    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 381.3k Views 57 Watching
    • fredo6F
      @dedmin said:
      (screencast.com)
      I am not sure I see the problem.
      But in any case, Simplify is not the opposite of Smooth.
      Furthermore, Smooth can be used to simplify a curve by incresing the angle, whereas Simplify just remove vertices based on a minimum angle
      • fredo6F
        @dedmin said:
        [attachment=0:wmnznkk8]<!-- ia0 -->2013-08-25_055853.jpg<!-- ia0 -->[/attachment:wmnznkk8]
        Date; 25-Aug-13 05;57;22
        > An error occured in Curvizard#edge_prop
        > The operation is aborted
        The bug in Edge Prop tool should be fixed in Curvizard 1.4a.
        • guanjinG
          guanjin
          Thank you updates, always so timely! πŸ‘
            dedmin
            Excellent and invaluable tools!!!
            No problems so far!
            Thanks!!
            • utilerU
              utiler
              Thank you Fredo from all that use your tools!!!
              Just Curious...
                dedmin
                Date; 16-Sep-13 19;59;36
                An error occured in Curvizard#cleanup_curve
                undefined method `[]' for nil;NilClass
                Lib6G6.rb; 1249 -- vertices_from_edges_in_sequence
                Lib6Contour.rb; 468 -- contour_reshaping
                encoding.rb; 48 -- each_with_index
                Lib6Contour.rb; 437 -- each
                Lib6Contour.rb; 437 -- each_with_index
                Lib6Contour.rb; 437 -- contour_reshaping
                CurvizardAlgo.rb; 523 -- execute_geometry
                CurvizardTool.rb; 1595 -- geometry_generate
                CurvizardTool.rb; 1495 -- top_execute
                CurvizardTool.rb; 290 -- handle_initial_selection
                CurvizardTool.rb; 267 -- activate
                CurvizardTool.rb; 46 -- select_tool
                CurvizardTool.rb; 46 -- launch_tool
                CurvizardTool.rb; 41 -- action__mapping
                Lib6Plugin.rb; 134 -- call
                Lib6Plugin.rb; 134 -- launch_action
                bootstrap_Curvizard.rb; 51 -- launch_action
                bootstrap_Curvizard.rb; 83 -- declare_command
                Lib6Plugin.rb; 1111 -- call
                Lib6Plugin.rb; 1111 -- build_config_handlers
                FredoTools__ThruPaint.rb; 2315 -- call
                • fredo6F
                  dedmin,
                  Would you mind to post or PM me the model.
                  This looks like a bug linked to the geometry.
                  • fredo6F
                    NEW RELEASE: Curvizard v1.5a - 27 Nov 13
                    Curvizard 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                    • sicksickisckS
                      sicksickisck
                      some bug in ver 1.5a ..crash skp9 when I use Curvizard inside the component.
                        What is skp9?
                        You have to give some useful details if you want help. Post the SketchUp model and describe exactly what you were trying to accomplish.
                        I just tried it and it works for me without crashing.
                        • sicksickisckS
                          sicksickisck
                          again crash! :kurwaa: when I want connect lines by Curvizard - v1.5a
                            That's as useless as your previous post as far as getting any help. πŸ˜’
                              amis
                              Nice interface improvement, Fredo! Thank you so much.
                              • jeff hammondJ
                                hey Fredo,
                                I'm experiencing the problem of curves exploding upon welding another curve on the same object.. the attached .skp should allow you to see this in a repeatable manner (at least, the model shows the problem on both of my computers)
                                MakeCurvesProblem.skp
                                with nothing pre-selected, use the function 'Make Curves (weld)' with the following settings:
                                ..click on one of the 3 border curves of the object.
                                -exit tool.. the curve has been welded.
                                -run the function again but use it on another edge.
                                -exit tool.. this new edge is now a curve but the other one has now exploded.
                                the .skp is saved as a v8 file but i'm using the plugin in a newer version of sketchup.. the Curvizard version i'm using is 1.5a with LibFredo 5.5g
                                thanks
                                • fredo6F
                                  Jeff,
                                  There seems to be several problems in this model
                                  • Curvizard (nor Curviloft) cannot select some of the edges in the bottom right corner
                                  • yes, curves are unwelded when you make a new one.
                                  I'll have a closer look and advise.
                                  Do you notice that on other models?
                                  • jeff hammondJ
                                    @fredo6 said:
                                    Jeff,
                                    thanks for looking into it.
                                    yes, i notice it on other models sometimes but it was this particular part of a drawing in which the behavior was very noticeable/repeatable..
                                    fwiw, the side profile edge came from a .3ds import via rhino and the surface was then made/revolved via TIG's lathe tool.. i'm not sure if that has anything to do with it.. i also mapped the surface with thruPaint but deleted the texture prior to uploading.. so the surface may still have some custom UV applied?
                                    [EDIT] i just tried drawing a similar model in sketchup only.. i still used TIGs lathe to revolve the surface but no texturing or imported curves were used.. same problem.
                                    • fredo6F
                                      Jeff,
                                      I identified and fixed all problems. This will go in a next release. Thanks for signaling (you were the first one).
                                      • jeff hammondJ
                                        @fredo6 said:
                                        Jeff,
                                        well, i just recently started trying curvizard as my all-situation weld tool.. previously i was using recurve in the situation presented here.. hence the late find πŸ˜‰
                                        • fredo6F
                                          NEW RELEASE: Curvizard v1.6a - 03 Feb 14
                                          Curvizard 1.6a is a release for bug fixing in the Make Curve tool, as signaled by Jeff Hammond. It is advised to upgrade.
                                          Curvizard 1.6 requires to upgrade to LibFredo6 5.6a or higher.
                                          See main post of this thread for Download of Curvizard.
                                          • jeff hammondJ
                                            sweet. that's working now.
                                            i did notice another peculiar behavior which occurs once lines have been welded but it's going to take me a bit of time to get the appropriate screenshots/description together.. and i don't have that much time right now.. if i don't get to it tonight, i'll post tomorrow
                                            thanks
                                            • 6 / 10
