    [Extension][$] iSelect
    54 Posts 20 Posters 23.2k Views 20 Watching
    • ElibjrE Offline
      Elibjr
      Thanks Renderiza! This is perfect for very busy models! I like your plugins.
      • JQLJ Offline
        JQL
        LOL! Brilliant! So simple and clever! Just brilliant!
        I'll install it of course but I'm so used to being careful right now that if I use this I may become even dumber than what I already am...
        Thanks,
        JQL
        www.casca.pt
        Visit us on facebook!
        • plesiosaurP Offline
          plesiosaur
          It seems to be deselecting everything. Are there any selection settings that I need to addressed before using?
          • cottyC Offline
            cotty
            Nice idea! Thank you.
            my SketchUp gallery
            • tridemT Offline
              tridem
              very clever ๐Ÿ‘
                So That is Select only visible ? โ˜€
                  samothrace41
                  Thank you very much ! Very useful !
                  • N Offline
                    numerobis
                    Very nice! ๐Ÿ‘ Thank You! ๐Ÿ˜Ž
                      chris87
                      Very useful plugin !
                      Thank you....
                        glro
                        nice idea
                        it works perfectly for faces in the selection
                        but it doesn't work for components in the selection
                        for example:
                        before
                        When i clic on the eye button:
                        after
                        you can see that some components that were visible,have been excluded from the selection, and some others, which were not entirely visible, have been kept
                        Would it be possible to fix that?
                        • JClementsJ Offline
                          JClements
                          Nice job. For those that don't wish to use the toolbar, could there also be another version in which the context menu would display an option to execute the script?
                          • renderizaR Offline
                            renderiza
                            Finished fixing the component & group situation and will start on adding the context menu next. Another plus to adding context menu is that it will show up on keyboard shortcut list. ๐Ÿ˜‰
                            Thanks for feedback! ๐Ÿ‘
                            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                              renderiza
                              [pre:12acadvw]Authors:: Renderiza
                              Plugin Name:: iSelect
                              Version:: 1.0.1
                              Date:: 11/6/2013
                              Cost:: Free[/pre:12acadvw]
                              iSelect v1.0.1 is now available for download.
                              http://jroot.sketchucation.com/pluginrepo/image/RND_iSelect_v1.0.0.png
                              %(#909090)[What is new:
                              • Group & Component selection is fixed
                              • Context Menu Added (right click > iSelect)
                              • Add keyboard shortcut
                              How to set keyboard shortcut:
                              Window > Preference > Shortcuts > Function = Edit/Item/iSelect > Add Shortcut
                              Thanks for Feedback! ๐Ÿ‘]
                                JClements
                                Thank you.
                                • erikBE Offline
                                  erikB
                                  Seems like a really, really!! useful tool.
                                  But auto-install with sketchUp plugin manager (I even tried it twice) doesn't install it ?
                                  Am I missing something, or is something missing ๐Ÿ˜‰ ?
                                  erib
                                    renderiza
                                    Have you verified that your plugin folder's permission have full rights?
                                    Just in case try auto-installing it from Extension Warehouse to see if that works.
                                      Thanks for this plugin. I think it'll be very useful.
                                      Erik, I just auto-installed it with the Plugin Store and it worked just fine for me.
                                      • erikBE Offline
                                        erikB
                                        Windows keeps being a mystery to me. ๐Ÿ˜’
                                        Not so long ago Tig mentioned the fact that being logged in as administrator not necessary meant you had full rights on every directory. So in order to overcome this he suggested all the usual directory's (sketchup, plugins,..) should all have this full admininstrator rights attributed to them. I don't recall anymore according to which plugin this was mentioned. BUT I then made sure all rights where given, and in the end the plugin worked. Seems that, for what ever reason (microsoft?) this now isn't anymore the case (altough all the other plugins work), for the plugin folder!
                                        So again I changed the rights and "hoera !!" it works.
                                        And may I say, fantastic plugin !!! So often when moving things (even after checking in x-ray mode) you missed a face of a vertex in the background and therefor messed up your model whit out noticing it. And when you found out later there is so much correction to be done (or some times it is virtual impossible timewise).
                                        So ๐Ÿ‘ ๐ŸŽ‰ ๐Ÿ‘ for this great plugin. (not to mention some other great plugins you made) Thanks,
                                        erikB
                                        • deaneauD Offline
                                          deaneau
                                          Really usefull.
                                          what do you think about a plugin that can do following:
                                          i have an object with inner and outer faces. i would have a plugin that select only outsidefaces.
                                          look here
                                          http://sketchucation.com/forums/viewtopic.php?f=323&t=38493
                                          scroll down to
                                          http://sketchucation.com/forums/viewtopic.php?f=323&t=38493#p340407
                                          thankyou for this plugin
                                          dean
                                            glro
                                            @renderiza said:
                                            [pre]Authors:: Renderiza
                                            [*]Group & Component selection is fixed
                                            [/color]
                                            yes
                                            it works better, thank you...
                                            there seems to be still some problems
                                            selection from top
                                            selection from tp
                                            this is what is selected from another point of view
                                            selection before iselect
                                            after clicking on "iselect" button, some columns remain selected
                                            as i understand the rule (a component which is not totally visible is excluded from the selection), this shouldn't happen, no?
                                            selection after iselect
                                            • 1 / 3
