    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 213.9k Views 85 Watching
      caronte01
      Hi Piet,
      Some screenshots of the dialog boxes, win vs. mac. I´ve highlighted in red the clipped text. I tried shortening some of those lines, but the dialog would resize, and clip other text. It also happens in the english translation...
      Config
      Settings
      Legend
      del
        pgarmyn
        Hi Santiago
        Good job ❗
        I will report this to the sketchup team and the community!
        See : http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57642%26amp;p=524309#p524309
        Thanks !
          caronte01
          Hi Piet,
          Three small things.
          Can default settings be saved, at least per session? I´m creating several rs on a model, I´m changing some of the settings from the default (rs profile lines to yes, so I can snap to the rs in layout, and projections to off) I have to do this every time I create an rs. Seems simple, but if I forget, and leave projections on, it takes forever to create an rs.
          It would be great to have esc abort the rs creation/update. Right now, the only way I´ve found is to either leave rs running, or force quit sketchup....
          In the settings dialog, move RSName to the top... Right now it is not easily found, down at the bottom.
          Cheers,
          Santiago
            pgarmyn
            Hi Santiago
            • about settings saved: i planned to propose the last used settings in creation, except name, section on/off and projection on/off, but i can limit the exception to the name...
            • escape : very usefull (was planned), but more difficult : Have to rewrite a lot. Will have to find the time.
            • name on the top : ok
              Thanks for the suggestions
              caronte01
                caronte01
                Hi Piet,
                Do you have a new version available? The current demo version expired yesterday....
                santiago
                  pgarmyn
                  @caronte01 said:
                  Hi Piet,
                  santiago
                  Ok, it will be there in 2 or 3 hours
                    pgarmyn
                    UPDATED : VERSION 0.4.4 is in the PLUGINSTORE
                      pgarmyn
                      @bimbachi @diegob
                      It must be a MAC related problem, you are both running on MAC ?
                      Any other Mac users with problems ❓ ❓ ❓ ❓ ❓
                      I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
                      Can you test the following : disable all the other plugins ❓
                      If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works ❓
                      Thanks in advance.
                      file deleted
                        caronte01
                        Thanks Piet!!!!
                        Cheers
                        Santiago
                          bimbachi
                          Did you abandoned mac problems?
                            pgarmyn
                            Caronte01 reported that the standard input box from the sketchup-API isn't working properly on mac.
                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=210#p524280
                            Actually i don't have time to work on it.
                            Did you find other problems?
                              caronte01
                              The new version looks great!
                              Thanks,
                              Santiago
                              • U Offline
                                unclex
                                great!!
                                work fine under 14
                                but under 13, it's disappeared...
                                last version under 13 was OK
                                  pgarmyn
                                  @unclex said:
                                  great!!
                                  work fine under 14
                                  What do you mean by disappeared?
                                  • U Offline
                                    unclex
                                    No icon in Toolbar under SU 2013, I called it disappear 😄
                                    and no any command about richsection can be found when using Preference
                                    https://copy.com/W7FI1VYHxdZA
                                      pgarmyn
                                      I will look this evening and update. Probably this evening (= within 14 hours)
                                        pgarmyn
                                        @unclex
                                        Windows or Mac ? Please complete your user profile.
                                        I've tested V0.4.4 on two computers, without any problem :
                                        • Windows 7 / Sketchup 2013
                                        • Windows 7 / Sketchup 2014
                                        • Windows 8 / Sketchup 8
                                        • Windows 8 / Sketchup 2013
                                        • Windows 8 / Sketchup 2014
                                        But I don't have a mac...
                                        • U Offline
                                          unclex
                                          this one....
                                          so no one else like me....
                                            pgarmyn
                                            this one....
                                            Probably a conflict with another plugin.
                                            See the first post....
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 19
                                            • 20
                                            • 13 / 20
