    [PLUGIN]MITSUBA Render Exporter v1.5.0(20141109)
    102 Posts 18 Posters 197.7k Views 18 Watching
      slbaumgartner
      Here are the folders and contents after importing the dae. As John reported, the textures folder exists but is empty, as is the output folder.
      steves-macbook:su_render steve$ ls -lR ./*
      -rw-r--r-- 1 steve admin 6673 Mar 17 21:23 ./Mitsuba_geometries.xml
      -rw-r--r-- 1 steve admin 1365 Mar 17 21:23 ./Mitsuba_scene.xml
      -rw-r--r-- 1 steve admin 5867 Mar 17 21:23 ./mitsuba_geom.txt
      -rw-r--r-- 1 steve admin 30488 Mar 17 21:23 ./mitsuba_main.dae
      -rw-r--r-- 1 steve admin 903109 Mar 18 09:04 ./mitsuba_main.exr
      -rw-r--r-- 1 steve admin 3582 Mar 18 08:55 ./mitsuba_main.serialized
      -rw-r--r-- 1 steve admin 1620 Mar 18 08:55 ./mitsuba_main.xml
      ./output:
      ./preview_cash:
      total 80
      -rw-r--r-- 1 steve admin 39202 Mar 17 17:31 su2objmtl_default_material.png
      ./textures:
      ./tx_default:
      total 8
      -rw-r--r-- 1 steve admin 3645 Mar 17 21:23 dark_mahogany.jpg
        driven
        the other thing I tried was exporting a dae directly from SU...
        filesize 202 KB
        texture folder empty
        serialised 11 KB
        Sophie is facedown on the ground [I don't think she's partially happy about it...]
        she ain't happy...
          driven
          here are all the files for both...
          this is after the Misuba.app import so it has a textures folder...
          still empty after untitled was run...
          su_render.zip
            tak2hata
            Here is the Flow of exporting to mitsuba in my plugin.
            1.Create collada mesh without materials and transformation.(for instancing)
            2.Convert the collada mesh to serialized mesh by mtsimport tool.
            3.Export scene information iclude materials and instancing and transformation for serialized mesh.
            Please open "mitsuba_scene.xml" in mitsuba render ,if there is correct serialized mesh "mitsuba_main.serialized" created from "mitsuba_main.dae".
            That will be shown all correctly.
            Mtsimport work fine?
            Collada file created fine?
            Seriarize file is not zero byte?
            by TAK2HATA
              driven
              I can trap the create_directory error by appending at line 269 in mitsuba_main.rb
              the serialisation never occurs from the plugin...
              system(commandline, ;out => ['/tmp/log.txt', 'a'], ;err => ['/tmp/log.txt', 'a'])
                tak2hata
                In my mac that occurs.
                Here is log.txt.
                2014-03-18 23;21;32.391 mtsimport[308;507] ApplePersistenceIgnoreState; Existing state will not be touched. New state will be written to /var/folders/v2/nc5st2054wvghywgtfrszpf00000gn/T/org.mitsuba.Mitsuba.savedState
                2014-03-18 23;21;32 INFO  main [converter.cpp;137] Beginning conversion ..
                2014-03-18 23;21;32 INFO  main [collada.cpp;1596] Loading "mitsuba_main.dae" ..
                2014-03-18 23;21;32 INFO  main [collada.cpp;1642] Importing materials ..
                2014-03-18 23;21;32 INFO  main [collada.cpp;1669] Importing scene ..
                2014-03-18 23;21;32 WARN  main [collada.cpp;1288] instance_geometry does not contain a <bind_material> element!
                2014-03-18 23;21;32 WARN  main [collada.cpp;615] Referenced material could not be found, substituting a diffuse BRDF.
                2014-03-18 23;21;32 INFO  main [collada.cpp;1680] Done, took 0.0s
                2014-03-18 23;21;32 INFO  main [mtsimport.cpp;156] Encountered 14 warnings -- please check the messages above for details.
                Finished conversion (took 60 ms)
                In Sketchup Ruby Console
                system(%Q{'/Applications/Mitsuba.app/Contents/MacOS/mtsimport' '/Applications/su_render/mitsuba_main.dae' '/Applications/su_render/mitsuba_main.xml'})
                this return False?
                by TAK2HATA
                  driven
                  Here is my log.txt. after 2 attempts
                  2014-03-18 13;58;36 INFO  main [converter.cpp;127] Creating directory "textures" ..
                  Caught a critical exception; boost;;filesystem;;create_directory; Permission denied; "textures"
                  2014-03-18 14;22;09 INFO  main [converter.cpp;127] Creating directory "textures" ..
                  this return False?
                  YES it returns false
                  and if you use this version, you get the same error as the log file in Ruby Console...
                  %x(/Applications/Mitsuba.app/Contents/MacOS/mtsimport /Applications/su_render/mitsuba_main.dae /Applications/su_render/mitsuba_main.xml 2>&1)
                  2014-03-18 14:42:03 INFO main [converter.cpp:127] Creating directory "textures" .. Caught a critical exception: boost::filesystem::create_directory: Permission denied: "textures"
                    tak2hata
                    I get this return.
                    2014-03-18 23;58;34.268 mtsimport[472;507] ApplePersistenceIgnoreState; Existing state will not be touched. New state will be written to /var/folders/v2/nc5st2054wvghywgtfrszpf00000gn/T/org.mitsuba.Mitsuba.savedState
                    2014-03-18 23;58;34 INFO  main [converter.cpp;137] Beginning conversion ..
