    [Plugin] Selection Toys
    594 Posts 121 Posters 587.6k Views 121 Watching
      Have you checked your Plugins folder Properties > Security > Edit = FULL for all listed users/groups ?
      The OS defaults will limit it settings - even for Admins...
      Messing on with reinstalls etc can screw things up...
      • renderizaR
        renderiza
        TIG you are right there is something wrong with my folder permission. I made new topic here to take this discussion there instead... http://sketchucation.com/forums/viewtopic.php?p=489984#p489984
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • Dan RathbunD
          Dan Rathbun
          FYI: On MS Windows, DO NOT assign a special (or custom) icon to the "Plugins" folder (or any of SketchUp's subfolders.) It causes folder permission errors.
          I'm not here much anymore.
          • renderizaR
            renderiza
            Already did without even wanting to I think. 😒
            Hope to find a way to undo it. πŸ˜•
            • Dan RathbunD
              Dan Rathbun
              Easy.
              1. Exit all SketchUp processes.
              2. Navigate to the SketchUp program folder.
              3. Rename the bad "Plugins" folder "Plugins_old" or whatever.
              4. Create a NEW folder named "Plugins"
              5. Copy the files and subfolders from the "old" folder.
              6. Delete the old folder.
              7. Restart SketchUp.
              • renderizaR
                renderiza
                Thanks Dan Rathbun!
                  danielfagerberg
                  Hi Thomas,
                  I am so grateful for your work!
                  Is there a way to select components that have been scaled?
                  Select the components that have been scaled to a certain scale so that i later can "make unique"
                  reason is, i have 1 component that i have scaled in 6 different scales and the copied all over the shop in hundreds...
                  I cant really find the ones with the same scale....
                  Using TIG's Descaler gives me hundreds of components... it sort of make the model a bit slow πŸ˜„
                  Again thank you for your wonderful work!
                  BTW, the bowler hat that i see both on you and TIG, is that a special Sketchucation feature? i will sure run down the street to get one in emotional support for you guys! πŸ˜„
                  • tt_suT
                    tt_su
                    Hi Danel.
                    There is no function in Selection Toys that selects based on size I'm afraid.
                    The hat spread across the forum after last Basecamp in 2012 πŸ˜„
                      danielfagerberg
                      Ok, thank you!
                      About the hat... im heading for the shop... will add a mustache as well πŸ˜„
                      @tt_su said:
                      Hi Danel.
                      • gonashviliG
                        gonashvili
                        So umm pardon my lack of 'research' into these toys, but is there a function to recall previous selection? Sort of an 'Undo' / 'Redo' in the selection's 'universe'..
                        No? Sheeeet πŸ˜„
                        Cause ummm.... I don't know like you guys, but there's a lot of Homer-style D'OH's goin on when I .... select stuff πŸ˜„
                        • cottyC
                          cotty
                          Not here, but there are others like Selection memory or Selection Manager...
                          my SketchUp gallery
                          • gonashviliG
                            gonashvili
                            Ah, thank you very much!!
                            • T
                              txusic
                              is there a version in .rb instead of .rbz..
                              i canΒ΄t find it to work on SU7 on an old PPC Mac
                              cheers
                              • massimoM
                                massimo Moderator
                                cheers
                                Just rename the folder as .zip and then unzip it.
                                • tt_suT
                                  tt_su
                                  Check out this article: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/#the-old-fashioned-manual-way
                                  • T
                                    txusic
                                    thanks ever so much!!!
                                    oh my.. iΒ΄ve discarded so many other stuff i couldnt work what was going on.. cheers
                                      There's already a native tool to do that.
                                        would be awesome if you could add a "select all connected" command ..
                                        As Dave mention that is a native function:
                                        ...or you can triple click.
                                          dedmin
                                          Win 7 64 bit, SU 2014 Pro (latest update)
                                          See the video.
                                          Video_2014-06-07_080026.wmv
                                            Any errors in the Ruby Console?
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 25 / 30
