    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 375.1k Views 57 Watching
    • fredo6F Offline
      @dedmin said:
      [attachment=0:wmnznkk8]<!-- ia0 -->2013-08-25_055853.jpg<!-- ia0 -->[/attachment:wmnznkk8]
      Date; 25-Aug-13 05;57;22
      > An error occured in Curvizard#edge_prop
      > The operation is aborted
      The bug in Edge Prop tool should be fixed in Curvizard 1.4a.
      • guanjinG Offline
        guanjin
        Thank you updates, always so timely! πŸ‘
          dedmin
          Excellent and invaluable tools!!!
          No problems so far!
          Thanks!!
          • utilerU Offline
            utiler
            Thank you Fredo from all that use your tools!!!
            Just Curious...
              dedmin
              Date; 16-Sep-13 19;59;36
              An error occured in Curvizard#cleanup_curve
              undefined method `[]' for nil;NilClass
              Lib6G6.rb; 1249 -- vertices_from_edges_in_sequence
              Lib6Contour.rb; 468 -- contour_reshaping
              encoding.rb; 48 -- each_with_index
              Lib6Contour.rb; 437 -- each
              Lib6Contour.rb; 437 -- each_with_index
              Lib6Contour.rb; 437 -- contour_reshaping
              CurvizardAlgo.rb; 523 -- execute_geometry
              CurvizardTool.rb; 1595 -- geometry_generate
              CurvizardTool.rb; 1495 -- top_execute
              CurvizardTool.rb; 290 -- handle_initial_selection
              CurvizardTool.rb; 267 -- activate
              CurvizardTool.rb; 46 -- select_tool
              CurvizardTool.rb; 46 -- launch_tool
              CurvizardTool.rb; 41 -- action__mapping
              Lib6Plugin.rb; 134 -- call
              Lib6Plugin.rb; 134 -- launch_action
              bootstrap_Curvizard.rb; 51 -- launch_action
              bootstrap_Curvizard.rb; 83 -- declare_command
              Lib6Plugin.rb; 1111 -- call
              Lib6Plugin.rb; 1111 -- build_config_handlers
              FredoTools__ThruPaint.rb; 2315 -- call
              • fredo6F Offline
                dedmin,
                Would you mind to post or PM me the model.
                This looks like a bug linked to the geometry.
                • fredo6F Offline
                  NEW RELEASE: Curvizard v1.5a - 27 Nov 13
                  Curvizard 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                  • sicksickisckS Offline
                    sicksickisck
                    some bug in ver 1.5a ..crash skp9 when I use Curvizard inside the component.
                      What is skp9?
                      You have to give some useful details if you want help. Post the SketchUp model and describe exactly what you were trying to accomplish.
                      I just tried it and it works for me without crashing.
                        sicksickisck
                        again crash! :kurwaa: when I want connect lines by Curvizard - v1.5a
                          That's as useless as your previous post as far as getting any help. πŸ˜’
                            amis
                            Nice interface improvement, Fredo! Thank you so much.
                            • jeff hammondJ Offline
                              hey Fredo,
                              I'm experiencing the problem of curves exploding upon welding another curve on the same object.. the attached .skp should allow you to see this in a repeatable manner (at least, the model shows the problem on both of my computers)
                              MakeCurvesProblem.skp
                              with nothing pre-selected, use the function 'Make Curves (weld)' with the following settings:
                              ..click on one of the 3 border curves of the object.
                              -exit tool.. the curve has been welded.
                              -run the function again but use it on another edge.
                              -exit tool.. this new edge is now a curve but the other one has now exploded.
                              the .skp is saved as a v8 file but i'm using the plugin in a newer version of sketchup.. the Curvizard version i'm using is 1.5a with LibFredo 5.5g
                              thanks
                              • fredo6F Offline
                                Jeff,
                                There seems to be several problems in this model
                                • Curvizard (nor Curviloft) cannot select some of the edges in the bottom right corner
                                • yes, curves are unwelded when you make a new one.
                                I'll have a closer look and advise.
                                Do you notice that on other models?
                                  @fredo6 said:
                                  Jeff,
                                  thanks for looking into it.
                                  yes, i notice it on other models sometimes but it was this particular part of a drawing in which the behavior was very noticeable/repeatable..
                                  fwiw, the side profile edge came from a .3ds import via rhino and the surface was then made/revolved via TIG's lathe tool.. i'm not sure if that has anything to do with it.. i also mapped the surface with thruPaint but deleted the texture prior to uploading.. so the surface may still have some custom UV applied?
                                  [EDIT] i just tried drawing a similar model in sketchup only.. i still used TIGs lathe to revolve the surface but no texturing or imported curves were used.. same problem.
                                  • fredo6F Offline
                                    Jeff,
                                    I identified and fixed all problems. This will go in a next release. Thanks for signaling (you were the first one).
                                      @fredo6 said:
                                      Jeff,
                                      well, i just recently started trying curvizard as my all-situation weld tool.. previously i was using recurve in the situation presented here.. hence the late find πŸ˜‰
                                      • fredo6F Offline
                                        NEW RELEASE: Curvizard v1.6a - 03 Feb 14
                                        Curvizard 1.6a is a release for bug fixing in the Make Curve tool, as signaled by Jeff Hammond. It is advised to upgrade.
                                        Curvizard 1.6 requires to upgrade to LibFredo6 5.6a or higher.
                                        See main post of this thread for Download of Curvizard.
                                          sweet. that's working now.
                                          i did notice another peculiar behavior which occurs once lines have been welded but it's going to take me a bit of time to get the appropriate screenshots/description together.. and i don't have that much time right now.. if i don't get to it tonight, i'll post tomorrow
                                          thanks
                                          • fredo6F Offline
                                            In Sketchup, Curves have the strong constraint that they cannot cross each other, except at their extremities. So, if you apply a Make Curve to a model globally, you will likely get atomic curves (for instance, a cube will results in just its individual edges to become curves).
                                            Curvizard can do bulk Make Curve on the selection, including in Groups and Components. But it will work better, and as expected, on a set of contours, where there is no ambiguity on which edges to assemble as curves.
                                            • 6 / 10
