    [REQ] un-select everything
    34 Posts 15 Posters 2.4k Views 15 Watching
    • KrisidiousK Offline
      Krisidious
      Crap... another context menu item... I'm already having spanning issues on my context menu. Oh well, one more to add to the party. Thanks Massimo.
      By: Kristoff Rand
      • jeff hammondJ Offline
        @gilles said:
        AZERTY, do you think this could make a difference?
        not sure.. i guess a few more mac users would have to try it to see..
        also, i wonder if everyone in the thread is talking about the same thing and i might of replied too quickly prior to fully understanding the question.
        are we talking about exiting groups or un-selecting selected items? πŸ˜• i'll read back through the thread a little later.
          Exiting editing mode from nested groups
          • gillesG Offline
            gilles
            Both.
            • pbacotP Offline
              I just use the key command for exit group... But you mean altogether out of all nested groups?
              I would also like a command to be able to click on an object and have it open that objects group immediately, no mater how nested.
                driven
                @jeff,
                esc works on my iMac. but I have never used it...
                I don't think it did on my mac book, so haven't tried it since...
                  DOD3R
                  Hi all,
                  I use ESC to exit components/groups i have no problem with that. I dont even need a function exit all, because its not that difficult to hit esc four times to exit from the nested group. And even i thing it helps me to be aware on witch layer in the nest am I.
                  But still sometimes I loose track of things and i would like some visual clue. I know there is outliner and it serves this purpose well. But it gets messy sometimes and for good orientation takes a lot of my screen space. I would like something illustrator has. see attachment.
                  what do you think?
                  T.
                    Sure if all components are named "Component"! πŸ’š
                      Krisidious
                      Have you been looking at my models again Pilou?
                      By: Kristoff Rand
                      • BoxB Offline
                        Funny how people can be talking about the same thing and not notice.
                        @bob james said:
                        @jim said:
                        Paste this into a file with the .rb extension in your plugins folder.
                        > > UI.add_context_menu_handler {|menu|
                        > >   menu.add_item("Close All Contexts") {
                        > >     Sketchup.active_model.selection.clear
                        > >     while (Sketchup.active_model.close_active); end
                        Called it BackOut.rb, assigned a shortcut to it, added it to a key on my P.I. Engineering x-keys keyboard and now I can back out from within any group/component with one key. Sure beats pecking at the Escape key πŸ˜„
                        Thank you very much πŸ‘
                          @jeff hammond said:
                          @gilles said:
                          It does for me or maybe I've a fake Mac πŸ’š
                          really? that's strange.
                          do you use an english keyboard? or- i wonder what else may be the reason why ESC deselects for you and not me?
                          It works for me on my Mac, too, Jeff.
                            Too true. πŸ˜‰
                            • Bob JamesB Offline
                              Bob James
                              massimo did notice.
                              @massimo said:
                              @krisidious said:
                              Esc does work and I use it often... But something to exit out of all groups and unselect everything back to the top of the model hierarchy would be nice.
                              This works like a charm.
                              That's what led me to turn Jim's code into backout.rb
                              BackOut.rb
                              • soloS Offline
                                massimo did notice.
                                πŸ‘
                                • bazB Offline
                                  baz
                                  Perhaps I am misunderstanding the issue but in the shortcuts menu there is an option for 'deselect all' This doesn't 'back out' like the escape key but does exactly what it says.
                                  I have it set as 'shift D'
                                  Baz
                                    Bob James
                                    That's the whole point of this discussion. Deselecting something buried within a component/group still leaves you inside the group/component. Backout deselects and brings the cursor all the way out of the group/component leaving you free to select something else in your model.
                                    By the way:,I can't find this:
                                    • bazB Offline
                                      baz
                                      I get you, 'Select None' only deselects within the group or component.
                                      Here Tis...
                                        Bob James
                                        Thanks:I was looking for 'deselect all'
                                        • bazB Offline
                                          baz
                                          my bad 😳
                                            @gilles said:
                                            Both.
                                            what if you aren't editing inside a group (raw geometry) and you have some items selected? will ESC deselect those items? i've tried it on a macpro and a mbp now and it works on neither. for that, i have to use the 'select none' shortcut.
                                            (though the way i usually do this when there is no blank space to click in is to select a new item which i can see then shift-select it in order to clear all selections.. just i bad habit i've developed over the years where i should probably be using the shift-cmmd-A shortcut)
                                            • 2 / 2
