    [Plugin] Super Drape
    192 Posts 54 Posters 380.2k Views 54 Watching
    • gonashviliG Offline
      gonashvili
      @tig said:
      How isn't it working ?
      Is it installed OK ?
      Think so, basic geometry (circle's,etc) worked OK, once it gets a bit more complex I get no respond (or a 'freeze').
      Here's a very simple shape made with the Uniform B-Spline, no idea what's wrong as it seems 'clean' enough 😲
      01.skp
      • BoxB Offline
        The problem with that one is that it is rotated. The small group's blue axis is running along the green axis, therefore it is "Draping" in the wrong direction. If you explode and regroup it it will work. Orientation is the key.
        As a side note it's worth pointing out that you have drawn it outside and under the ground plane, not that this is causing your problem.
          gonashvili
          Thanks for the tip man!
            sketchydog
            I'm trying to get an effect where I'm draping roads, parking lots, etc. ONTO the imported google earth terrain. Super Drape and Drape both take the top group and "cut" it onto the TIN of the terrain. What I'm looking for is something that will drape the roads and so forth, onto the TIN below, but stay a completely separate group. In this way I can still control layers, etc.
            Also, with Super Drape, I'm not getting the top donor materials to "take" in the google earth terrain. I get generic "white" skin where the new faces are cut.
            I'd appreciate any comments or help. thanks!
            • mitcorbM Offline
              mitcorb
              I tried to answer in your other post that I think you want the Stamp tool in the Sketchup Sandbox Tools. But I could be wrong.
                @Sketchydog
                Are your faces upside down ?
                Either in the mesh or the 'road' your are trying to project 'down'...
                Use a Style with a distinctly color back-face - say bright-blue or magenta.
                Now view in Monochrome mode...
                If you see that when it should be a front color you have some 'reversing' to do... πŸ˜’
                • pep75P Offline
                  pep75
                  Is it true that Supderdrape doesn't work in 2014 when installing it with the PluginStore manager? I can't see it anywhere 😞!
                  • pep75P Offline
                    pep75
                    ...I found it...you'll have to active the toolbar in the extensions-list in the preferences window. mmmm
                      It already worked in v2014... but FTAO I've relaunched it as v3.2 http://sketchucation.com/forums/viewtopic.php?p=358314#p358314
                      New version now in the PluginStore http://sketchucation.com/pluginstore?pln=SuperDrape
                        kaas
                        Could I ask for some help? I'm trying to drape a textured road on a terrain mesh. Using Super Drape the resulting mapping coordinates are messed up somehow.
                        Already checked: units, regrouped both, edge inspector results in no errors, face normals are ok, removed smoothing and all edges are visible. I have no idea why it doesn't work.
                        Any help would be appreciated.
                        kind regards, Max
                        superdrape2.skp
                          @Max
                          I confirm I get similar results.
                          The UV-mapping of the upper faces' textures should be transferred to the facets in the draped version, with adjustments for their relative normal angles: but clearly this is not happening...
                          I will investigate...
                            kaas
                            @tig said:
                            @Max
                            Great Tig! Just wondering, the terrain uses projected textures - cause of problem maybe?
                              It may be a projected texture issue... πŸ˜•
                              How did you apply/edit the textured 'yellow stripe' material on the 'flat' faces ?
                              I found that if I added the material afresh and used Texture and/or My Texture Tools Plugin to adjust its rotation/position I could then get it to SuperDrape acceptably - see the first 6 facets in the screen-shot - I defaulted the next two facets to show the differences between my effort and your original πŸ˜•
                                kaas
                                I applied the texture using Fredo's ThruPaint. By doing so the mapping for the entire road is aligned to the curves of the road in just 2 mouse clicks.
                                Tig, thanks for your time and effort. This method sounds a bit more time consuming. Will try as well.
                                  So maybe ThruPaint is messing with the UV-mapping in a way that SuperDrape can't unravel into a suitable way onto the surface?
                                  Can you use it to reverse engineer the problem after SuperDraping ?
                                    kaas
                                    The draping proces changed (divided) the mesh in such a way ThruPaint doesn't pick up any quads anymore so using that result in a mess. Trying to figure out some workarounds...
                                    edit: tried copying UV with UV toolkit but didn't work. I guess due to the difference in vertex count.
                                    edit2: exporting the original flat road as 3ds / dae reports: 80 different textures are being made. Importing that 3ds / dae results in 80 different materials for the road. One for each face. Strange..
                                    edit3: exporting the draped UV's to roadkill is no solution either. Even after welding it doesn't look good and individual points can't be moved.
                                      kaas
                                      Had another go at trying to find some workflow to get roads, rivers, ponds or any textured flat custom shape into a 3d terrain mesh (or actually into any 3d mesh - otherwise I could just as easily buy instantRoad).
                                      I tried copying the edges of a flattened version of the original terrain into the original textured flat road so the number of faces and edges would be the same as in the superdraped road. I hoped I could then use UVtoolkit2 to copy the uv coords of (3) into (2) but it didn't work at all (see result 4).
                                      I wanted to know if there's something strange happening with the UV coordinates so I had a go at ruby and google-searched-copy-pasted some code to investigate them:
                                      ss = Sketchup.active_model.selection
                                      @tw = Sketchup.create_texture_writer
                                      side = true
                                      hash = {}
                                      ss.each do |i|
                                      	next unless i.class == Sketchup;;Face
                                      	uv_helper = i.get_UVHelper(true, false, @tw)
                                          i.vertices.each{|v|
                                            p = v.position
                                            uv = (side)? uv_helper.get_front_UVQ(p) ; uv_helper.get_back_UVQ(p)
                                            uv.x /= uv.z; uv.y /= uv.z; uv.z = 1
                                            hash[v] = [] if !hash[v]
                                            hash[v] << uv
                                      	  puts ("ux=" + uv.x.to_s + "   uy=" + uv.y.to_s)
                                      I hoped for some really strange results but I'm no export on the UV coordinates so I have no idea what I'm looking for. What's strange though is that some faces have the same UV coords but still look different (see picture).
                                      I hope somebody has a clue what to do...
                                      superdrape2.skp
                                        Chimaera13
                                        This is hopelessly broken. I just keep getting a complaint that the group needs to be above the other group... and no matter how many ways I adjust things it just keeps doing that. Only once did it do anything else, and it wasn't draping. Just added a bunch of extra geometry that roughly corresponded the object I was trying to drape. WOrse, it breaks the ability to create grids.
                                        • BoxB Offline
                                          When a plugin like this is hopelessly broken it is usually down to user error.
                                          More infomation on what the problem is would help. Some images or the model to test.
                                          First thing that springs to my mind is you have your model orientated incorrectly, solid blue is up.
                                            Perhaps if you posted the SKP with it set up in the way you get a fail, then we'd be able to see better what was up.
                                            Also, do you have any Ruby Console output?
                                            It should never break anything else...
                                            Are you sure it is not something else that is breaking it?
                                            And what 'Grid' thing is 'broken' exactly?
                                            SuperDrape works when one group is placed over another and they are selected in the appropriate order...
                                            Are your axes visible?
                                            Are they set to the default??
                                            etc...
                                            Possible issues arise if either of the two groups have very tiny geometry - SketchUp's intersect fails to make edges < ~1/1000th"...
                                            Have you tried using The native Sandbox > Drape ?
                                            If so what happens ??
                                            I guess that it is either 'user error' or 'inappropriate geometry' πŸ˜’
                                            • 9 / 10
