    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • C
      caronte01
      In your rs settings, section was off (the first item on the list). Also, some of the groups/components in your model were non solid.
      From my experience, rs works better with solids. I use tt's solid inspector a lot. RS works well with nested solids, and even with multi mesh solids (something native su solid tools has problems with).
      Things to avoid:
      Ungrouped geometry.
      Dividing lines on coplanar faces, except when they are used to separate different materials.
      Santiago
      0000.skp
      • KrisidiousK
        Krisidious
        Thanks for the help Santiago, I did have "Yes" selected when I created the section. as for the solids and such no.
        By: Kristoff Rand
        • C
          caronte01
          Hi Piet,
          Some screenshots of the dialog boxes, win vs. mac. I´ve highlighted in red the clipped text. I tried shortening some of those lines, but the dialog would resize, and clip other text. It also happens in the english translation...
          Config
          Settings
          Legend
          del
          • P
            pgarmyn
            Hi Santiago
            Good job ❗
            I will report this to the sketchup team and the community!
            See : http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57642%26amp;p=524309#p524309
            Thanks !
            • C
              caronte01
              Hi Piet,
              Three small things.
              Can default settings be saved, at least per session? I´m creating several rs on a model, I´m changing some of the settings from the default (rs profile lines to yes, so I can snap to the rs in layout, and projections to off) I have to do this every time I create an rs. Seems simple, but if I forget, and leave projections on, it takes forever to create an rs.
              It would be great to have esc abort the rs creation/update. Right now, the only way I´ve found is to either leave rs running, or force quit sketchup....
              In the settings dialog, move RSName to the top... Right now it is not easily found, down at the bottom.
              Cheers,
              Santiago
              • P
                pgarmyn
                Hi Santiago
                • about settings saved: i planned to propose the last used settings in creation, except name, section on/off and projection on/off, but i can limit the exception to the name...
                • escape : very usefull (was planned), but more difficult : Have to rewrite a lot. Will have to find the time.
                • name on the top : ok
                  Thanks for the suggestions
                • C
                  caronte01
                  • C
                    caronte01
                    Hi Piet,
                    Do you have a new version available? The current demo version expired yesterday....
                    santiago
                    • P
                      pgarmyn
                      @caronte01 said:
                      Hi Piet,
                      santiago
                      Ok, it will be there in 2 or 3 hours
                      • P
                        pgarmyn
                        UPDATED : VERSION 0.4.4 is in the PLUGINSTORE
                        • P
                          pgarmyn
                          @bimbachi @diegob
                          It must be a MAC related problem, you are both running on MAC ?
                          Any other Mac users with problems ❓ ❓ ❓ ❓ ❓
                          I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
                          Can you test the following : disable all the other plugins ❓
                          If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works ❓
                          Thanks in advance.
                          file deleted
                          • C
                            caronte01
                            Thanks Piet!!!!
                            Cheers
                            Santiago
                            • B
                              bimbachi
                              Did you abandoned mac problems?
                              • P
                                pgarmyn
                                Caronte01 reported that the standard input box from the sketchup-API isn't working properly on mac.
                                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=210#p524280
                                Actually i don't have time to work on it.
                                Did you find other problems?
                                • C
                                  caronte01
                                  The new version looks great!
                                  Thanks,
                                  Santiago
                                  • U
                                    unclex
                                    great!!
                                    work fine under 14
                                    but under 13, it's disappeared...
                                    last version under 13 was OK
                                    • P
                                      pgarmyn
                                      @unclex said:
                                      great!!
                                      work fine under 14
                                      What do you mean by disappeared?
                                      • U
                                        unclex
                                        No icon in Toolbar under SU 2013, I called it disappear 😄
                                        and no any command about richsection can be found when using Preference
                                        https://copy.com/W7FI1VYHxdZA
                                        • P
                                          pgarmyn
                                          I will look this evening and update. Probably this evening (= within 14 hours)
                                          • P
                                            pgarmyn
                                            @unclex
                                            Windows or Mac ? Please complete your user profile.
                                            I've tested V0.4.4 on two computers, without any problem :
                                            • Windows 7 / Sketchup 2013
                                            • Windows 7 / Sketchup 2014
                                            • Windows 8 / Sketchup 8
                                            • Windows 8 / Sketchup 2013
                                            • Windows 8 / Sketchup 2014
                                            But I don't have a mac...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 19
                                            • 20
                                            • 13 / 20
