    [Plugin] Selection Toys
    594 Posts 121 Posters 565.6k Views 121 Watching
    • tt_suT
      tt_su
      Hi Danel.
      There is no function in Selection Toys that selects based on size I'm afraid.
      The hat spread across the forum after last Basecamp in 2012 😄
        danielfagerberg
        Ok, thank you!
        About the hat... im heading for the shop... will add a mustache as well 😄
        @tt_su said:
        Hi Danel.
        • gonashviliG
          gonashvili
          So umm pardon my lack of 'research' into these toys, but is there a function to recall previous selection? Sort of an 'Undo' / 'Redo' in the selection's 'universe'..
          No? Sheeeet 😄
          Cause ummm.... I don't know like you guys, but there's a lot of Homer-style D'OH's goin on when I .... select stuff 😄
          • cottyC
            cotty
            Not here, but there are others like Selection memory or Selection Manager...
            my SketchUp gallery
            • gonashviliG
              gonashvili
              Ah, thank you very much!!
              • T
                txusic
                is there a version in .rb instead of .rbz..
                i can´t find it to work on SU7 on an old PPC Mac
                cheers
                • massimoM
                  massimo Moderator
                  cheers
                  Just rename the folder as .zip and then unzip it.
                  • tt_suT
                    tt_su
                    Check out this article: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/#the-old-fashioned-manual-way
                    • T
                      txusic
                      thanks ever so much!!!
                      oh my.. i´ve discarded so many other stuff i couldnt work what was going on.. cheers
                        There's already a native tool to do that.
                          would be awesome if you could add a "select all connected" command ..
                          As Dave mention that is a native function:
                          ...or you can triple click.
                            dedmin
                            Win 7 64 bit, SU 2014 Pro (latest update)
                            See the video.
                            Video_2014-06-07_080026.wmv
                              Any errors in the Ruby Console?
                                dedmin
                                Nope.
                                selection_toys.7z
                                  All look at it when I get back from my vacation that starts now. I'll be gone for two week cycling - with little or no internet access.
                                  • B
                                    bruorlando
                                    Hi Thom,
                                    This script helps me so much in my everyday work I have no words to thank you enough.
                                    I'm writing, though, trying to solve a bug I just can't figured out where it came from. Although the script works for every type of selection, it no longer runs for LINEAR DIMENSIONS. Not via the toolbar, nor contextual menu.
                                    I've tried reinstalling the plugin, updating the software (14.1.1283), but so far, that one remains "mute".
                                    Has anyone faced similar problem?
                                    Do you have any suggestions?
                                    Thanks in advance.
                                    Bruno
                                    • Dan RathbunD
                                      Dan Rathbun
                                      The exposure of dimension objects changed in the Ruby API for SU2014.
                                      Do you have the latest version of of Selection Toys ?
                                      I'm not here much anymore.
                                        Ah, yes - new classes where introduced in SU2014. I'll have to fix that.
                                          Fix live on EW. Found a couple of other small bugs that I need to fix in another update. Will post that soon and make sure to update on PluginStore as well.
                                          • plot-parisP
                                            plot-paris
                                            I have a selection question. I guess if any plugin can help me, it is this one. But I am not sure how. Maybe someone can help me.
                                            I have this model with many (non-quad) faces. And I would like to soften all the triangulation-edges so that I am left with seemingly quad faces.
                                            I guess the best way would be to soften everything, then select the edge loops and unsoften them. But I don't know how.
                                            Is it possible at all with this plugin?
                                            If yes, how?
                                            Any help would be appreciated.
                                            Cheers,
                                            Jakob
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 25 / 30
