    Mini-challenge
    328 Posts 26 Posters 34.2k Views 26 Watching
    • fredo6F Offline
      The last Fredo method (some simple indeed) without plug gives with apparently no problem of top tangency vertices
      Unfortunately, although the method is mathematically correct, it suffers from the lack of precision of Sketchup for rotation and parallelism of guides (even with circles of 512 segments).
      One way to check that is to split the right post and the board and check the intersectio. As shown in the video, it may not be clean in certain cases.
      So you need an extra step, with the Move tool, to adjust the intersection. You can do this step accurately because the SU Move tools inferences differently the intersection points (cross) and the endpoints (circular dot).
      Strangely, Ruby does not suffer this inaccuracy issue and gives a correct intersection, although the FredoScale Rotate script uses the same method (i.e. calculate the offset angle and substract it to the rotation angle).
      • fredo6F Offline
        This mini challenge gave me an interesting idea. Thanks Jeff.
        I will introduce an option in FredoScale for the tools using rotation, in particular the Free Rotate tool (but also Twist and Rotate in Box).
        Basically, after you define the plan of rotation and base direction, you will click an extra target point anywhere in the model. This target point, and actually the parallel to the base direction passing through this point will be used as inference guide instead of the base direction.
        As I did not want to make a separate tool, the convention is that when you click the point for the base direction, you release after 1 second (kind of long click). Then you'll have the opportunity to click the target point as a red cross (in the Fee Rotate tool, you can also toggle this function via Ctrl Alone).
        Indeed this is a plugin solution to the challenge, but I am not sure there is a pure geometrical solution with just the native standard SU Tools.
        If you wish to try in advance of releasing, just drop the file Lib6Protractor.rb attached to this post into the LIBFREDO6_Dir_44 folder.
        • fredo6F Offline
          For info, I just published the script updates for supporting the two problems featured in this mini challenge. See this post for detail and video.
          This comes in FredoScale, but you just need to download LibFredo6 4.5a.
          • utilerU Offline
            utiler
            You are a crazy man, Fredo!!!!!
            Just Curious...
              Yep! 😎
              Classieux! 👍
              And no problem in the Big Zoom! ☀
              1.3239127 Nurbs (height of brace cut vertically) Pilars are 1 * 1 * 10 , brace 1 * 1 * x : unity meter
              1.323913m SU
              http://forums.sketchucation.com/download/file.php?id=87799
                Charlie__V
                Bravo Fredo..............Bravo!
                Thanks lots,
                Charlie
                • jeff hammondJ Offline
                  2014 bump
                    @jeff hammond said:
                    2014 bump
                    why are you bumping this, Jeff?
                      because you can solve the challenge with su2014
                        Oh. By using the new Arc tool.
                          right. we finally have a way to natively get a rotated snap point.
                          next step, incorporate the same inferencing into the rotate tool 😉
                          (but just having it in the arc tool is fine by me.. I've been wishing for it since maybe 2004 😄 )
                            Charlie__V
                            @jeff hammond said:
                            Buzzinga! 😎
                            C
                            • Wo3DanW Offline
                              Wo3Dan
                              @jeff hammond said:
                              right. we finally have a way to natively get a rotated snap point. ...
                              Is it really that accurate? I can't get it to work. If I zoom in I can still see a new endpoint (second end of arc) not being on the edge inside a group I "rotated" to(=pulled the arc to.
                              • Wo3DanW Offline
                                Wo3Dan
                                @wo3dan said:
                                Is it really that accurate? I can't get it to work. If I zoom in I can still see a new endpoint (second end of arc) not being on the edge inside a group I "rotated" to(=pulled the arc to).
                                  as far as i can tell, it's completely accurate.. in this case, i tested it like this:
                                  click pic for larger
                                  ... then rotated the bottom board from the arc end point to the arc start point using the same center point..
                                  everything appears to line up perfectly for me..
                                  • pbacotP Offline
                                    I am surprised because SU can't draw real arcs.
                                      the arcs are the same as before. it's just that you can now get a snap at an intersection while creating the arc.
                                      • Wo3DanW Offline
                                        Wo3Dan
                                        The arc tool hasn't changed at all, it still doen't snap to edges, only to endpoints (say A), intersections (say A)etc. To indicate that the arc ends on a (virtual) line from certer to A.
                                        The tool may indicate that you slide the cursor on an edge. But when zooming in, the resulting endpoint that the arc creates isn't on the edge that it is supposed to snap to. Unfortunately!
                                          the old arc tool hasn't changed. there's a new arc tool in 2014.. pick the center point first then the two end points.
                                          try using that one.
                                          there's a red X indicator when an intersection is made
                                          • Wo3DanW Offline
                                            Wo3Dan
                                            @jeff hammond said:
                                            .....the old arc tool hasn't changed. there's a new arc tool in 2014.. pick the center point first then the two end points.
                                            try using that one.
                                            I did use the new arc tool (center > start endpoint > end endpoint of the arc).
                                            Thing is I was trying to get an intersection on a grouped edge. That didn't give me any intersection ( red X ), only a sliding rectangular red dot. But on a basic edge I did. Thank you Jeff for pointing it out.
                                            Have you managed to get the intersection on an edge inside a group or component?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
