    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • P
      pgarmyn
      Hi Santiago
      Good job ❗
      I will report this to the sketchup team and the community!
      See : http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57642%26amp;p=524309#p524309
      Thanks !
      • C
        caronte01
        Hi Piet,
        Three small things.
        Can default settings be saved, at least per session? I´m creating several rs on a model, I´m changing some of the settings from the default (rs profile lines to yes, so I can snap to the rs in layout, and projections to off) I have to do this every time I create an rs. Seems simple, but if I forget, and leave projections on, it takes forever to create an rs.
        It would be great to have esc abort the rs creation/update. Right now, the only way I´ve found is to either leave rs running, or force quit sketchup....
        In the settings dialog, move RSName to the top... Right now it is not easily found, down at the bottom.
        Cheers,
        Santiago
        • P
          pgarmyn
          Hi Santiago
          • about settings saved: i planned to propose the last used settings in creation, except name, section on/off and projection on/off, but i can limit the exception to the name...
          • escape : very usefull (was planned), but more difficult : Have to rewrite a lot. Will have to find the time.
          • name on the top : ok
            Thanks for the suggestions
          • C
            caronte01
            • C
              caronte01
              Hi Piet,
              Do you have a new version available? The current demo version expired yesterday....
              santiago
              • P
                pgarmyn
                @caronte01 said:
                Hi Piet,
                santiago
                Ok, it will be there in 2 or 3 hours
                • P
                  pgarmyn
                  UPDATED : VERSION 0.4.4 is in the PLUGINSTORE
                  • P
                    pgarmyn
                    @bimbachi @diegob
                    It must be a MAC related problem, you are both running on MAC ?
                    Any other Mac users with problems ❓ ❓ ❓ ❓ ❓
                    I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
                    Can you test the following : disable all the other plugins ❓
                    If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works ❓
                    Thanks in advance.
                    file deleted
                    • C
                      caronte01
                      Thanks Piet!!!!
                      Cheers
                      Santiago
                      • B
                        bimbachi
                        Did you abandoned mac problems?
                        • P
                          pgarmyn
                          Caronte01 reported that the standard input box from the sketchup-API isn't working properly on mac.
                          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=210#p524280
                          Actually i don't have time to work on it.
                          Did you find other problems?
                          • C
                            caronte01
                            The new version looks great!
                            Thanks,
                            Santiago
                            • U
                              unclex
                              great!!
                              work fine under 14
                              but under 13, it's disappeared...
                              last version under 13 was OK
                              • P
                                pgarmyn
                                @unclex said:
                                great!!
                                work fine under 14
                                What do you mean by disappeared?
                                • U
                                  unclex
                                  No icon in Toolbar under SU 2013, I called it disappear 😄
                                  and no any command about richsection can be found when using Preference
                                  https://copy.com/W7FI1VYHxdZA
                                  • P
                                    pgarmyn
                                    I will look this evening and update. Probably this evening (= within 14 hours)
                                    • P
                                      pgarmyn
                                      @unclex
                                      Windows or Mac ? Please complete your user profile.
                                      I've tested V0.4.4 on two computers, without any problem :
                                      • Windows 7 / Sketchup 2013
                                      • Windows 7 / Sketchup 2014
                                      • Windows 8 / Sketchup 8
                                      • Windows 8 / Sketchup 2013
                                      • Windows 8 / Sketchup 2014
                                      But I don't have a mac...
                                      • U
                                        unclex
                                        this one....
                                        so no one else like me....
                                        • P
                                          pgarmyn
                                          this one....
                                          Probably a conflict with another plugin.
                                          See the first post....
                                          • U
                                            unclex
                                            Rick Wilson : Windowizer & Goldxxxx
                                            Artisan
                                            These I used under 2014 is OK
                                            so I think it should be something else make the "Disappear"
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 19
                                            • 20
                                            • 13 / 20
