    [Plugin] Selection Toys
    594 Posts 121 Posters 380.3k Views 121 Watching
      danielfagerberg
      Hi Thomas,
      I am so grateful for your work!
      Is there a way to select components that have been scaled?
      Select the components that have been scaled to a certain scale so that i later can "make unique"
      reason is, i have 1 component that i have scaled in 6 different scales and the copied all over the shop in hundreds...
      I cant really find the ones with the same scale....
      Using TIG's Descaler gives me hundreds of components... it sort of make the model a bit slow 😄
      Again thank you for your wonderful work!
      BTW, the bowler hat that i see both on you and TIG, is that a special Sketchucation feature? i will sure run down the street to get one in emotional support for you guys! 😄
      • tt_suT Offline
        tt_su
        Hi Danel.
        There is no function in Selection Toys that selects based on size I'm afraid.
        The hat spread across the forum after last Basecamp in 2012 😄
          danielfagerberg
          Ok, thank you!
          About the hat... im heading for the shop... will add a mustache as well 😄
          @tt_su said:
          Hi Danel.
          • gonashviliG Offline
            gonashvili
            So umm pardon my lack of 'research' into these toys, but is there a function to recall previous selection? Sort of an 'Undo' / 'Redo' in the selection's 'universe'..
            No? Sheeeet 😄
            Cause ummm.... I don't know like you guys, but there's a lot of Homer-style D'OH's goin on when I .... select stuff 😄
            • cottyC Offline
              cotty
              Not here, but there are others like Selection memory or Selection Manager...
              my SketchUp gallery
                gonashvili
                Ah, thank you very much!!
                  txusic
                  is there a version in .rb instead of .rbz..
                  i can´t find it to work on SU7 on an old PPC Mac
                  cheers
                  • massimoM Offline
                    massimo Moderator
                    cheers
                    Just rename the folder as .zip and then unzip it.
                    • tt_suT Offline
                      tt_su
                      Check out this article: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/#the-old-fashioned-manual-way
                        txusic
                        thanks ever so much!!!
                        oh my.. i´ve discarded so many other stuff i couldnt work what was going on.. cheers
                          There's already a native tool to do that.
                            would be awesome if you could add a "select all connected" command ..
                            As Dave mention that is a native function:
                            ...or you can triple click.
                              dedmin
                              Win 7 64 bit, SU 2014 Pro (latest update)
                              See the video.
                              Video_2014-06-07_080026.wmv
                                Any errors in the Ruby Console?
                                  dedmin
                                  Nope.
                                  selection_toys.7z
                                    All look at it when I get back from my vacation that starts now. I'll be gone for two week cycling - with little or no internet access.
                                      bruorlando
                                      Hi Thom,
                                      This script helps me so much in my everyday work I have no words to thank you enough.
                                      I'm writing, though, trying to solve a bug I just can't figured out where it came from. Although the script works for every type of selection, it no longer runs for LINEAR DIMENSIONS. Not via the toolbar, nor contextual menu.
                                      I've tried reinstalling the plugin, updating the software (14.1.1283), but so far, that one remains "mute".
                                      Has anyone faced similar problem?
                                      Do you have any suggestions?
                                      Thanks in advance.
                                      Bruno
                                      • Dan RathbunD Offline
                                        Dan Rathbun
                                        The exposure of dimension objects changed in the Ruby API for SU2014.
                                        Do you have the latest version of of Selection Toys ?
                                        I'm not here much anymore.
                                          Ah, yes - new classes where introduced in SU2014. I'll have to fix that.
                                            Fix live on EW. Found a couple of other small bugs that I need to fix in another update. Will post that soon and make sure to update on PluginStore as well.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 25 / 30
