    Shade umbrella???
    28 Posts 9 Posters 3.5k Views 9 Watching
    • utilerU
      utiler
      So here's progress but not how I want the outcome...
      I thought I may have to create segments of the fabric and make them components seeing each side will be the same however when I do that I end up with hard edges where my shapes connect.
      Its really got me beat how you do this. Maybe I should be creating it from the ground up rather than around the edges...?
      Shade.skp
      Just Curious...
      • pbacotP
        Screen Shot 2014-02-06 at 8.39.13 PM.pngIDK how to do this for the precise mathematics but you get a different shape if you have a curve at the bottom edge. Not sure this is what you are after.
        • jeff hammondJ
          a square perimeter with a rounded top and a drooping mesh using curviloft would be something like this:
          tent_su6.skp
          • gillesG
            gilles
            This how Ferrari deals with it, for info.
            • mitcorbM
              mitcorb
              Hi:
              I fiddled with this yesterday. I did it two ways. When I did the deed by sections, selecting each curve in sequence, and mirror copied the result, I noticed the mis-shapened circular opening. When I selected everything and then activated the tool, I got a more regular opening. Segment count and size of segments in the curves do matter for more regular surfaces, as well as degree of curvature. My "good" result still had too much torsion/warpage in the finished surface. Did you see this too?
              • utilerU
                utiler
                @pbacot said:
                [attachment=0:2noo5rgt]<!-- ia0 -->Screen Shot 2014-02-06 at 8.39.13 PM.png<!-- ia0 -->[/attachment:2noo5rgt]IDK how to do this for the precise mathematics but you get a different shape if you have a curve at the bottom edge. Not sure this is what you are after.
                Thanks for giving it a go, mate! Normally I would expect the outer edge to be exactly how you've done it but the client wants to be able to fit drapes to the edges to close it in at times.... ๐Ÿ‘
                Just Curious...
                • utilerU
                  utiler
                  [attachment=1:2w6zx0be]<!-- ia1 -->tent_su6.skp<!-- ia1 -->[/attachment:2w6zx0be]
                  [attachment=0:2w6zx0be]<!-- ia0 -->tent.jpg<!-- ia0 -->[/attachment:2w6zx0be]
                  That's pretty much how I had attempted it also, Jeff however the 4 'hips' will actually be welded and stretched so they won't appear to have hard edges....
                  cheers for the input though! ๐Ÿ‘
                  Just Curious...
                  • utilerU
                    utiler
                    That's close, gillies although the surface on the outside of the apexes differ from the inner. seems 'warped to one side.
                    Getting close though! ๐ŸŽ‰ ๐ŸŽ‰
                    Just Curious...
                    • utilerU
                      utiler
                      @mitcorb said:
                      Hi:
                      Thanks Tim, what tool did you use?
                      Just Curious...
                      • BoxB
                        I'm not really sure about what shape it is you are after but this is Extrude edges by rails.
                        I don't know how you work white on white? sends me blind.
                        • jeff hammondJ
                          soften the edges after arraying. (or gap the array at the hips and fill in with an actual rounded surface)
                          the main point being- if you use that outwardly bulging edge of the top ring as part of a networked surface and the opposing edge is straight, the bulge is going to carry throughout the surface.. if you want the surface to sag in the middle, you'll have to do something like i showed (if using curviloft or any of the 2rail sweep plugins)..
                          maybe with soap skin& bubble you could get the sunken results as it has the pressure adjuster..
                          • mitcorbM
                            mitcorb
                            @utiler:
                            I used Curviloft by activating the "tent" icon.
                            • utilerU
                              utiler
                              So this is where it ended up at but still not convinced its the best result.
                              Just Curious...
                              • jeff hammondJ
                                hmm.. i'm not entirely sure what shape you're trying to get.. this latest version is different than the one you first described (or more likely- i misinterpreted before)
                                is this what you want? if so, it's easier to draw than the other one i showed.. i'll tell you how to do it if it's the right shape ๐Ÿ˜‰
                                tent2_v6.skp
                                • utilerU
                                  utiler
                                  I don't mind that, Jeff? ๐Ÿ‘
                                  Please tell me more....
                                  Just Curious...
                                    You could use Vertex Tools or even the Smoove tool
                                    • fredo6F
                                      If you do not have to respect strict profiles, you could give a try to
                                      1. Curviloft - Loft by Spline (with Bezier method 2 and play with the tension)
                                      1. TopoShaper, based on the square and ellipse
                                      In either case, you can refine and smooth better with the thomthom's Vertex Tools
                                      • jeff hammondJ
                                        Fredo just showed the way i did it ๐Ÿ˜„
                                        Loft by spline, bezier method 2, tension controls.
                                        • fredo6F
                                          Jeff, I should have though about that. Actually, you are probably the one who knows the most about Curviloft, more than I do (I really need to go back to this plugin and refresh it).
                                          @utiler: if you have a profile imposed, it may be better to use Curviloft - Loft along path, as shown in the video.
                                          Note that you must disable the "simplify" option, because it creates an artefact
                                          • utilerU
                                            utiler
                                            Never tried Vertex tools, Rich. Might have to give it a go.' ๐Ÿ‘
                                            Just Curious...
