    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 381.3k Views 57 Watching
    • K
      kein2006
      very nice plugin. It's really useful, thank you so much
      • fredo6F
        NEW RELEASE: Curvizard v1.4a - 15 Sep 13
        Curvizard 1.4a is a release with the following updates
        • New naming conventions
        • Fixes a major bug in the Edge Prop tool (which was not working)
        • Include an alternate icon toolbar by CadFather
        Curvizard 1.4 requires an upgrade to LibFredo6 5.2 or higher.
        • fredo6F
          @dedmin said:
          (screencast.com)
          I am not sure I see the problem.
          But in any case, Simplify is not the opposite of Smooth.
          Furthermore, Smooth can be used to simplify a curve by incresing the angle, whereas Simplify just remove vertices based on a minimum angle
          • fredo6F
            @dedmin said:
            [attachment=0:wmnznkk8]<!-- ia0 -->2013-08-25_055853.jpg<!-- ia0 -->[/attachment:wmnznkk8]
            Date; 25-Aug-13 05;57;22
            > An error occured in Curvizard#edge_prop
            > The operation is aborted
            The bug in Edge Prop tool should be fixed in Curvizard 1.4a.
            • guanjinG
              guanjin
              Thank you updates, always so timely! πŸ‘
                dedmin
                Excellent and invaluable tools!!!
                No problems so far!
                Thanks!!
                • utilerU
                  utiler
                  Thank you Fredo from all that use your tools!!!
                  Just Curious...
                    dedmin
                    Date; 16-Sep-13 19;59;36
                    An error occured in Curvizard#cleanup_curve
                    undefined method `[]' for nil;NilClass
                    Lib6G6.rb; 1249 -- vertices_from_edges_in_sequence
                    Lib6Contour.rb; 468 -- contour_reshaping
                    encoding.rb; 48 -- each_with_index
                    Lib6Contour.rb; 437 -- each
                    Lib6Contour.rb; 437 -- each_with_index
                    Lib6Contour.rb; 437 -- contour_reshaping
                    CurvizardAlgo.rb; 523 -- execute_geometry
                    CurvizardTool.rb; 1595 -- geometry_generate
                    CurvizardTool.rb; 1495 -- top_execute
                    CurvizardTool.rb; 290 -- handle_initial_selection
                    CurvizardTool.rb; 267 -- activate
                    CurvizardTool.rb; 46 -- select_tool
                    CurvizardTool.rb; 46 -- launch_tool
                    CurvizardTool.rb; 41 -- action__mapping
                    Lib6Plugin.rb; 134 -- call
                    Lib6Plugin.rb; 134 -- launch_action
                    bootstrap_Curvizard.rb; 51 -- launch_action
                    bootstrap_Curvizard.rb; 83 -- declare_command
                    Lib6Plugin.rb; 1111 -- call
                    Lib6Plugin.rb; 1111 -- build_config_handlers
                    FredoTools__ThruPaint.rb; 2315 -- call
                    • fredo6F
                      dedmin,
                      Would you mind to post or PM me the model.
                      This looks like a bug linked to the geometry.
                      • fredo6F
                        NEW RELEASE: Curvizard v1.5a - 27 Nov 13
                        Curvizard 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                        • sicksickisckS
                          sicksickisck
                          some bug in ver 1.5a ..crash skp9 when I use Curvizard inside the component.
                            What is skp9?
                            You have to give some useful details if you want help. Post the SketchUp model and describe exactly what you were trying to accomplish.
                            I just tried it and it works for me without crashing.
                            • sicksickisckS
                              sicksickisck
                              again crash! :kurwaa: when I want connect lines by Curvizard - v1.5a
                                That's as useless as your previous post as far as getting any help. πŸ˜’
                                  amis
                                  Nice interface improvement, Fredo! Thank you so much.
                                  • jeff hammondJ
                                    hey Fredo,
                                    I'm experiencing the problem of curves exploding upon welding another curve on the same object.. the attached .skp should allow you to see this in a repeatable manner (at least, the model shows the problem on both of my computers)
                                    MakeCurvesProblem.skp
                                    with nothing pre-selected, use the function 'Make Curves (weld)' with the following settings:
                                    ..click on one of the 3 border curves of the object.
                                    -exit tool.. the curve has been welded.
                                    -run the function again but use it on another edge.
                                    -exit tool.. this new edge is now a curve but the other one has now exploded.
                                    the .skp is saved as a v8 file but i'm using the plugin in a newer version of sketchup.. the Curvizard version i'm using is 1.5a with LibFredo 5.5g
                                    thanks
                                    • fredo6F
                                      Jeff,
                                      There seems to be several problems in this model
                                      • Curvizard (nor Curviloft) cannot select some of the edges in the bottom right corner
                                      • yes, curves are unwelded when you make a new one.
                                      I'll have a closer look and advise.
                                      Do you notice that on other models?
                                      • jeff hammondJ
                                        @fredo6 said:
                                        Jeff,
                                        thanks for looking into it.
                                        yes, i notice it on other models sometimes but it was this particular part of a drawing in which the behavior was very noticeable/repeatable..
                                        fwiw, the side profile edge came from a .3ds import via rhino and the surface was then made/revolved via TIG's lathe tool.. i'm not sure if that has anything to do with it.. i also mapped the surface with thruPaint but deleted the texture prior to uploading.. so the surface may still have some custom UV applied?
                                        [EDIT] i just tried drawing a similar model in sketchup only.. i still used TIGs lathe to revolve the surface but no texturing or imported curves were used.. same problem.
                                        • fredo6F
                                          Jeff,
                                          I identified and fixed all problems. This will go in a next release. Thanks for signaling (you were the first one).
                                          • jeff hammondJ
                                            @fredo6 said:
                                            Jeff,
                                            well, i just recently started trying curvizard as my all-situation weld tool.. previously i was using recurve in the situation presented here.. hence the late find πŸ˜‰
                                            • 6 / 10
