    Building thickness
    24 Posts 9 Posters 1.7k Views 9 Watching
      Rudbeckia
      Shellify seems like it might do the opposite of what I want. The problem is a 3d printer wont print just a "shell" or just faces with no thickness
      If you you do the reverse faces with a smaller building does it make walls for you?
      • pbacotP Offline
        These are simple blocks. Shellify might do it Also you could scale the building making a smaller version inside. Reverse the faces. You will have to push in projections that still sit outside after scaling.
        How do you intend to print? Is the creation of walls just to make it empty inside (not visible in the end product?) the the second procedure above might work.
        Reading your second post-- if these can be solid material, then printing would fill the form you have shown.
          Rudbeckia
          Sorry I am probably not explaining very well.
          A 3d printer will not read just a face in SU even in the faces are closed, like a cube. It does not read the cube as a solid......at least thats what i have been told.
            kaas
            @rudbeckia said:
            ... Or is there a way for me to make them solid (so not void in middle like SU draws)
            Normally when 3d printing you are charged for the amount (cm3) of printing material you use. If you make everything massive solids it will cost you a lot.
            Making shells might be better. Just watch out the roof spans are not too large (ask the 3d printing service for their specs) or the material will need some kind of support structure to keep the roof in place.
              Rudbeckia
              The "shells" need walls though correct? Meaning they cant just be faces?
              Im wondering if there is a quick way to make walls from a bunch of buildings that are just faces.
              • pbacotP Offline
                [quote="Rudbeckia"]Shellify seems like it might do the opposite of what I want. The problem is a 3d printer wont print just a "shell" or just faces with no thickness
                What I describe would be making inside faces spaced in from the outside. You reverse the faces on this inside group so that the space "inside the walls" is then all back faces.
                I'll attach the model. The wall thickness in this scale method are not exact. You have to adjust to your liking after.
                I don't know of a fast way myself.
                bldg 2.skp
                  Rudbeckia
                  I see now what you are saying, so the bldg you attached would print on a 3d printer? Even though it is still faces not walls? Bc what you have done would be a lot faster than redrawing all the sides of the bldgs as walls
                  • pbacotP Offline
                    OK. As I understand, it will. I don't do 3d printing myself, but I have helped others with models to print, and it came out fine. SketchUp only has faces. However a properly made model will print when translated.
                    The point about the roof span should be considered you might end up adding some columns or other mass in the center to keep it from sinking in. Probably you should pushpull it thicker than I show too (roof and floor). A prototype model would help your printer tell you what is needed.
                      Rudbeckia
                      thanks for the help!
                        kaas
                        A quick addition to my earlier comment:
                        1. you could also just offset the floorplane and pushpull it up just below the rooflevel.
                        2. if you make a group of a closed object it will automatically turn into a solid. You can only 3d print solid objects
                        3. check the specs and material of your 3d printer. it will depend the minimall thickness of the walls and roof and if you need supporting structures for the roof.
                        4. check your units. If you want to 3d print the model at some scale, the model should be scaled accordingly.
                        • pbacotP Offline
                          No 1 is a good idea. Faster.
                          • cottyC Offline
                            cotty
                            It's depending on the printing technology. If it's powder based for example, you need escape holes for the powder inside... for some ideas of rules see here.
                            You need to follow the design rules for the specific printer that will be used! (wall thickness, holes, ...)
                            A quick way to add thickness to the walls in this case could be the JPP plugin from Fredo, and to make it into a solid component use Solidsolver from TIG...
                            [screenr:3mtb2nbb]YSUN[/screenr:3mtb2nbb]
                            my SketchUp gallery
                              @Cotty
                              How select the faces on this video ?
                              Does the background external faces of the 2 "little boxes" are selected?
                              Have you a screenshot of the JPP toolbar regulates?
                              • cottyC Offline
                                cotty
                                Does this screenshot help?
                                my SketchUp gallery
                                  No ๐Ÿ˜„
                                  Some explosion! ๐Ÿ˜ฎ
                                  no.skp
                                  • cottyC Offline
                                    cotty
                                    I've got the same problem with your geomtry...
                                    my SketchUp gallery
                                      I believe that your geometry works because your 2 little boxes are "penetrating" by the top inside the big one!
                                      Mine is just "pasted" without soaking even inside is effectively dug!
                                      So maybe Fred must improuve his JPP! ๐Ÿ˜„
                                      • tt_suT Offline
                                        tt_su
                                        I've not had that problem. When you have a closed volume, in SketchUp it will say "Solid" in Entity Into then it's good to go for 3d print.
                                        This was printed from a SketchUp model:
                                        https://lh3.googleusercontent.com/-8uzkqpEAPfA/T9sv_fQ9W1I/AAAAAAAABWs/p5dSGHFq2wQ/w716-h985-no/Peon.jpg
                                        https://plus.google.com/u/0/photos/103450081381233788032/albums/5754245713469640065
                                        I used iMaterialize's services.
                                          Poor pawn ! ๐Ÿ˜‰
                                            The simple definition of a manifold solid - one that will successfully 3d-print when exported to a compatible file format - is a collection of 'geometry', consisting of just faces and the edges bounding those faces [within a group or a component 'container'].
                                            Every edge must bound exactly two faces - no fewer and no more.
                                            So that precludes faceless edges, or edges around holes, forming flaps/shelves etc with therefore one face only, or edges bounding internal partition faces where they would have three or more faces, or edges shared by two otherwise seemingly solid objects - like cubes meeting along one edge - where that edge is shared by four faces.
                                            It also precludes nested groups/components and any other entities like text and dims.
                                            Although construction-lines and points [aka guides] within a collection do not compromise its solidity, these are best avoided when sending on for 3d-printing etc...
