    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 213.9k Views 85 Watching
      pgarmyn
      Hi Santiago
      • about settings saved: i planned to propose the last used settings in creation, except name, section on/off and projection on/off, but i can limit the exception to the name...
      • escape : very usefull (was planned), but more difficult : Have to rewrite a lot. Will have to find the time.
      • name on the top : ok
        Thanks for the suggestions
        caronte01
          caronte01
          Hi Piet,
          Do you have a new version available? The current demo version expired yesterday....
          santiago
            pgarmyn
            @caronte01 said:
            Hi Piet,
            santiago
            Ok, it will be there in 2 or 3 hours
              pgarmyn
              UPDATED : VERSION 0.4.4 is in the PLUGINSTORE
                pgarmyn
                @bimbachi @diegob
                It must be a MAC related problem, you are both running on MAC ?
                Any other Mac users with problems ❓ ❓ ❓ ❓ ❓
                I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
                Can you test the following : disable all the other plugins ❓
                If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works ❓
                Thanks in advance.
                file deleted
                  caronte01
                  Thanks Piet!!!!
                  Cheers
                  Santiago
                    bimbachi
                    Did you abandoned mac problems?
                      pgarmyn
                      Caronte01 reported that the standard input box from the sketchup-API isn't working properly on mac.
                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=210#p524280
                      Actually i don't have time to work on it.
                      Did you find other problems?
                        caronte01
                        The new version looks great!
                        Thanks,
                        Santiago
                        • U Offline
                          unclex
                          great!!
                          work fine under 14
                          but under 13, it's disappeared...
                          last version under 13 was OK
                            pgarmyn
                            @unclex said:
                            great!!
                            work fine under 14
                            What do you mean by disappeared?
                            • U Offline
                              unclex
                              No icon in Toolbar under SU 2013, I called it disappear 😄
                              and no any command about richsection can be found when using Preference
                              https://copy.com/W7FI1VYHxdZA
                                pgarmyn
                                I will look this evening and update. Probably this evening (= within 14 hours)
                                  pgarmyn
                                  @unclex
                                  Windows or Mac ? Please complete your user profile.
                                  I've tested V0.4.4 on two computers, without any problem :
                                  • Windows 7 / Sketchup 2013
                                  • Windows 7 / Sketchup 2014
                                  • Windows 8 / Sketchup 8
                                  • Windows 8 / Sketchup 2013
                                  • Windows 8 / Sketchup 2014
                                  But I don't have a mac...
                                  • U Offline
                                    unclex
                                    this one....
                                    so no one else like me....
                                      pgarmyn
                                      this one....
                                      Probably a conflict with another plugin.
                                      See the first post....
                                      • U Offline
                                        unclex
                                        Rick Wilson : Windowizer & Goldxxxx
                                        Artisan
                                        These I used under 2014 is OK
                                        so I think it should be something else make the "Disappear"
                                          pgarmyn
                                          Artisan
                                          It is probably Rich Wilson's Windowiser, see previous posts from micione and TIG: here.
                                          It is perfectly possible that the 'conflict' disappears with ruby 2.0 (SU 2014)
                                          For SU2013 (and older) : Try to desactivate one ore more plugins... and tell me ....
                                            c4rt00n3
                                            hi there
                                            I am using Sketchup Pro 2014 on a Mac.
                                            No projection lines appear. I have tried modifying all RichSection parameters but nothing changes...
                                            Any ideas?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 19
                                            • 20
                                            • 13 / 20
