    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 156.7k Views 85 Watching
      pgarmyn
      @caronte01 said:
      Hi Piet,
      Do you have a new version available? The current demo version expired yesterday....
      santiago
      Ok, it will be there in 2 or 3 hours
        pgarmyn
        UPDATED : VERSION 0.4.4 is in the PLUGINSTORE
          pgarmyn
          @bimbachi @diegob
          It must be a MAC related problem, you are both running on MAC ?
          Any other Mac users with problems ❓ ❓ ❓ ❓ ❓
          I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
          Can you test the following : disable all the other plugins ❓
          If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works ❓
          Thanks in advance.
          file deleted
            caronte01
            Thanks Piet!!!!
            Cheers
            Santiago
              bimbachi
              Did you abandoned mac problems?
                pgarmyn
                Caronte01 reported that the standard input box from the sketchup-API isn't working properly on mac.
                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=210#p524280
                Actually i don't have time to work on it.
                Did you find other problems?
                  caronte01
                  The new version looks great!
                  Thanks,
                  Santiago
                  • U Offline
                    unclex
                    great!!
                    work fine under 14
                    but under 13, it's disappeared...
                    last version under 13 was OK
                      pgarmyn
                      @unclex said:
                      great!!
                      work fine under 14
                      What do you mean by disappeared?
                      • U Offline
                        unclex
                        No icon in Toolbar under SU 2013, I called it disappear πŸ˜„
                        and no any command about richsection can be found when using Preference
                        https://copy.com/W7FI1VYHxdZA
                          pgarmyn
                          I will look this evening and update. Probably this evening (= within 14 hours)
                            pgarmyn
                            @unclex
                            Windows or Mac ? Please complete your user profile.
                            I've tested V0.4.4 on two computers, without any problem :
                            • Windows 7 / Sketchup 2013
                            • Windows 7 / Sketchup 2014
                            • Windows 8 / Sketchup 8
                            • Windows 8 / Sketchup 2013
                            • Windows 8 / Sketchup 2014
                            But I don't have a mac...
                            • U Offline
                              unclex
                              this one....
                              so no one else like me....
                                pgarmyn
                                this one....
                                Probably a conflict with another plugin.
                                See the first post....
                                • U Offline
                                  unclex
                                  Rick Wilson : Windowizer & Goldxxxx
                                  Artisan
                                  These I used under 2014 is OK
                                  so I think it should be something else make the "Disappear"
                                    pgarmyn
                                    Artisan
                                    It is probably Rich Wilson's Windowiser, see previous posts from micione and TIG: here.
                                    It is perfectly possible that the 'conflict' disappears with ruby 2.0 (SU 2014)
                                    For SU2013 (and older) : Try to desactivate one ore more plugins... and tell me ....
                                      c4rt00n3
                                      hi there
                                      I am using Sketchup Pro 2014 on a Mac.
                                      No projection lines appear. I have tried modifying all RichSection parameters but nothing changes...
                                      Any ideas?
                                        pgarmyn
                                        @c4rt00n3 said:
                                        hi there
                                        Any ideas?
                                        I can't test on Mac.
                                        Are there other Mac-people having this problem?
                                          c4rt00n3
                                          Thanks pgarmyn for your interest. Looks like no one else is!
                                          This is one useful plugin, and I wish I could pay for it so you could put resources behind developing it - for Mac too. Have you considered upgrading to a 'pro' paid version?
                                          C
                                          • EdsonE Offline
                                            Edson
                                            pgarmyn,
                                            this is a plugin with enormous potential. so much so that it deserves better documentation. your videos go a long way to show us how RichSection works but they go too fast. I know it is too much to ask but would you consider releasing a pdf describing all the features and a reasonable workflow?
                                            I, and am sure many others, would be willing to pay for a plugin like this if it can boost one's productivity. charging for it would perhaps encourage you to produce that documentation.
                                            I do hope you can get the mac version of it working. why do you not ask for help from other authors who have faced the same problem? the author of Layers Panel had similar problems and managed to fix them so that his excellent plugin is now running smoothly on mac.
                                            best regards.
                                            http://www.mahfuz.arq.br
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 19
                                            • 20
                                            • 13 / 20
