    [REQ] un-select everything
    34 Posts 15 Posters 2.4k Views 15 Watching
      Exiting editing mode from nested groups
      • gillesG Offline
        gilles
        @jeff hammond said:
        @gilles said:
        AZERTY, do you think this could make a difference?
        not sure.. i guess a few more mac users would have to try it to see..
        also, i wonder if everyone in the thread is talking about the same thing and i might of replied too quickly prior to fully understanding the question.
        are we talking about exiting groups or un-selecting selected items? πŸ˜• i'll read back through the thread a little later.
        Both.
        • pbacotP Offline
          I just use the key command for exit group... But you mean altogether out of all nested groups?
          I would also like a command to be able to click on an object and have it open that objects group immediately, no mater how nested.
            driven
            @jeff,
            esc works on my iMac. but I have never used it...
            I don't think it did on my mac book, so haven't tried it since...
              DOD3R
              Hi all,
              I use ESC to exit components/groups i have no problem with that. I dont even need a function exit all, because its not that difficult to hit esc four times to exit from the nested group. And even i thing it helps me to be aware on witch layer in the nest am I.
              But still sometimes I loose track of things and i would like some visual clue. I know there is outliner and it serves this purpose well. But it gets messy sometimes and for good orientation takes a lot of my screen space. I would like something illustrator has. see attachment.
              what do you think?
              T.
                Sure if all components are named "Component"! πŸ’š
                • KrisidiousK Offline
                  Krisidious
                  Have you been looking at my models again Pilou?
                  By: Kristoff Rand
                  • BoxB Offline
                    Funny how people can be talking about the same thing and not notice.
                    @bob james said:
                    @jim said:
                    Paste this into a file with the .rb extension in your plugins folder.
                    > > UI.add_context_menu_handler {|menu|
                    > >   menu.add_item("Close All Contexts") {
                    > >     Sketchup.active_model.selection.clear
                    > >     while (Sketchup.active_model.close_active); end
                    Called it BackOut.rb, assigned a shortcut to it, added it to a key on my P.I. Engineering x-keys keyboard and now I can back out from within any group/component with one key. Sure beats pecking at the Escape key πŸ˜„
                    Thank you very much πŸ‘
                      @jeff hammond said:
                      @gilles said:
                      It does for me or maybe I've a fake Mac πŸ’š
                      really? that's strange.
                      do you use an english keyboard? or- i wonder what else may be the reason why ESC deselects for you and not me?
                      It works for me on my Mac, too, Jeff.
                        Too true. πŸ˜‰
                        • Bob JamesB Offline
                          Bob James
                          massimo did notice.
                          @massimo said:
                          @krisidious said:
                          Esc does work and I use it often... But something to exit out of all groups and unselect everything back to the top of the model hierarchy would be nice.
                          This works like a charm.
                          That's what led me to turn Jim's code into backout.rb
                          BackOut.rb
                          • soloS Offline
                            massimo did notice.
                            πŸ‘
                            • bazB Offline
                              baz
                              Perhaps I am misunderstanding the issue but in the shortcuts menu there is an option for 'deselect all' This doesn't 'back out' like the escape key but does exactly what it says.
                              I have it set as 'shift D'
                              Baz
                                Bob James
                                That's the whole point of this discussion. Deselecting something buried within a component/group still leaves you inside the group/component. Backout deselects and brings the cursor all the way out of the group/component leaving you free to select something else in your model.
                                By the way:,I can't find this:
                                • bazB Offline
                                  baz
                                  I get you, 'Select None' only deselects within the group or component.
                                  Here Tis...
                                    Bob James
                                    Thanks:I was looking for 'deselect all'
                                    • bazB Offline
                                      baz
                                      my bad 😳
                                      • jeff hammondJ Offline
                                        @gilles said:
                                        Both.
                                        what if you aren't editing inside a group (raw geometry) and you have some items selected? will ESC deselect those items? i've tried it on a macpro and a mbp now and it works on neither. for that, i have to use the 'select none' shortcut.
                                        (though the way i usually do this when there is no blank space to click in is to select a new item which i can see then shift-select it in order to clear all selections.. just i bad habit i've developed over the years where i should probably be using the shift-cmmd-A shortcut)
                                        • gillesG Offline
                                          gilles
                                          @jeff hammond said:
                                          @gilles said:
                                          Both.
                                          Yes this works, I' running Mountain lion Mac book pro SU V8.
                                          As I said before ESC does not deselect with some tools when they are active.
                                            well.. that's just strange (tried it in su8 too on lion and mavericks-- with various active tools).. i'm sure there's a reason behind the differing behaviors on our computers but i guess it's not important enough to figure out.
                                            fwiw, i do use the ESC key often in sketchup but i use it as a cancel button while drawing (for instance, i use the line tool if i need to measure something but i ESC once i see the dimension in the measurement box.. or if i misplace the beginning click of a tool etc..)
                                            • 2 / 2
