies could generate improper collisions. You might set a bowl static mesh, but make sure that the front faces are always facing out because the front faces are the only faces that generate the collisions, not the back faces.
                      • tt_suT
                        tt_su
                        Like tribles? πŸ˜„
                        • PixeroP
                          Pixero
                          @tt_su said:
                          Like tribles? πŸ˜„
                          You mean, like Trimbles? πŸ˜›
                          No, I mean like flags, cloth and such.
                          • K
                            kaas
                            Tried a bowl like Solo suggested. Marbles are falling though the bowl. So tried some boxes. Had to scale everything x10 or the boxes would stick through the bowl. I guess I need to tweak some settings.
                            msPhysics_bowl.skp
                              Anton_S
                              Yeah, tiny objects are no good for newton. Another thing is I'll add the continuous collision mode feature, where objects won't fly through at fast speeds.
                              • O
                                otb designworks
                                What are the chances of a mac version?
                                Cheers, Chuck
                                OTB Designworks is on Youtube
                                  Anton_S
                                  The chances of a Mac version is like the chances of snow here in Salem Oregon - 3% πŸ˜†
                                  As you noticed this plugin requires AMS Library which is fully dependent on the Windows API. The mac version will be created, but it will lack a lot of features from the Windows version.
                                  • O
                                    otb designworks
                                    Too bad, but thanks for the explanation of why.
                                    Cheers, Chuck
                                    • tt_suT
                                      tt_su
                                      What things do you need to do?
                                        Anton_S
                                        I got a whole list πŸ’š
                                        • tt_suT
                                          tt_su
                                          Got a summary?
                                            Anton_S
                                            @tt_su said:
                                            Got a summary?
                                            I'm working on joints right now... Everything else later.
                                            • 46
                                            • 47
                                            • 2 / 47
