    [Extension][$] iSelect
    54 Posts 20 Posters 24.3k Views 20 Watching
      So That is Select only visible ? ☀
        samothrace41
        Thank you very much ! Very useful !
        • N Offline
          numerobis
          Very nice! 👍 Thank You! 😎
            chris87
            Very useful plugin !
            Thank you....
              glro
              nice idea
              it works perfectly for faces in the selection
              but it doesn't work for components in the selection
              for example:
              before
              When i clic on the eye button:
              after
              you can see that some components that were visible,have been excluded from the selection, and some others, which were not entirely visible, have been kept
              Would it be possible to fix that?
              • JClementsJ Offline
                JClements
                Nice job. For those that don't wish to use the toolbar, could there also be another version in which the context menu would display an option to execute the script?
                • renderizaR Offline
                  renderiza
                  Finished fixing the component & group situation and will start on adding the context menu next. Another plus to adding context menu is that it will show up on keyboard shortcut list. 😉
                  Thanks for feedback! 👍
                  [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                    renderiza
                    [pre:12acadvw]Authors:: Renderiza
                    Plugin Name:: iSelect
                    Version:: 1.0.1
                    Date:: 11/6/2013
                    Cost:: Free[/pre:12acadvw]
                    iSelect v1.0.1 is now available for download.
                    http://jroot.sketchucation.com/pluginrepo/image/RND_iSelect_v1.0.0.png
                    %(#909090)[What is new:
                    • Group & Component selection is fixed
                    • Context Menu Added (right click > iSelect)
                    • Add keyboard shortcut
                    How to set keyboard shortcut:
                    Window > Preference > Shortcuts > Function = Edit/Item/iSelect > Add Shortcut
                    Thanks for Feedback! 👍]
                      JClements
                      Thank you.
                      • erikBE Offline
                        erikB
                        Seems like a really, really!! useful tool.
                        But auto-install with sketchUp plugin manager (I even tried it twice) doesn't install it ?
                        Am I missing something, or is something missing 😉 ?
                        erib
                          renderiza
                          Have you verified that your plugin folder's permission have full rights?
                          Just in case try auto-installing it from Extension Warehouse to see if that works.
                            Thanks for this plugin. I think it'll be very useful.
                            Erik, I just auto-installed it with the Plugin Store and it worked just fine for me.
                            • erikBE Offline
                              erikB
                              Windows keeps being a mystery to me. 😒
                              Not so long ago Tig mentioned the fact that being logged in as administrator not necessary meant you had full rights on every directory. So in order to overcome this he suggested all the usual directory's (sketchup, plugins,..) should all have this full admininstrator rights attributed to them. I don't recall anymore according to which plugin this was mentioned. BUT I then made sure all rights where given, and in the end the plugin worked. Seems that, for what ever reason (microsoft?) this now isn't anymore the case (altough all the other plugins work), for the plugin folder!
                              So again I changed the rights and "hoera !!" it works.
                              And may I say, fantastic plugin !!! So often when moving things (even after checking in x-ray mode) you missed a face of a vertex in the background and therefor messed up your model whit out noticing it. And when you found out later there is so much correction to be done (or some times it is virtual impossible timewise).
                              So 👍 🎉 👍 for this great plugin. (not to mention some other great plugins you made) Thanks,
                              erikB
                              • deaneauD Offline
                                deaneau
                                Really usefull.
                                what do you think about a plugin that can do following:
                                i have an object with inner and outer faces. i would have a plugin that select only outsidefaces.
                                look here
                                http://sketchucation.com/forums/viewtopic.php?f=323&t=38493
                                scroll down to
                                http://sketchucation.com/forums/viewtopic.php?f=323&t=38493#p340407
                                thankyou for this plugin
                                dean
                                  glro
                                  @renderiza said:
                                  [pre]Authors:: Renderiza
                                  [*]Group & Component selection is fixed
                                  [/color]
                                  yes
                                  it works better, thank you...
                                  there seems to be still some problems
                                  selection from top
                                  selection from tp
                                  this is what is selected from another point of view
                                  selection before iselect
                                  after clicking on "iselect" button, some columns remain selected
                                  as i understand the rule (a component which is not totally visible is excluded from the selection), this shouldn't happen, no?
                                  selection after iselect
                                    Seems there is a glitch! 😉
                                    Each 3d block is a group! I select in side view!
                                    Seems don't works when I all select 1 or all select 2 from left to right or right to lerft! 😲
                                    All stay selected after click the black eye!(in perspective or parallal projection) 😮
                                    v6.skp
                                      glro
                                      @renderiza said:
                                      [pre:1w1z3q12]Authors:: Renderiza
                                      Version:: 1.0.1
                                      Date:: 11/6/2013
                                      Cost:: Free[/pre:1w1z3q12]
                                      i use Iselect 1.0.1 to select components, but sometimes i forget to clic on the plugin button after selecting to filter them
                                      i wouldn't forget if the filtering was automatic after selection
                                      so would it be possible modify the order of operations, and embed your plugin in a "filtered selection" tool:
                                      you click on the button corresponding to "filtered selection"
                                      you select
                                      and only then "iselect" is launched to filter the selection
                                      i tried to add some lines of code to yours to do that, but after calling the native select tool, everything stops ...
                                      • danchoD Offline
                                        dancho
                                        does someone use it under SKP 2015. I can't get it to work 😒
                                        • E Offline
                                          Einstein
                                          Hi!
                                          As you can see in the attachment, it also deselects some of the front, visible faces. The problem appears when softened edges come into play.
                                          I also told this in Extension Warehouse.
                                            glro
                                            @renderiza said:
                                            I have updated the code of 'iSelect' and the new version 2.0.0 is available at the following link...
                                            Also, I'll appreciate more feedback so I can improve iSelect even more.
                                            Note: I am charging a small fee for the plugin to help me spend more time making SketchUp Extensions.
                                            best regards,
                                            Renderiza
                                            i tried version 2
                                            still have problems
                                            Error: #<RangeError: float Inf out of range of integer>
                                            C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/MiSU_iSelect/MiSU_iSelect_loader.rb:98:in `*'
                                            selection is not filtered
                                            • 1 / 3
