    [Plugin] MoveAlong - v1.2b - 07 Jul 14
    71 Posts 26 Posters 71.2k Views 26 Watching
    • fredo6F Offline
      @rv1974 said:
      In short the 'move along' won't work with relatively heavy geometry.
      Could it get fixed?
      Thank you.
      I published a provisional fix for selection with big number of entities in MoveAlong 1.0d, published as part of FredoTools 1.8e.
      • fredo6F Offline
        @xianglin said:
        Hello Fredo
        Thank you for your plugin.
        I'm your biggest fan.
        For you to see a video, you might have some new ideas.
        Http://video.sina.com.cn/v/b/92151582-1801050914.html
        Looks like a super-powerful road editor; very well done!
        • KrisidiousK Offline
          Krisidious
          @xianglin said:
          Hello Fredo
          Wow, that's very kool... I'd love to have that in Sketchup.
          By: Kristoff Rand
          • FrederikF Offline
            Frederik
            That video takes forever to load for me, although I have a very fast Internet connection... 😕
            Cheers
            Kim Frederik
              Krisidious
              Fred, It's served from China (I think) and then it has to load 14 minutes of video. I think that's why it takes so long.
              By: Kristoff Rand
                rv1974
                Fredo, many thanks for 1.8e update, it's great improvement!
                Another nuance- those Acad-like grey phantom lines of the initial position, which give posibility to snap.
                I noticed that not grouped\componented geometry unfortunately doesn't give this feature;
                grey phantom lines represent the object's bounding boxes (pic.1). Couldn't they represent the true
                wireframe
                (pic.2)?
                Thank you.
                • fredo6F Offline
                  This is possible, but it would defeat performance, which I think is essential for a Move operation (remember your other request on big building!)).
                  What I can do is to display in wire the element picked inside the groups and components, say face, edge, ...)
                    rv1974
                    may be some sort of button or combo box in your ribbon toolbar that dis-\en-ables wireframe degradation?
                    • fredo6F Offline
                      @cotty said:
                      Shortcut 'M' updated!
                      A little observation:
                      The shadow is not updated until leaving the tool... (not really a problem)
                      [screenr:3rgydhdx]cFxN[/screenr:3rgydhdx]
                      At least you can tell that you move faster than your shadow!
                      PS: nothing I can do, I have no control over shadows and the Move api does not seem to take care of them interactively.
                        @Fredo
                        Wonderful tool.
                        Will we see it obey quad face convention in the future?
                        Enabling Thomthom's AutoSmooth while using MoveAlong has no effect.
                        • fredo6F Offline
                          Rich,
                          Good suggestion. It should go in the next release.
                          I use thomthom's conventions for quads
                          • smooth = soft = true
                            cast_shadows = false
                          PS: Apparently the Move api ( #transform_entities) behaves differently from the move tool regarding the creation / modification of entities. So it is more tricky.
                            rv1974
                            Fredo,
                            is it possible to replicate the Acad's Tracking (with numeric distance input) as shown on vid.1? And I can't figure out how do standard Move with Shift pressed (vid.2.) Is it supported in MoveAlong?
                            Another little thing: this strip of beige with current snapping info.. could it stay permanently (no popping-up)?
                            acad.swf
                            acad2.swf
                            • fredo6F Offline
                              @rv1974 said:
                              Fredo,
                              I cannot read the swf files. Could you display them or use another format.
                                To read a swf file just drag+drop it on your browser - it's a flash-movie and should then play...
                                @rv1974
                                You can constrain the native move/copy to align with the edge - hover over it and hold shift, then the movement is inference constrained along an extension of that edge, BUT any typed in the distance is taken from the picked point on the original object [along that vector].
                                You can of course use a premade guide-line offset the desired distance and snap to that using the inferred vector...
                                  rv1974
                                  http://screencast.com/t/7ii1K2G10nsi
                                  http://screencast.com/t/ZXLyKo6h
                                  Can you see them online?
                                    rv1974
                                    @TIG: Exactly, that's what I tried to illustrate with the 2nd vid. I just suggested to MoveAlong to support the Shift trick (with Acad's numeric input, if possible).
                                    • fredo6F Offline
                                      @TIG, @rv1974
                                      That's just remote inferencing (passive and active). It was planned and I am actually coding it. So should go in next release whenever I have time.
                                      • X Offline
                                        xianglin
                                        @fredo6 said:
                                        @TIG, @rv1974
                                        Hello fredo.
                                        DO you see the powerful road editor?
                                        If there is a person who can do such the powerful road editor in SkethcUp.I think only you.
                                        • fredo6F Offline
                                          @xianglin said:
                                          Hello fredo.
                                          Yes I did. This is quite a piece of work. And the main difficulty is to create the roads over a surface mesh.
                                          I think you should try to see if this tool can export the roads data format that can be re-imported into Sketchup. That would be the most efficient.
                                          • fredo6F Offline
                                            @rv1974 said:
                                            Fredo,
                                            Here is a preview of the remote inferencing feature. It allows to type the distance from the remote in the VCB.
                                            • 2 / 4
