    [Extension][$] iSelect
    54 Posts 20 Posters 28.5k Views 20 Watching
    • tridemT
      tridem
      very clever ๐Ÿ‘
        So That is Select only visible ? โ˜€
          samothrace41
          Thank you very much ! Very useful !
          • N
            numerobis
            Very nice! ๐Ÿ‘ Thank You! ๐Ÿ˜Ž
            • C
              chris87
              Very useful plugin !
              Thank you....
              • G
                glro
                nice idea
                it works perfectly for faces in the selection
                but it doesn't work for components in the selection
                for example:
                before
                When i clic on the eye button:
                after
                you can see that some components that were visible,have been excluded from the selection, and some others, which were not entirely visible, have been kept
                Would it be possible to fix that?
                • JClementsJ
                  JClements
                  Nice job. For those that don't wish to use the toolbar, could there also be another version in which the context menu would display an option to execute the script?
                  • renderizaR
                    renderiza
                    Finished fixing the component & group situation and will start on adding the context menu next. Another plus to adding context menu is that it will show up on keyboard shortcut list. ๐Ÿ˜‰
                    Thanks for feedback! ๐Ÿ‘
                    [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                    • renderizaR
                      renderiza
                      [pre:12acadvw]Authors:: Renderiza
                      Plugin Name:: iSelect
                      Version:: 1.0.1
                      Date:: 11/6/2013
                      Cost:: Free[/pre:12acadvw]
                      iSelect v1.0.1 is now available for download.
                      http://jroot.sketchucation.com/pluginrepo/image/RND_iSelect_v1.0.0.png
                      %(#909090)[What is new:
                      • Group & Component selection is fixed
                      • Context Menu Added (right click > iSelect)
                      • Add keyboard shortcut
                      How to set keyboard shortcut:
                      Window > Preference > Shortcuts > Function = Edit/Item/iSelect > Add Shortcut
                      Thanks for Feedback! ๐Ÿ‘]
                      • JClementsJ
                        JClements
                        Thank you.
                        • erikBE
                          erikB
                          Seems like a really, really!! useful tool.
                          But auto-install with sketchUp plugin manager (I even tried it twice) doesn't install it ?
                          Am I missing something, or is something missing ๐Ÿ˜‰ ?
                          erib
                          • renderizaR
                            renderiza
                            Have you verified that your plugin folder's permission have full rights?
                            Just in case try auto-installing it from Extension Warehouse to see if that works.
                              Thanks for this plugin. I think it'll be very useful.
                              Erik, I just auto-installed it with the Plugin Store and it worked just fine for me.
                              • erikBE
                                erikB
                                Windows keeps being a mystery to me. ๐Ÿ˜’
                                Not so long ago Tig mentioned the fact that being logged in as administrator not necessary meant you had full rights on every directory. So in order to overcome this he suggested all the usual directory's (sketchup, plugins,..) should all have this full admininstrator rights attributed to them. I don't recall anymore according to which plugin this was mentioned. BUT I then made sure all rights where given, and in the end the plugin worked. Seems that, for what ever reason (microsoft?) this now isn't anymore the case (altough all the other plugins work), for the plugin folder!
                                So again I changed the rights and "hoera !!" it works.
                                And may I say, fantastic plugin !!! So often when moving things (even after checking in x-ray mode) you missed a face of a vertex in the background and therefor messed up your model whit out noticing it. And when you found out later there is so much correction to be done (or some times it is virtual impossible timewise).
                                So ๐Ÿ‘ ๐ŸŽ‰ ๐Ÿ‘ for this great plugin. (not to mention some other great plugins you made) Thanks,
                                erikB
                                • deaneauD
                                  deaneau
                                  Really usefull.
                                  what do you think about a plugin that can do following:
                                  i have an object with inner and outer faces. i would have a plugin that select only outsidefaces.
                                  look here
                                  http://sketchucation.com/forums/viewtopic.php?f=323&t=38493
                                  scroll down to
                                  http://sketchucation.com/forums/viewtopic.php?f=323&t=38493#p340407
                                  thankyou for this plugin
                                  dean
                                  • G
                                    glro
                                    @renderiza said:
                                    [pre]Authors:: Renderiza
                                    [*]Group & Component selection is fixed
                                    [/color]
                                    yes
                                    it works better, thank you...
                                    there seems to be still some problems
                                    selection from top
                                    selection from tp
                                    this is what is selected from another point of view
                                    selection before iselect
                                    after clicking on "iselect" button, some columns remain selected
                                    as i understand the rule (a component which is not totally visible is excluded from the selection), this shouldn't happen, no?
                                    selection after iselect
                                      Seems there is a glitch! ๐Ÿ˜‰
                                      Each 3d block is a group! I select in side view!
                                      Seems don't works when I all select 1 or all select 2 from left to right or right to lerft! ๐Ÿ˜ฒ
                                      All stay selected after click the black eye!(in perspective or parallal projection) ๐Ÿ˜ฎ
                                      v6.skp
                                      • G
                                        glro
                                        @renderiza said:
                                        [pre:1w1z3q12]Authors:: Renderiza
                                        Version:: 1.0.1
                                        Date:: 11/6/2013
                                        Cost:: Free[/pre:1w1z3q12]
                                        i use Iselect 1.0.1 to select components, but sometimes i forget to clic on the plugin button after selecting to filter them
                                        i wouldn't forget if the filtering was automatic after selection
                                        so would it be possible modify the order of operations, and embed your plugin in a "filtered selection" tool:
                                        you click on the button corresponding to "filtered selection"
                                        you select
                                        and only then "iselect" is launched to filter the selection
                                        i tried to add some lines of code to yours to do that, but after calling the native select tool, everything stops ...
                                        • danchoD
                                          dancho
                                          does someone use it under SKP 2015. I can't get it to work ๐Ÿ˜’
                                          • E
                                            Einstein
                                            Hi!
                                            As you can see in the attachment, it also deselects some of the front, visible faces. The problem appears when softened edges come into play.
                                            I also told this in Extension Warehouse.
                                            • 1 / 3