                    2014-03-18 23;58;34 INFO  main [collada.cpp;1596] Loading "mitsuba_main.dae" ..
                    2014-03-18 23;58;34 INFO  main [collada.cpp;1642] Importing materials ..
                    2014-03-18 23;58;34 INFO  main [collada.cpp;1669] Importing scene ..
                    2014-03-18 23;58;34 WARN  main [collada.cpp;1288] instance_geometry does not contain a <bind_material> element!
                    2014-03-18 23;58;34 WARN  main [collada.cpp;615] Referenced material could not be found, substituting a diffuse BRDF.
                    2014-03-18 23;58;34 INFO  main [collada.cpp;1680] Done, took 0.0s
                    2014-03-18 23;58;34 INFO  main [mtsimport.cpp;156] Encountered 16 warnings -- please check the messages above for details.
                    Finished conversion (took 42 ms)
                    Is this problem security permission?
                    by TAK2HATA
                      driven
                      the problem seems to be the path from boost to the file not having the correct permissions, if that makes sense...
                      As the folder is in the HD/Applications/ I have tried it at /tmp/, ~/Desktop, ~/Documents and in Plugins, all fail...
                      my copy of boost lives in /usr/local/bin/include, but it's a symlink to homebrew/cellar so that my be the issue...
                      not following symlink from ruby, I'll check it again from terminal...
                        driven
                        that returns
                        dyld; Symbol not found; __cg_jpeg_resync_to_restart
                          Referenced from; /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                          Expected in; /usr/local/lib/libJPEG.dylib
                         in /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                        Trace/BPT trap; 5
                          tak2hata
                          @driven said:
                          that returns
                          > Trace/BPT trap; 5
                          Avoiding this problem,
                          I will write the code for serialized mesh exporter in ruby.
                          Thanks.
                          by TAK2HATA
                            driven
                            Good idea, it's probably the best long term solution...
                            you can PM me if you want anything tested...
                              driven
                              I just had a thought and did some tests...
                              commandline tool need to modify .bashrc to point to python...
                              I don't use a .bashrc file, i use .bashprofile, so I created one under User/me/.bashrc and it's not written to...
                              where is your .bashrc located, and exactly what does it contain??
                                tak2hata
                                I search in my mac.
                                I found "bashrc" in "/private/etc"
                                it contains this.
                                # System-wide .bashrc file for interactive bash(1) shells.
                                if [ -z "$PS1" ]; then
                                   return
                                fi
                                PS1='¥h;¥W ¥u¥$ '
                                # Make bash check its window size after a process completes
                                shopt -s checkwinsize
                                # Tell the terminal about the working directory at each prompt.
                                if [ "$TERM_PROGRAM" == "Apple_Terminal" ] && [ -z "$INSIDE_EMACS" ]; then
                                    update_terminal_cwd() {
                                        # Identify the directory using a "file;" scheme URL,
                                        # including the host name to disambiguate local vs.
                                        # remote connections. Percent-escape spaces.
                                	local SEARCH=' '
                                	local REPLACE='%20'
                                	local PWD_URL="file;//$HOSTNAME${PWD//$SEARCH/$REPLACE}"
                                	printf '¥e]7;%s¥a' "$PWD_URL"
                                    PROMPT_COMMAND="update_terminal_cwd; $PROMPT_COMMAND"
                                fi
                                by TAK2HATA
                                  driven
                                  thanks for that,
                                  I found a note in the 'Mitsuba' source repository that the .bashrc file was no longer written to, so their message-box needs updating.
                                  It does seem to be a simple path issue, that halts the process...
                                  I just can't find it.
                                  I have a separate instal of 'boost', so it may be a version/path conflict when Mitsuba calls it from shell...
                                  Mitsuba works with other .dae files when imported, and I have older scene files from a previous instal, that run after they are auto updated on loading...
                                  I'll remove my copy of boost and see if that makes a difference...
                                    driven
                                    hi
                                    got it working...
                                    will need tidying...
                                    line 264
                                    			commandline = %Q{cd /Applications && Mitsuba.app/Contents/MacOS/mtsimport #{objfile.gsub(/\\/,'/')} #{xmlfile.gsub(/\\/,'/')}}
                                    OSX 10.9.2 must be stricter about the context...
                                      tak2hata
                                      @driven said:
                                      hi
                                      got it working...
                                      line 264
                                      Hi,john.
                                      Thanks!!!
                                      I change that line.and I update this to v1.2.1.
                                      I am very Happy.
                                      Thank you very much!
                                      by TAK2HATA
                                        tak2hata
                                        @sadyo said:
                                        Mitsuba seem work fine on my Sketchup 2014-Windowc 8.1 64bit
                                        But,
                                        How to implementing the clipmap/2D object in Mitsuba ❓ ❓
                                        http://s1.postimg.org/jtfu9opfj/image.jpg
                                        it won't appear in Renderer
                                        Hi sadyo.
                                        This problem is still exists.
                                        if it is clip mapped material ,please use mask option in "OTHER" tab of material editor.
                                        But the Image object is not material.
                                        So it can not edit by material editor.
                                        Please explode it to face and material.
                                        The image object is no supported in this plugin ,yet
                                        It will support in future version.
                                        But clipping of Image object will not be supported.
                                        And other notice,mitsuba render can not read TIFF and PSD.
                                        by TAK2HATA
                                          driven
                                          downloaded v1.2.1 and notice you left the log code in...
                                          not sure if it breaks PC's
                                            tak2hata
                                            Sorry.
                                            Now I deleted that log option.and updated.
                                            Thanks john!
                                            by TAK2HATA
                                            • 2 / 6
