    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 386.9k Views 57 Watching
      dedmin
      Excellent and invaluable tools!!!
      No problems so far!
      Thanks!!
      • utilerU
        utiler
        Thank you Fredo from all that use your tools!!!
        Just Curious...
          dedmin
          Date; 16-Sep-13 19;59;36
          An error occured in Curvizard#cleanup_curve
          The operation is aborted
          undefined method `[]' for nil;NilClass
          Lib6G6.rb; 1249 -- vertices_from_edges_in_sequence
          Lib6Contour.rb; 468 -- contour_reshaping
          encoding.rb; 48 -- each_with_index
          Lib6Contour.rb; 437 -- each
          Lib6Contour.rb; 437 -- each_with_index
          Lib6Contour.rb; 437 -- contour_reshaping
          CurvizardAlgo.rb; 523 -- execute_geometry
          CurvizardTool.rb; 1595 -- geometry_generate
          CurvizardTool.rb; 1495 -- top_execute
          CurvizardTool.rb; 290 -- handle_initial_selection
          CurvizardTool.rb; 267 -- activate
          CurvizardTool.rb; 46 -- select_tool
          CurvizardTool.rb; 46 -- launch_tool
          CurvizardTool.rb; 41 -- action__mapping
          Lib6Plugin.rb; 134 -- call
          Lib6Plugin.rb; 134 -- launch_action
          bootstrap_Curvizard.rb; 51 -- launch_action
          bootstrap_Curvizard.rb; 83 -- declare_command
          Lib6Plugin.rb; 1111 -- call
          Lib6Plugin.rb; 1111 -- build_config_handlers
          FredoTools__ThruPaint.rb; 2315 -- call
          • fredo6F
            dedmin,
            Would you mind to post or PM me the model.
            This looks like a bug linked to the geometry.
            • fredo6F
              NEW RELEASE: Curvizard v1.5a - 27 Nov 13
              Curvizard 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
              • sicksickisckS
                sicksickisck
                some bug in ver 1.5a ..crash skp9 when I use Curvizard inside the component.
                  What is skp9?
                  You have to give some useful details if you want help. Post the SketchUp model and describe exactly what you were trying to accomplish.
                  I just tried it and it works for me without crashing.
                  • sicksickisckS
                    sicksickisck
                    again crash! :kurwaa: when I want connect lines by Curvizard - v1.5a
                      That's as useless as your previous post as far as getting any help. πŸ˜’
                        amis
                        Nice interface improvement, Fredo! Thank you so much.
                        • jeff hammondJ
                          hey Fredo,
                          I'm experiencing the problem of curves exploding upon welding another curve on the same object.. the attached .skp should allow you to see this in a repeatable manner (at least, the model shows the problem on both of my computers)
                          MakeCurvesProblem.skp
                          with nothing pre-selected, use the function 'Make Curves (weld)' with the following settings:
                          ..click on one of the 3 border curves of the object.
                          -exit tool.. the curve has been welded.
                          -run the function again but use it on another edge.
                          -exit tool.. this new edge is now a curve but the other one has now exploded.
                          the .skp is saved as a v8 file but i'm using the plugin in a newer version of sketchup.. the Curvizard version i'm using is 1.5a with LibFredo 5.5g
                          thanks
                          • fredo6F
                            Jeff,
                            There seems to be several problems in this model
                            • Curvizard (nor Curviloft) cannot select some of the edges in the bottom right corner
                            • yes, curves are unwelded when you make a new one.
                            I'll have a closer look and advise.
                            Do you notice that on other models?
                            • jeff hammondJ
                              @fredo6 said:
                              Jeff,
                              thanks for looking into it.
                              yes, i notice it on other models sometimes but it was this particular part of a drawing in which the behavior was very noticeable/repeatable..
                              fwiw, the side profile edge came from a .3ds import via rhino and the surface was then made/revolved via TIG's lathe tool.. i'm not sure if that has anything to do with it.. i also mapped the surface with thruPaint but deleted the texture prior to uploading.. so the surface may still have some custom UV applied?
                              [EDIT] i just tried drawing a similar model in sketchup only.. i still used TIGs lathe to revolve the surface but no texturing or imported curves were used.. same problem.
                              • fredo6F
                                Jeff,
                                I identified and fixed all problems. This will go in a next release. Thanks for signaling (you were the first one).
                                • jeff hammondJ
                                  @fredo6 said:
                                  Jeff,
                                  well, i just recently started trying curvizard as my all-situation weld tool.. previously i was using recurve in the situation presented here.. hence the late find πŸ˜‰
                                  • fredo6F
                                    NEW RELEASE: Curvizard v1.6a - 03 Feb 14
                                    Curvizard 1.6a is a release for bug fixing in the Make Curve tool, as signaled by Jeff Hammond. It is advised to upgrade.
                                    Curvizard 1.6 requires to upgrade to LibFredo6 5.6a or higher.
                                    See main post of this thread for Download of Curvizard.
                                    • jeff hammondJ
                                      sweet. that's working now.
                                      i did notice another peculiar behavior which occurs once lines have been welded but it's going to take me a bit of time to get the appropriate screenshots/description together.. and i don't have that much time right now.. if i don't get to it tonight, i'll post tomorrow
                                      thanks
                                      • fredo6F
                                        In Sketchup, Curves have the strong constraint that they cannot cross each other, except at their extremities. So, if you apply a Make Curve to a model globally, you will likely get atomic curves (for instance, a cube will results in just its individual edges to become curves).
                                        Curvizard can do bulk Make Curve on the selection, including in Groups and Components. But it will work better, and as expected, on a set of contours, where there is no ambiguity on which edges to assemble as curves.
                                        • fredo6F
                                          NEW RELEASE: Curvizard v1.7a - 15 Feb 14
                                          Curvizard 1.7a fixes a major bugwhich was present in v1.6a, whereby the vertex marks and tooltip for number of segments were no longer displayed. It is advised to upgrade to v1.7a.
                                          • fredo6F
                                            NEW RELEASE: Curvizard v1.7b - 16 Feb 14
                                            Curvizard 1.7b fixes a major bugwhich was present in v1.6a, whereby the vertex marks and tooltip for number of segments were no longer displayed. Then, a bug was introduced in v1.7a So, it is strongly advised to upgrade to v1.7b.
                                            • 6 / 10
