    1.5k Posts 470 Posters 3.3m Views 469 Watching
    • W Offline
      wisar
      Great tool but I am wondering if I can undo the rounded corners if I want to revisit a design and make some changes like pushing and pulling a face?
      Cheers,
      W
      • mitcorbM Offline
        mitcorb
        Hi:
        You can undo the rounded corners while in the same session, but you cannot undo the round corners tomorrow.
        If you were using Blender you could simply switch it off, because rounded corners would be a modifier "channel"(?).
        In Sketchup, do the rounding on a separate copy, group or unique component of the original geometry.
        You could then save these copies out of your working file if you wish.
          Lyubov
          Please, help me to delete plugin from SketchUp Pro 2013, after Setting plugin Fredo6_Round Corner i decieded to delete him from foulder plugins, but now after openning SketchUp I have every time notice about that I have to install this plugin...(YOU MUST INSTALL LIBFREDO6 VERSION 5.2 OR HIGHER TO RUN FREDO ROUND CORNER)... Thank you so much for helping!! 😒
          • mitcorbM Offline
            mitcorb
            Hi, Lyubov:
            Your question generates many questions.
            Please visit this thread and see if an answer is there:
            http://sketchucation.com/plugin/696-SketchUcationTools
            Fredo6's RoundCorner is a very reliable plugin and requires a helper file called Libfredo. In fact, most if not all of his tools utilize the helper file.
            See if the above helps and post back if you need further assistance.
            Someone is sure to respond.
            • frankflafyF Offline
              frankflafy
              is it compatible with su2014? im trying and still get error.
                Round Corner is indeed compatible with SU2014. What error do you get? Just saying you get an error is useless.
                Make sure you've installed the current version of Round Corner AND Libfredo6.
                  frankflafy
                  sorry i just copy paste old plugins to a new plugins folder. and i got screwed.
                  but it fixed. thanx community.
                    Frank, it has been posted all over Sketchucation that copying and pasting plugins from an older installation is not advised.
                      keramare
                      THANX again
                        Antonius43
                        Just do not understand, do I need to pay for this plugin to work? After following the instructions I cannot find the toolbar? What a waste!!!
                        • massimoM Offline
                          massimo Moderator
                          No.
                          What a waste!!!
                          Waste? this is a great and must have plugin and many people use it successfully.
                          Correct.
                            Maybe you wil be more lucky with this!
                            Now there is a sort of integration of it inside Join PusPushPull Interactive!
                              It is free to download, install and use [but of course you are free to donate to authors]...
                              If you have installed the Plugin properly [and how did you do that?]... then you might need to restart SketchUp and activate the it under Preferences > Extensions... and then activate its Toolbar...
                              Also having read the Plugin's installation instructions... you will be aware that you also need to have 'LibFredo' downloaded and installed to make this work [that's free too 😉 ]
                                synthkim1
                                Thank u so much,,,it's amazing
                                • Z Offline
                                  ZRaupp
                                  took me a few minutes to get it working, had to run Sketchup as administrator..
                                    Why? Where and how did you install the plugin?
                                    • Z Offline
                                      ZRaupp
                                      I installed plug-ins before i followed the steps and it works... .. ..
                                        Whatever works, I guess, but you didn't really answer the question.
                                        You shouldn't have to run SketchUp 2014 as administrator to get plugins to work unless you aren't installing them in the correct location.
                                        • Z Offline
                                          ZRaupp
                                          There is only one place to install plugins and its in the plugins folder ...
                                          • bsusalaB Offline
                                            bsusala
                                            Hi Fredo, folks, thanks for this very useful plugin.
                                            I am asking from a rendering perspective. And woodworking, where straight rectangular edges are very common.
                                            • would RC in a future version work on multiple groups selection? For a furniture piece with many parts, that would be a real time-saver.
                                            • would RC in a future version allow for native undo-ing (not SU's undo) Maybe even with some form of Ghost integration.
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 73
                                            • 74
                                            • 41 / 74
