    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • P
      pgarmyn
      @unclex said:
      No icon in Toolbar under SU 2013, I called it disappear 😄
      and no any command about richsection can be found when using Preference
      I will look this evening and update. Probably this evening (= within 14 hours)
      • P
        pgarmyn
        @unclex
        Windows or Mac ? Please complete your user profile.
        I've tested V0.4.4 on two computers, without any problem :
        • Windows 7 / Sketchup 2013
        • Windows 7 / Sketchup 2014
        • Windows 8 / Sketchup 8
        • Windows 8 / Sketchup 2013
        • Windows 8 / Sketchup 2014
        But I don't have a mac...
        • U
          unclex
          this one....
          so no one else like me....
          • P
            pgarmyn
            this one....
            Probably a conflict with another plugin.
            See the first post....
            • U
              unclex
              Rick Wilson : Windowizer & Goldxxxx
              Artisan
              These I used under 2014 is OK
              so I think it should be something else make the "Disappear"
              • P
                pgarmyn
                Artisan
                It is probably Rich Wilson's Windowiser, see previous posts from micione and TIG: here.
                It is perfectly possible that the 'conflict' disappears with ruby 2.0 (SU 2014)
                For SU2013 (and older) : Try to desactivate one ore more plugins... and tell me ....
                • C
                  c4rt00n3
                  hi there
                  I am using Sketchup Pro 2014 on a Mac.
                  No projection lines appear. I have tried modifying all RichSection parameters but nothing changes...
                  Any ideas?
                  • P
                    pgarmyn
                    @c4rt00n3 said:
                    hi there
                    Any ideas?
                    I can't test on Mac.
                    Are there other Mac-people having this problem?
                    • C
                      c4rt00n3
                      Thanks pgarmyn for your interest. Looks like no one else is!
                      This is one useful plugin, and I wish I could pay for it so you could put resources behind developing it - for Mac too. Have you considered upgrading to a 'pro' paid version?
                      C
                      • EdsonE
                        Edson
                        pgarmyn,
                        this is a plugin with enormous potential. so much so that it deserves better documentation. your videos go a long way to show us how RichSection works but they go too fast. I know it is too much to ask but would you consider releasing a pdf describing all the features and a reasonable workflow?
                        I, and am sure many others, would be willing to pay for a plugin like this if it can boost one's productivity. charging for it would perhaps encourage you to produce that documentation.
                        I do hope you can get the mac version of it working. why do you not ask for help from other authors who have faced the same problem? the author of Layers Panel had similar problems and managed to fix them so that his excellent plugin is now running smoothly on mac.
                        best regards.
                        http://www.mahfuz.arq.br
                        • P
                          pgarmyn
                          @edson
                          Thanks for the kind words
                          About documentation:
                          I planned to make very short 'how-to' videos. In my opinion, that is the best way to explain the basic steps of the workflow. And traduction is almost superfluous.
                          About Mac:
                          I got help from the mac community, but it is almost impossible to make regular updates without testing the new code parts in mac and windows. I dont have a mac. Maybee i should buy a cheap (paradox?) or a second-hand mac.
                          About charging:
                          I don't have much time outside my every-day job (architect, 98% execution, conception is only an exception), family, etc.
                          Charging wouldn't give me more free time to spent on ruby & SU.
                          So, be patient ❓
                          • EdsonE
                            Edson
                            @pgarmyn said:
                            @edson
                            About Mac:
                            About charging:
                            So, be patient ❓
                            thanks for your kind reply. believe it or not there is a cheap mac: the mac mini. it comes without screen, keyboard or mouse. you can just connect the ones you have.
                            I am patient. it is just that RichSection is so promising one wants to get it working right away. keep up the great work.
                            • EdsonE
                              Edson
                              what if you just created a pdf explaining each item in the dialog that opens when one creates a new RS? for people who do not have English as their first language the dialog is not self-explanatory.
                              to give you feedback: I installed RS in my mac smoothly but I cannot get it to fill the sections it produces. I am not sure if it is a problem or my lack of knowledge of how to use RS.
                              cheers.
                              • P
                                pgarmyn
                                @Edson
                                About PDF manual : I will do it, but first i will work on the mac version.
                                About. MAC : I don't think the last version is working on Mac. I bought a second-hand Mac just for serving my users !
                                I will make it work !
                                • U
                                  unclex
                                  Errors Under 2013
                                  Error Loading File E:/Trimble/SketchUp.2B/Plugins/PiGa_RichSection/RSloader.rb
                                  undefined method length' for false:FalseClass Error Loading File PiGa_RichSection.rb undefined method length' for false:FalseClass
                                  Errors Under 2014
                                  Error: #<NoMethodError: undefined method length' for false:FalseClass> c:/programdata/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:845:in statsSCFsend'
                                  c:/programdata/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:1060:in <module:PiGaRSection>' c:/programdata/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:99:in <main>'
                                  C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in eval' C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in require'
                                  C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in <module:PiGa>' C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:3:in <top (required)>'
                                  E:/Trimble/SketchUp.14/Tools/extensions.rb:197:in require' E:/Trimble/SketchUp.14/Tools/extensions.rb:197:in load'
                                  C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in register_extension' C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in module:PiGa'
                                  C:/ProgramData/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:17:in `<top (required)>'
                                  • U
                                    unclex
                                    under 2014
                                    change the 0.45 to another catalog
                                    Error: #<NoMethodError: undefined method length' for false:FalseClass> c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:845:in statsSCFsend'
                                    c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:1060:in <module:PiGaRSection>' c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:99:in <main>'
                                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in eval' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in require'
                                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in <module:PiGa>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:3:in <top (required)>'
                                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in module:PiGa'
                                    C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:17:in `<top (required)>'
                                    • P
                                      pgarmyn
                                      @unclex
                                      Still on windows ? Do you still have Windowiser active ? There are also other plugins having problems with it.
                                      Will have a look ....
                                      • U
                                        unclex
                                        yes, with windowlize
                                        but
                                        0.4.4 with windowlize under 2014, it's OK.......
                                        • P
                                          pgarmyn
                                          DOCUMENTATION (not yet complete)
                                          Update of the plugin tomorrow V0.4.6.....
                                          RichSection Documentation
                                          • P
                                            pgarmyn
                                            • bug fixes
                                            • statistics for analysis and development of the plugin : I will publish some …
                                            • DOCUMENTATION !!!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 19
                                            • 20
                                            • 13 / 20
