    [REQ] un-select everything
    34 Posts 15 Posters 1.2k Views 15 Watching
    • gillesG Offline
      gilles
      @jeff hammond said:
      fwiw, on mac, esc doesn't clear a selection(s)..
      it's cmmd-A for select all & shift-cmmd-A for deselect all
      It does for me or maybe I've a fake Mac πŸ’š
      • jeff hammondJ Offline
        really? that's strange.
        do you use an english keyboard? or- i wonder what else may be the reason why ESC deselects for you and not me?
        • gillesG Offline
          gilles
          AZERTY, do you think this could make a difference?
          • KrisidiousK Offline
            Krisidious
            Esc does work and I use it often... But something to exit out of all groups and unselect everything back to the top of the model hierarchy would be nice.
            By: Kristoff Rand
            • gillesG Offline
              gilles
              It does not work with some tools when they are active.
              • massimoM Offline
                massimo Moderator
                This works like a charm.
                  Krisidious
                  Crap... another context menu item... I'm already having spanning issues on my context menu. Oh well, one more to add to the party. Thanks Massimo.
                  By: Kristoff Rand
                    not sure.. i guess a few more mac users would have to try it to see..
                    also, i wonder if everyone in the thread is talking about the same thing and i might of replied too quickly prior to fully understanding the question.
                    are we talking about exiting groups or un-selecting selected items? πŸ˜• i'll read back through the thread a little later.
                      Exiting editing mode from nested groups
                      • gillesG Offline
                        gilles
                        Both.
                        • pbacotP Offline
                          I just use the key command for exit group... But you mean altogether out of all nested groups?
                          I would also like a command to be able to click on an object and have it open that objects group immediately, no mater how nested.
                            driven
                            @jeff,
                            esc works on my iMac. but I have never used it...
                            I don't think it did on my mac book, so haven't tried it since...
                              DOD3R
                              Hi all,
                              I use ESC to exit components/groups i have no problem with that. I dont even need a function exit all, because its not that difficult to hit esc four times to exit from the nested group. And even i thing it helps me to be aware on witch layer in the nest am I.
                              But still sometimes I loose track of things and i would like some visual clue. I know there is outliner and it serves this purpose well. But it gets messy sometimes and for good orientation takes a lot of my screen space. I would like something illustrator has. see attachment.
                              what do you think?
                              T.
                                Sure if all components are named "Component"! πŸ’š
                                  Krisidious
                                  Have you been looking at my models again Pilou?
                                  By: Kristoff Rand
                                  • BoxB Offline
                                    Funny how people can be talking about the same thing and not notice.
                                    @bob james said:
                                    @jim said:
                                    Paste this into a file with the .rb extension in your plugins folder.
                                    > > UI.add_context_menu_handler {|menu|
                                    > >   menu.add_item("Close All Contexts") {
                                    > >     Sketchup.active_model.selection.clear
                                    > >     while (Sketchup.active_model.close_active); end
                                    Called it BackOut.rb, assigned a shortcut to it, added it to a key on my P.I. Engineering x-keys keyboard and now I can back out from within any group/component with one key. Sure beats pecking at the Escape key πŸ˜„
                                    Thank you very much πŸ‘
                                      It works for me on my Mac, too, Jeff.
                                        Too true. πŸ˜‰
                                        • Bob JamesB Offline
                                          Bob James
                                          massimo did notice.
                                          That's what led me to turn Jim's code into backout.rb
                                          BackOut.rb
                                          • soloS Offline
                                            massimo did notice.
                                            πŸ‘
                                            • 2 / 2
