    [Extension][$] iSelect
    54 Posts 20 Posters 27.7k Views 20 Watching
    • renderizaR
      renderiza
      [pre:12acadvw]Authors:: Renderiza
      Plugin Name:: iSelect
      Version:: 1.0.1
      Date:: 11/6/2013
      Cost:: Free[/pre:12acadvw]
      iSelect v1.0.1 is now available for download.
      http://jroot.sketchucation.com/pluginrepo/image/RND_iSelect_v1.0.0.png
      %(#909090)[What is new:
      • Group & Component selection is fixed
      • Context Menu Added (right click > iSelect)
      • Add keyboard shortcut
      How to set keyboard shortcut:
      Window > Preference > Shortcuts > Function = Edit/Item/iSelect > Add Shortcut
      Thanks for Feedback! 👍]
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • JClementsJ
        JClements
        Thank you.
        • erikBE
          erikB
          Seems like a really, really!! useful tool.
          But auto-install with sketchUp plugin manager (I even tried it twice) doesn't install it ?
          Am I missing something, or is something missing 😉 ?
          erib
          • renderizaR
            renderiza
            Have you verified that your plugin folder's permission have full rights?
            Just in case try auto-installing it from Extension Warehouse to see if that works.
              Thanks for this plugin. I think it'll be very useful.
              Erik, I just auto-installed it with the Plugin Store and it worked just fine for me.
              • erikBE
                erikB
                Windows keeps being a mystery to me. 😒
                Not so long ago Tig mentioned the fact that being logged in as administrator not necessary meant you had full rights on every directory. So in order to overcome this he suggested all the usual directory's (sketchup, plugins,..) should all have this full admininstrator rights attributed to them. I don't recall anymore according to which plugin this was mentioned. BUT I then made sure all rights where given, and in the end the plugin worked. Seems that, for what ever reason (microsoft?) this now isn't anymore the case (altough all the other plugins work), for the plugin folder!
                So again I changed the rights and "hoera !!" it works.
                And may I say, fantastic plugin !!! So often when moving things (even after checking in x-ray mode) you missed a face of a vertex in the background and therefor messed up your model whit out noticing it. And when you found out later there is so much correction to be done (or some times it is virtual impossible timewise).
                So 👍 🎉 👍 for this great plugin. (not to mention some other great plugins you made) Thanks,
                erikB
                • deaneauD
                  deaneau
                  Really usefull.
                  what do you think about a plugin that can do following:
                  i have an object with inner and outer faces. i would have a plugin that select only outsidefaces.
                  look here
                  404 Not Found
                  (sketchucation.com)
                  scroll down to
                  404 Not Found
                  (sketchucation.com)
                  thankyou for this plugin
                  dean
                  • G
                    glro
                    @renderiza said:
                    [pre]Authors:: Renderiza
                    [*]Group & Component selection is fixed
                    [/color]
                    yes
                    it works better, thank you...
                    there seems to be still some problems
                    selection from top
                    selection from tp
                    this is what is selected from another point of view
                    selection before iselect
                    after clicking on "iselect" button, some columns remain selected
                    as i understand the rule (a component which is not totally visible is excluded from the selection), this shouldn't happen, no?
                    selection after iselect
                      Seems there is a glitch! 😉
                      Each 3d block is a group! I select in side view!
                      Seems don't works when I all select 1 or all select 2 from left to right or right to lerft! 😲
                      All stay selected after click the black eye!(in perspective or parallal projection) 😮
                      v6.skp
                      • G
                        glro
                        @renderiza said:
                        [pre:1w1z3q12]Authors:: Renderiza
                        Version:: 1.0.1
                        Date:: 11/6/2013
                        Cost:: Free[/pre:1w1z3q12]
                        i use Iselect 1.0.1 to select components, but sometimes i forget to clic on the plugin button after selecting to filter them
                        i wouldn't forget if the filtering was automatic after selection
                        so would it be possible modify the order of operations, and embed your plugin in a "filtered selection" tool:
                        you click on the button corresponding to "filtered selection"
                        you select
                        and only then "iselect" is launched to filter the selection
                        i tried to add some lines of code to yours to do that, but after calling the native select tool, everything stops ...
                        • danchoD
                          dancho
                          does someone use it under SKP 2015. I can't get it to work 😒
                          • E
                            Einstein
                            Hi!
                            As you can see in the attachment, it also deselects some of the front, visible faces. The problem appears when softened edges come into play.
                            I also told this in Extension Warehouse.
                            • G
                              glro
                              @renderiza said:
                              I have updated the code of 'iSelect' and the new version 2.0.0 is available at the following link...
                              Also, I'll appreciate more feedback so I can improve iSelect even more.
                              Note: I am charging a small fee for the plugin to help me spend more time making SketchUp Extensions.
                              best regards,
                              Renderiza
                              i tried version 2
                              still have problems
                              Error: #<RangeError: float Inf out of range of integer>
                              C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/MiSU_iSelect/MiSU_iSelect_loader.rb:98:in `*'
                              selection is not filtered
                              • G
                                glro
                                @renderiza said:
                                best regards,
                                Renderiza
                                something is missing?
                                content 1
                                content 2
                                i don't see the code that is supposed to do the job
                                • renderizaR
                                  renderiza
                                  Can you provide an attachment of the SketchUp model you are trying to use?
                                  What version of SketchUp are you using?
                                  Can you install the plugin?
                                  Does it work on some faces?
                                  Are you trying to detect Groups or Components?
                                  I'll try to find out how to solve your issue.
                                  Best regards,
                                  Renderiza
                                  • G
                                    glro
                                    @renderiza said:
                                    Best regards,
                                    Renderiza
                                    sketchup 17
                                    it works in some circonstances
                                    trying to detect components
                                    here is the example that fails
                                    platform
                                    top view
                                    top view
                                    "Error: #<RangeError: float Inf out of range of integer>
                                    C:/Users/.../SketchUp 2017/SketchUp/Plugins/MiSU_iSelect/MiSU_iSelect_loader.rb:98:in `*'"
                                    now i admit this is not a usual case
                                    most of the time it works pretty well
                                    • renderizaR
                                      renderiza
                                      Now that I have your SketchUp model I am receiving the error you mentioned. I'll work on fixing it soon.
                                      Renderiza
                                      • renderizaR
                                        renderiza
                                        Try to download the extension again... It should say 'iSelect v2.0.2.rbz' and hopefully the problem you were having is now fixed. Please let me know if it works.
                                        Thanks,
                                        Renderiza
                                        • G
                                          glro
                                          before iselectafter iselect
                                          no error message
                                          and i noticed the progressbar
                                          it is slower but more efficient
                                          thank you
                                          • renderizaR
                                            renderiza
                                            best regards,
                                            Renderiza
                                            • 2 / 3
