    [Plugin] Super Drape
    192 Posts 54 Posters 370.1k Views 54 Watching
      The .rbz file for this plugin is available at the bottom of the first post in this thread. Download that and use Install Extension to install it. You should remove any files related to this plugin that you have tried to install, though.
      And make sure you have full admin rights before trying to install it.
      • BoxB Offline
        It's not the install extension section I was referring to. In the box above the install extension button you need to see super drape there and tick it's box.
          parsleybrain
          That just did the trick and it was the only place I didn't check a second time - so thank you very much!
          • gonashviliG Offline
            gonashvili
            Any vid/tuts about using this? Can't get this to work....
              Please be less cryptic.
              How isn't it working ?
              Is it installed OK ?
              Did you follow the guidance and image in the first post/download thread... ?
              Reiterated:
              You need two groups.
              The draper-group must be located above the receiving group.
              Its faces are replicated, projected onto the receiver's surfaces, maintaining the materials.
              Possible issues:
              The draper/receiver geometry contain tiny edges or facets that can't be intersected using SketchUp's methods, simply because of its tolerances [~1/1000"] - where the start & ends of a tiny line are deemed to occupy the same point in space and so the edge won't form, and then its related face can't form.
              Scale up both drape and scale-down - tiny edges can exist but cannot be created [this is the same issue with Sandbox-Drape]
              View the groups in Monochrome mode with a distinctive back-face material.
              If any 'backs' are facing up in either group you will get unexpected results.
              The edges might drape successfully, but then it seems like the draped materials are missing - they are not, they are just on the 'underside' [front] of the faces in the receiver. The materials on the draper's face-fronts will be used and of course this might not be the top-side you expected, if faces are wrongly oriented.
                gonashvili
                Think so, basic geometry (circle's,etc) worked OK, once it gets a bit more complex I get no respond (or a 'freeze').
                Here's a very simple shape made with the Uniform B-Spline, no idea what's wrong as it seems 'clean' enough ๐Ÿ˜ฒ
                01.skp
                • BoxB Offline
                  The problem with that one is that it is rotated. The small group's blue axis is running along the green axis, therefore it is "Draping" in the wrong direction. If you explode and regroup it it will work. Orientation is the key.
                  As a side note it's worth pointing out that you have drawn it outside and under the ground plane, not that this is causing your problem.
                    gonashvili
                    Thanks for the tip man!
                      sketchydog
                      I'm trying to get an effect where I'm draping roads, parking lots, etc. ONTO the imported google earth terrain. Super Drape and Drape both take the top group and "cut" it onto the TIN of the terrain. What I'm looking for is something that will drape the roads and so forth, onto the TIN below, but stay a completely separate group. In this way I can still control layers, etc.
                      Also, with Super Drape, I'm not getting the top donor materials to "take" in the google earth terrain. I get generic "white" skin where the new faces are cut.
                      I'd appreciate any comments or help. thanks!
                      • mitcorbM Offline
                        mitcorb
                        I tried to answer in your other post that I think you want the Stamp tool in the Sketchup Sandbox Tools. But I could be wrong.
                          @Sketchydog
                          Are your faces upside down ?
                          Either in the mesh or the 'road' your are trying to project 'down'...
                          Use a Style with a distinctly color back-face - say bright-blue or magenta.
                          Now view in Monochrome mode...
                          If you see that when it should be a front color you have some 'reversing' to do... ๐Ÿ˜’
                          • pep75P Offline
                            pep75
                            Is it true that Supderdrape doesn't work in 2014 when installing it with the PluginStore manager? I can't see it anywhere ๐Ÿ˜ž!
                            • pep75P Offline
                              pep75
                              ...I found it...you'll have to active the toolbar in the extensions-list in the preferences window. mmmm
                                It already worked in v2014... but FTAO I've relaunched it as v3.2 http://sketchucation.com/forums/viewtopic.php?p=358314#p358314
                                New version now in the PluginStore http://sketchucation.com/pluginstore?pln=SuperDrape
                                  kaas
                                  Could I ask for some help? I'm trying to drape a textured road on a terrain mesh. Using Super Drape the resulting mapping coordinates are messed up somehow.
                                  Already checked: units, regrouped both, edge inspector results in no errors, face normals are ok, removed smoothing and all edges are visible. I have no idea why it doesn't work.
                                  Any help would be appreciated.
                                  kind regards, Max
                                  superdrape2.skp
                                    @Max
                                    I confirm I get similar results.
                                    The UV-mapping of the upper faces' textures should be transferred to the facets in the draped version, with adjustments for their relative normal angles: but clearly this is not happening...
                                    I will investigate...
                                      kaas
                                      @tig said:
                                      @Max
                                      Great Tig! Just wondering, the terrain uses projected textures - cause of problem maybe?
                                        It may be a projected texture issue... ๐Ÿ˜•
                                        How did you apply/edit the textured 'yellow stripe' material on the 'flat' faces ?
                                        I found that if I added the material afresh and used Texture and/or My Texture Tools Plugin to adjust its rotation/position I could then get it to SuperDrape acceptably - see the first 6 facets in the screen-shot - I defaulted the next two facets to show the differences between my effort and your original ๐Ÿ˜•
                                          kaas
                                          I applied the texture using Fredo's ThruPaint. By doing so the mapping for the entire road is aligned to the curves of the road in just 2 mouse clicks.
                                          Tig, thanks for your time and effort. This method sounds a bit more time consuming. Will try as well.
                                            So maybe ThruPaint is messing with the UV-mapping in a way that SuperDrape can't unravel into a suitable way onto the surface?
                                            Can you use it to reverse engineer the problem after SuperDraping ?
                                            • 8 / 10
